Hello. I recently did a hard reset on my ZyXEL P-873HNUP-51B router and now I have no Internet. I typically have 2 dsl lights on, I now only have one. Is this something I did? How can I fix this? I can access the admin web configurator if that helps.
SOURCE: i cant configure Edimax BR-6104K router with PLDT auto-connect DSL
Try set the Edimax router to accept a Dynamic IP from the ISP - cause I guess they provide it to you changed everytime you disconnect.
Posted on Mar 27, 2008
tech curly
  • 298 Answers
SOURCE: No DSL or Internet light
Does your mac book has a phone port? You can try that to setup a dial up connection an see if it will work.
Posted on May 20, 2008
  • 104 Answers
SOURCE: ZyXEL P-660HW-D3 password change
There should be a tiny recessed 'button' (usually more of a hole) in the back of your router. This may be marked 'reset'.
To use this to reset your router, the manual for the Zyxel P660HW router advises that your power LED should be on, but not blinking.
Push the end of an opened out paperclip into the 'reset' button (hole) for 10 seconds, or until the power LED blinks. This restores your defaults. The manual I have advises that your password will be reset to 1234. If you have a manual, please check this.
Good luck ;-)
Posted on Dec 01, 2008
SOURCE: Unable to access DLink WBR 2310 Configuration page
Reset the router first, press the reset pinhole on the back for 10 seconds using a paper clip, don't press it too much or it will mess up the settings of the router. then try to access again the configuration page.
Posted on Feb 10, 2009
plettdoctor
  • 121 Answers
SOURCE: P-661H-D3 zyxel problem?
The fact that it does not get an IP address almost certainly means that the router is KAPUT. You may try to add in a manuel address. In you network settings of your computer you can put the following IP addresses:
IP Address : 192.168.0.100
SUBNET MASK : 255.255.255.0
GATEWAY : 192.168.0.1
then try to see if you can connect to the internet (see if the internet light then comes on.)
Let me know if it works. I may still be able to help you after that.....
My email = doc@plettcomputerdoctor.co.za
Posted on Jul 15, 2009
How do i fix connection for router zyxel wap3205
Turn your DSL/cable modem off.
Turn your ZYXEL router off.
Turn your DSL/cable modem on.
Turn your ZYXEL router on.
Restart your computer.
You should now have an Internet connection.
Mar 05, 2015 | Zyxel WAP3205 Wireless Access Point -...
Hello lost my password to access my zyxel 660hn router and i am concerned about resetting as I am not sure of the info I will have to enter after reset..its in French and German and not english. will the...
If you lost your password to access the router's web interface, then a hard-reset is the only thing you can do. That said, it will configure the router to factory condition. If your ISP requires particular authentication (like a member ID and network password for DSL), then this information WILL need to be re-entered. If your ISP does not require that configuration, then nothing would need to be configured after the hard-reset. Before moving ahead, it may be a good idea to contact the ISP to understand configuration requirements.
Sep 21, 2011 | Zyxel P660HW-D1 Router
I have a Zyxel Q1000z dsl router power light and DSL light on solid green however internet light is completely out not red or green or anything Qwest my service provider tested the line as good. I have...
If you have called your service provider and they have confirmed that the connection is good then there may be a problem with:
A- The router itself
B-The physical connection from the ISP's last access point to your router.
Your best bet would be to (if you haven't already) reset the router and wait AT LEAST 10-15 seconds before plugging it back in.
Another solution would be to go to the router configuration page and check the router logs to see when the problem first occurred, and what could be causing it.
Jul 09, 2011 | Zyxel P660HW-D1 Router
My Zyxel P-600 series router cannot establish a DSL connection. The WLAN light will illuminate as normal, so I suppose that works, but no DSL or internet connection. I've had this problem for a couple of...
Thank you for using FixYa
It sounds like your internet connection is down or has intermitent connectivity. You need to call your DSL supplier and see if they are having problems. They can test your connection.
I hope this was useful and please comment if this was helpful to you.
Apr 25, 2011 | Zyxel Prestige 841 (91-004-226010) Modem
I tried to change my security to wep and it just stopped connecting so i reset the router and now there is no dsl wlan or internet light on just a power light
Let's guess. This is a DSL connection and you just reset the access to your internet account.
Find the paper or person who set the system up originally and start all over. Next time, have some sort of idea what you're doing BEFORE you press the reset button. You started with access to the router, and changing Wireless Security settings could have been undone if you went back into the box from a WIRED connection and turned off or altered the WEP code.
Good luck.
Carl
May 25, 2010 | Zyxel P660HW-D1 Router
Dsl light stays on but internet drops out
reset the router or contact your internet provider...could be something with the router.
Jan 19, 2010 | Zyxel Prestige 660R Router (91004397002)
Describe your zyxel p-600 dsl light turns off then on
Hello kb_gimper,
The power light and all other lights blink when the ZyXel P-600 is initializing. The ethernet, dsl and internet lights blink when data transfer is detected. The lights are from left to right:
* Power Light
* Ethernet Light
* DSL Light
* Internet Light
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Dec 19, 2009 | Zyxel Prestige 660R Router (91004397002)
Zyxel 660HW DSL LED keeps flashing
Try to change the Local or LAN IP Address of your Zyxel to 192.168.5.1 and do not configure the Zyxel router for PPPoE Connection. It should be configured as Obtain IP Automatically or Automtic DHCP.
Oct 21, 2009 | Zyxel Prestige 660HW Wireless Router...
Jul 15, 2009 | Zyxel Prestige 660R Router (P660R)
May 20, 2008 | Zyxel Prestige 660R Router (91004397002)
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
