Question about Dell Vostro 3500 Notebook PC Core i3 i3350M 226 GHz 156 Aberdeen Silver 2 GB DDR3 SDRAM 2
Upgrade cpu to 15-580M on 0G2R51 dell motherboard
I have a dell vostro 3500 with a 0G2R51 dell motherboard. It has a i3-350M cpu and I would like to upgrade to an i5-580M. The I-5 580M has same G1-socket, L1 and L2 cache and 35w TDP. The FSB of 1066 mhz matches but I'm not sure The L3 cache does. Graphics and memory controllers are located on a separate die. And I'm wondering about that too. thank you
3 Suggested Answers
ijaz641
  • 4 Answers
SOURCE: what is dell l2 cache patern test failure?
cmos problem battry 3v change or bois chip change ok
Posted on Nov 12, 2009
  • 2567 Answers
SOURCE: how do i install the
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Posted on Sep 18, 2010
Hard drive beeps
was your vostro 230 third generation? meaning, did it use DDR2 memory before or always had DDR3? They are not compatible. 2nd generation computers cannot use third gen parts. cpu, ram, most none of that type stuff. the motherboards are different and cannot change. if it was ddr2 memory you have to use ddr2, not ddr3, hope that helps.
Nov 19, 2013 | Dell Vostro 230 Safe space Tower w monitor...
Vostro 3500 won't turn on and charger light is flashing
How old is your laptop? if it is over 5-6 months it could be because of a faulty battery. You may want to upgrade or change your battery.
Apr 10, 2013 | Dell Vostro Computers & Internet
Need step by step instructions on replacing a palm rest on the dell vostro 3500
try this easy step by step instruction. hopefully it's of use to you
http://support.dell.com/support/edocs/systems/vos3500/en/SM/Palmrest.htm
Oct 16, 2012 | Dell Vostro 3500 Laptop Computer (Intel...
Water pilled in my dell vostro 3500 , i left it to dry for several days and till now it doesn't work , the screen is off even the power is on , and also fan on , light is fine to. what is the pro
The water is inside the machine on the motherboard and is causing a short, I recommend removing the main battery unplug the power supply open up laptop and lay it face down on a thick towel to assorb any moisture coming out from the keyboard, but I strongly suggest a pro take it apart for a cleaning provided the main board can be saved.
Jul 21, 2012 | Dell Vostro 3500 Laptop
The cap lock and scroll lock flashes and the number lock stays lit and it wont start on my Vostro 3500
This indicates a motherboard issue, remove main battery, and unplug the charger from the laptop, now press and hold power button for 60 seconds in hopes to reset the computer. Install battery and charger and turn on.
Jun 14, 2012 | Dell Vostro 3500 Laptop
Dell Vostro 3500 suddenly shut down, start up and works fine, after 2 minutes turn off without any warning message this happened after i installed bios upgrade A10 from dell.com
this is happening because of bios upgrade but not in a bad way. May be there is a hardware problem just starting so new bios upgrade is detecting that and thats why its restarting.
basically sudden shut down occurs in either cases- Fan not working or hard disk(or RAM) gone bad.
my advise is to contact dell customer support and they will guide you thru trouble shooting steps.
they will guide you if your warranty is not there.
Jan 02, 2011 | Dell VOSTRO 3500 Notebook
I have a vostro 3500, after i installed A10 bios upgrade from Dell.com my laptop suddenly turn off 2 minutes after i turn it on can anybody please help me?
hi eily81,
good day!We have the same problem last time I troubleshoot dell laptop.But I just wait for a minute before I turn it ON..but still turned OFF..so I tried to pull off the battery and power it directly in line.Then keep pressing the power ON..then it begin displaying.
If you can do that..try it.
mastergani
Can i upgrade a dell vostro 200 computer to a q8400 cpu
unforntuately, these are the only type of processors that the vostro motherboard supports
Intel® Core2 Duo processor
Intel® Pentium® Dual-Core processor
Intel® Celeron® processor
the one that you were asking to use is not compatible since it's a Quad processor.
Oct 10, 2009 | Foxconn Computers & Internet
Dell Vostro 3500 Notebook PC Core i3 i3350M 226 GHz 156 Aberdeen Silver 2 GB DDR3 SDRAM 2 Logo
134 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
