Question about Boating
Mercury 60 hp outboard no spark - Boating
  • 187 Answers
SOURCE: 1994 40 hp mercury force outboard with no spark
If the fuel was not treated with a fuel stabilizer than you probably have a varnish build up in the carburetor. This varnish will clog fuel needle valves and jets. You need to disassemble the carb to clean the jets and needle valves. Sometimes cleaner is not enough you need to us compressed air to blow out the jets. Good luck.
Posted on May 13, 2009
SOURCE: 9.8 hp mercury outboard shutting off in low idle speed.
My problem ended up being the spring on the reed valve being weak.But at the same time and while I had already had my carb broke down I took a can of carb cleaner to it and cleaned it. In order to replace the spring on reed valve you will have to buy a new one, but don't worry I only payed about $6.00 for mine. You may also look into replacing your primer bulb if you haven't already because may allowing air to build up in your gas line while you are basically idiling.Once you get the carb straightened out you may have to reajust it again. If I might be able to help you again you may contact me at j_speaks@yahoo.com.
Posted on Jun 16, 2009
  • 77 Answers
SOURCE: mercury outboard 60 motor turning over but not firing up.
get some starting fluid and spray a liberal amount into the air intake, then try to turn over. if it will not turn over with starting fluid you have a problem either with your ignition system, example: plugs, coils, wires, ect. If it does fire and then die out with a shot of starting fluid then you have a carb problem. If the boat has been sitting anything over a month thats where I'm betting the problem is. Post back after you find out if its a fuel, or fire issue and we'll start the repair process.
Posted on Jul 02, 2009
  • 86 Answers
SOURCE: Spark plug gap 150 hp Yamaha outboard
The correct gap is .035
Posted on Oct 16, 2009
  • 2926 Answers
SOURCE: 2000 Mercury 75 outboard 3 cylinder with 3
No spark can be attributed to two components; The stator or the trigger assembly. Even if you had a diagram (available online @ Mercury), you will still need a test harness,a DVA adapter and a meter to measure the resistance of the CDM's (capacitor discharge module) ,stator and trigger assembly. Best case fix would be the trigger, most expensive would be the stator. If you remove the flywheel, and inspect the stator, you can inspect the the coils that are coated with a white epoxy, and if one or more are bad, they sometimes leak a black resin, indicating the coil(s) have been shorted and no longer provide voltage for spark.
Posted on Jan 22, 2011
Mercury 1989 60 HP Outboard Motor manual to find gas to oil ratio
50:1 But if your doing mostly low rpm cruising (trolling) then you could reduce that a bit to 75:1 to help reduce smoke. If you do mostly mid to higher rpm cruising, then 50:1 (1 pint to 6 gallons. )
Or 200mls in 20 liters if your Canadian.
Feb 26, 2016 | Seloc Mercury Outboard Repair Manual, 1965...
1985 mercury 150 hp outboard V6 black-max.Where can I get a free service manual. I really only need the wiring diagrams. 1985 mercury 150 hp V6
go google and type in--- mercury outboard motor manuals --and there are pages of download manuals
if there is not one for your engine then alter the url question to --manual for mercury outboard engine 150hp v6--and see what comes up.
Sep 22, 2015 | Boating
Engine diagram parts
Have you replaced the impeller in the lower unit recently? If so was it in pieces? I would start there.
Aug 21, 2014 | Clymer Mercury/Mariner 2.5-60 HP...
Why won't my mercury optimax 150 outboard start?
your owners manual should tell you what the beep code means.or call a dealer and ask them.
Jun 08, 2014 | Boating
How do i fix a mariner 60 outboard motor that has fuel starvation?
have you checked the fuel pump diaphrams are ok and are the connections on the fuel tank and line ok ? primer bulb not sticking ? carbs clean ? fuel pump connection to crankcase ok ?
Apr 26, 2014 | Clymer Mercury/mariner 2.5-60 Hp...
2stroke 8 HP mercury outboard,newish engine no spark
Clean or change the Spark Cables>
to cleab the pull them out and with antirust spray and clean
May 06, 2010 | 2009 Mercury Mariner Hybrid
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
