Question about Vintage Keeper Refrigerators
Compressor for vintage keeper model cy7ab
S.n. 7ab01=3 Refrig :112 Volts/hz115v 60 hz
4 Suggested Answers
yalmer
  • 549 Answers
SOURCE: I have a 2002 frigidare
Here is a link to trouble shooting answers.
Could be a bad start relay, overload, dirty condensor coils, condenser fan motor is not running.
If the link does not work then copy and paste.
http://www.applianceaid.com/refrigerator.html#clicking
Posted on Apr 29, 2008
  • 1218 Answers
SOURCE: kenmore top mount refrigerator, 18 cubic feet. how
Good day,
That sounds about right, however if your generator is rated in wattage the amps times volts won't work.
On an induction unit, such as a refrigerator, the wattage is volts times power factor times amps.
Nominal wattage should be around 375 watts. However, during auto defrost the heater will probably be around 450 watts.
As well, locked rotor amps on starting will be about 4 times running amps approx. 18 to 20 amps. so your generator will have to be able to handle that.
The short and long of it is give yourself wiggle room.
Posted on Aug 24, 2010
oldTech2332
  • 2341 Answers
SOURCE: I have a kenmore refrig/freezer.
The calulation of max wattage is going to be 750 watts at start up and be around 500 on normal running wattage after start up so a 1100 watt generator should be fine.
GENE
Posted on Sep 06, 2011
Trying to find the right fuse for a eden World Tour 800 bass amp
Well, hope this helps you.
Fuse Requirements:
USA @ 120 Volts /60 HZ - 10 Amps, 5 x 20 mm GMC/T/slow blow
Europe @ 240 Volts/50 Hz - 5 Amps, 5 x 20 mm GMC/T/slow blow
Japan @ 100 Volts/60 Hz - 12 Amps, 5 x 20 mm GMC/T/slow blow
Mar 10, 2013 | Hartke HyDrive HX410 4x10 Bass Cabinet...
I have a kenmore refrig/freezer. Full load amp is 6.5 , 60 hz and 115 volts. I have a generator that will take 1100 watts with 1500 peak or surge watts. I heard that refrigerators use more electricity or...
GENE
Sep 06, 2011 | Kenmore Refrigerators
Kenmore top mount refrigerator, 18 cubic feet. how many amps doe it use. question is for purchase of emergency generator. spec Plate states 4.5 amps, is that accurate? Refrig is 115 volts, 60 hz
Good day,
Aug 24, 2010 | Kenmore Refrigerators
Bought a TD 150 MkII that runs 100 ~ 240 volts 50 Hz. In my country we have 60 Hz. How to correct ?
It's simply a matter of if the transformer can take the 60 Hz. After that the supply passes via a large electrolytic capacitor which is there to take out the 50 Hz. Otherwise you get a hum, which is what happens when the large capacitor fails.
Though I can not be certain! It might just work with the 60 Hz without doing nothing. Though if you get a hum you might need to replace the big capacitor with one with a greater value than the one in. Say the one you have in is 2200uf at 50v, you would need to replace it with 4700uf or higher at the same voltage or higher. Of course the other problem might be getting a bigger capacitor in!
Jan 11, 2010 | Thorens Audio Players & Recorders
I'm reading 130VAC on the output. Can this be
It should read 115v-120v with full load. Yes, you can slow the engine down just a little, depending on the engine, there will be a high rpm adjustment. 130v with full speed, no load, is really not too bad.
Nov 26, 2009 | Coleman Powermate Powermate 5000W...
Manual for split acu model LP-10091 i need replacement of compressor scroll type 380 volts 60 hz 3 phase
You will have to go through a distributor or a dealer. Most often, you will have to be licensed by the state to purchase this item unless you can find a bootleg somewhere on the internet. You can find the manual for this on the LG website. www.lge.com
Apr 18, 2009 | Heating & Cooling
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
Here are the specs on your compressor:
Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Mar 21, 2009 | Air Tools & Compressors
Different HZs problem (from 60Hz to 50Hz)
Yes there are frequency converters available but most are relatively over rated (industrial) for your requirement such as MDS Power or VisiComm Industries. What you need is a Low Power Solid State Frequency Converters lower than a
Electrocon Frequency Converters. However, I expect this devices to be rather expensive.
A few other options you may want to consider:
1. Contact the store where you bought if from; swap with an International version (Model SL-1210 Mark II; same price as SL-1200 Mark II); dual voltage switchable on rear of unit: 120 volts/60 Hz (U.S.) or 220 volts/50 Hz (Europe). You hopefully just spend for the cost of shipping + a restocking fee;
2. Contact 3rd party Technics TT specialist like TopDJGear, Quality Electronics, Planet DJ or DJHardware
and inquire if they would supply you the part(s) that you need to convert the 1200 to a 1210; or
3. Offer a swap on eBay.
Hope this be of some idea/help. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 13, 2007 | Technics SL-1200MK2 Turntable
Refrigerators Logo
66 people viewed this question
Top Vintage Keeper Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Vintage Keeper Refrigerator Expert? Answer questions, earn points and help others
