Question about Tools & Hardware - Others
Clarke sander sander keeps shutting off - I'll turn it on, it will run for 10 seconds, then will shut off. I'll press the white reset button, start it up again, and same thing happens over and over.
    New Friend:
Once we plugged it into an outlet with a trip switch it worked.
Posted on Aug 07, 2016
rowdy45176
  • 2176 Answers
SOURCE: sander kick out
I cant find anything on the powermatic tool that you listed, but is this something recent? Look at the nameplate on the machine and if it a large unit it would probably say around 15-20 amps but to start the unit sometimes it pulls more than the listed rating and could be causing your problem. Check the outlet that you have it plugged into, is there anything else online with this that would draw a lot of current when starting e.g. freezer. If you can provide me with some more data I will check other floor sanders and see what I can come up with.
Posted on Feb 06, 2009
  • 630 Answers
SOURCE: the belt on the sander doesn't turn. The sander
Sounds like the last time it was being used a piece of old belt tore off and wedged itself in the sander locking the belt wheel from turning, unplug and try to clear it out,you may have to take off a shield to gain access.
If its not a stoppage of the belt wheel, it may need new brushes, that would be the next thing to test after it has been cleared for any obstruction, generally brushes cause a nasty smell when they are burnt out, unplug the tool and open up the slotted ports that contain the brushes, one on each side of the motor, replace if they are worn too far down.
Posted on Jun 13, 2010
rowdy45176
  • 2176 Answers
SOURCE: skill 7292 hand sander won't turn on
a lot of times sawdust gets into the switch contacts and won't allow the tool to operate. I would try turning the switch on/off several times and see if it temporarily helps. Also check the cord. Let me know if you need more assistance.
Posted on Mar 04, 2012
H2_Brad
  • 425 Answers
SOURCE: Bosh B7350 Belt Sander not working
Did you pull the plastic cover on the left side to see if the drive belt has broken? I think the cover is held on with only one screw.
Posted on Aug 23, 2012
SOURCE: clarke belt sander runs in reverse
sounds like a wiring issue with in the machine?
Posted on Sep 13, 2012
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Reset kindle fire
Press and hold the power button, ignoring the prompt asking whether you want to shut down, until the screen goes blank. To turn it back on, you'll have to press and hold the power button for a second or two.
Nov 10, 2012 | Computers & Internet
Side lx won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 01, 2012 | T-Mobile Cell Phones
My dolphin inexplicably shuts off for no apparent reason. It's been happening since I charged it last - about 4 uses ago. It'll be playing for 5 to 10 minutes, even 15, then just shuts down. ...
Have you checked the settings? There's one in there for auto-shutoff. I had this happen and it turned out I had accidentally changed this setting.
Sep 12, 2011 | NuTech NU Dolphin (4 GB) MP3 Player
My HTC HD 7 phone keeps turning off it goes to the white screen with green HTC then shuts off and keeps doing the same thing over and sometimes when i try to use it and i tap the screen then it shuts off...
I finally had to have them replace the unit. If doing a factory reset does not help, then I would have them replace it. Mine started rebooting infrequently, but then started doing it more often. They didn't waist any time getting my replacement out.
Please make sure you back up all your contacts/email before proceeding. I use Google on my phone through the Outlook option. Google/Outlook syncs all my mail, contacts, and calendar.
RESET: Software: SETTINGS > ABOUT > RESET YOUR PHONE
Hardware: 1) Turn off phone 2) While holding down both the Up/Down Volume buttons, turn unit on 3) Keep holding down the volume buttons until white screen appears 4) Press the Down Volume button to reset to factory defaults. 5) Restart phone
Jun 28, 2011 | HTC HD7 Cell Phone
My iPhone is stuck on the white screen but i cant really use it..i tried to restore it on itunes but i cant since it has a passcode but i cant type it in because the screens white and i cant see the...
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Jan 27, 2011 | Apple iPhone Smartphone
Apple 20 in Imac G5 turn on for about 40 second and shut it down itself .. please help
Sounds like you need to reset your SMU and NVRAM:
To reset your SMU:
  1. Turn off the computer by choosing Shut Down from the Apple menu, or by holding the power button until the computer turns off.
  2. Unplug all cables from the computer, including the power cord.
  3. Wait 10 seconds.
  4. Plug in the power cord while simultaneously pressing and holding the power button on the back of the computer.
  5. Let go of the power button.
  6. Press the power button once more to start up your iMac.
To reset your NVRAM:
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
If those don't resolve the issue, your computer will probably need service. Good luck!
Oct 10, 2010 | Apple iMac G5 Desktop
Alarm light on and u051 error mx310
Hi
You’ll need to reset your printer to clear the ink counters, after resetting it’ll not display the error code again. Follow this procedure to reset the printer--
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset.
Please rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Frozen jailbroken iphone 3g
I'll recommend you re-break your phone and if you are willing to perform the task in a more simple yet time-saving manner, follow the step by step guide from this website: iphoneunlockeasily.com
Jul 24, 2009 | Apple iPhone 3G
Toshiba Satellite A15-S157 PC Notebook
go to services.msc and chk if the wireless zero is on or off
Nov 05, 2008 | Toshiba Satellite A15-S157 Notebook
Tools & Hardware - Others Logo
545 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
