Question about Garden
Toro 20071 Starter recoil rope broke. how do you replace it for a 22" recycler model # 20071?
clyde2j2
  • 137 Answers
SOURCE: starter rope broke
Unless you know how or have the patience of Jobe save yourself a lot of grief and take it in to a lawnmower repair guy.
Posted on Mar 24, 2009
  • 4 Answers
SOURCE: starter rope broke on yard machine
Take the top off. Remove broken rope. Rewind spring until tight, then unwind one turn. Insert and knot new rope.
Posted on Jun 16, 2009
pippall
  • 1486 Answers
SOURCE: spring tip broken
the coil spring is allready in place.you have to by the whole thing.You can get them from the internet.
Posted on Jul 24, 2009
  • 65 Answers
SOURCE: Toro Recycler 6.5HP recoil start cord pulls hard & snaps back in
This sounds like you have bent the shaft. This happens when you run over something hard. Hope this will help.
Posted on Jul 25, 2009
97F350diesel
  • 1326 Answers
SOURCE: starter pull rope broke. how do i replace?
Should be 3-4 bolts right on top of the pull starterhousing, take them off to replace string
Posted on Nov 10, 2009
How do I replace the starter (pull) rope on a toro ccr2450 (model 38413)?
Although it looks like you simply un-bolt the recoil starter you need remove the whole blower (flywheel) housing as there are nuts on the back side.
  • Once the housing is off, remove the broken rope and prepare a length of rope to replace it base upon the old ropes length. Probably close to 6 feet.Don't forget to put the pull handle on the new rope.
  • Tighten the recoil pulley in the direction it normally turns as you pull the rope out until it stops.
  • Slowly back of up to one turn to align the hole in the pulley with the housing hole and hold it in that position while you insert the rope and try a sturdy knot.
  • Slowly let recoil assembly pull the rope back in and test that it is working properly before re-installing the housing.
  • Once you are satisfied that the recoil is working properly re-install the remaining covers.
Jan 15, 2015 | Toro Garden
How to fix stuck pull cord of a 22 inch Toro Recycler lawn mower
Is the engine seized?. Try turning the blade and if it won't turn then you have a seized engine. If that is ok your recoil has a stuck part possibly something has broken off inside. If it's an older model try shooting WD40 inside the recoil as it could be rusty.
Jul 25, 2014 | Toro Garden
HOW TO FIX MY TORO RECOIL
You need to probably replace or put the recoil spring back in place.,You have to take the recoil off to do it.
Jun 22, 2014 | Toro Power Lawn Mower
Starter rope replacement
recoil spring has slipped out of the hole.pull your starter rope out of the wind up mechanism, insert the spring latch on both ends and put back into housing. with a piece of 3/4 square stock or something the will fit mthe hole start to wind the mechanism spring up tight. with apair vishgrips lock it down so it does not move. insert your starter rope anr release the visegrips. the springwii recoil and pull the rope in.cut off excess rope. good luck
Oct 17, 2012 | Little Wonder 6032 10 Inch Pro Lawn Edger,...
Pullstart cable broke
Remove nuts mounting recoil assembly. Observe how rope is wound around pulley. Find end knot in pulley wheel. Cutoff end knot and remove old rope. Find end knot in handle, use needle nose pliers pull thru old rope. Rope is sold by the foot at mower repair shops. Replace rope as observed before removal. Cut to size after wrapping recoil assembly and attaching thru handle at proper length if at recoil assembly or on mower handle. Ensure good knot in hole of recoil assembly and handle.
Sep 22, 2012 | Toro Power Lawn Mower
Starter rope broke how do i replace it. toro super recycler mower. Removed the plastic engine cover and the recoil mechanism seems to be rivited down and I cant get in there to replace the rope. Please...
You have to remove the whole engine air shroud over the flywheel to gain access to the recoil and rope mechanism. If you need specific help on your exact model engine I need all of engine model type numbers 5 to 6 char then 4 char then 2 char i.e XXXXXX-YYYY-ZZ for B & S Honda numbers are by the engine oil port on the base of the crank case. Thanks for using FixYa, Kelly
Apr 22, 2010 | Toro Lawn Mower With Toro Power Tools
How to change the pull string on a toro 22 inch recycler
To take the housing off, you may need to remove the carb choke houseing "becasue of a hard to reach bolt. A small oil filler tube screw and then a couple screws on the top. I dont know if you broke the rope or of the assemble inside is broke, but they make a kit for new springs and wings that is fairly simple to replace if thats the latter of the two.
I would discourage the average handy person from undoing the screw on the plastic reel inside under the cover and pulling up, as it is the metal band that creates the recoil tension and those are challenging still 15 years later. ;)
Aug 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Starter Rope Rewind Problem
I need to replace rope on my lawnmower starter, are there any tips on this?
Dec 11, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Mower Recoil Assembly
try turning it clockwise. if it doesnt work it means the inner coil may be broken. its pretty difficult to fix those but if you would to try let me know and i'll talk you through it
Sep 20, 2008 | Toro Lawn Mower With Toro Power Tools
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
