Question about Acer Computer Monitors
Liteview lm19w my son has pinched my pc speakers duz my monitor have speakers
0 characters
1 Points
My son has an LG W2234S monitor with his desktop computer. when you start up the computer the monitor just says power save mode and the screen then goes black. We have tried attaching the monitor to my...
If this monitor works with your lap top or the other PC (not your son's PC). Then your son PC video card may not be sending out the video signal so the monitor goes into power save mode.
Did you try another monitor with your son's PC yet?
Does the PC has plug in video card or it is integrated with the mother board, you can also try reseating the card and the RAM.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 29, 2010 | LG Computer Monitors
Have an AOC 2436Vh monitor. It has speakers. My son has plugged his PS3 into it, and would like to use external speakers for his game(s). The soft buttons do not control the volume in any way that I can...
To adjust volume, press the down arrow on the lower right corner, to enter volume-setting mode. Then use the up arrow to raise the volume. I think you press the menu button when you are done, or the volume graphic might just go away after a minute.
Dec 02, 2010 | Computer Monitors
Speakers are not working. I do not have a manual for the product. I am assuming that the speakers are built in since there appears to be no input jack on the monitor into which speakers can be plugged.
So u are using this lcd monitor with ur pc? been trying to look it around and i really dont think this one have built in speakers, u need to plug ur speakers to ur pc, not to ur monitor.
Oct 31, 2009 | Proview PL713S 17" Flat Panel LCD Monitor
Liteview lm15w tft monitor model goes blank
It sounds like the port where the power cable plugs into is loose and shorting out. You may be able to dis-assemble the monitor and repair or replace the port. They are usually soldered in and the solder connection may have come loose. If it plus into the circuit board you might be able to fix the plug or tighten the screw if it is held by one.
Sep 27, 2009 | Dell E173FPb 17" TFT LCD Monitor
The laptop is widescreen at a guess. The external monitor is not. You need to change your laptop screen resolution to be something like 1280x1024, or, you need to tell the monitor to be a display EXTENSION not a mirror. Right click the desktop, properties, then Settings. Click on the 2nd screen, and set its resolution to 1024x768 or 1280x1024. It's here you would tell it to extend not mirror too.
Jul 12, 2009 | Star Logic 17" LCD Monitor
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
No sound from monitor speakers
The monitor must plug into the PC as the external speakers did.
Apr 16, 2008 | Westinghouse L1928NV Monitor
No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
make sure you hook up the third gree socket on back of monitor to PC that was my problem and solution to my model monitor LCD
Sep 17, 2007 | Liquid Video E15LCD1 15"
Installed new monitor, lost my sound
If your previous monitor had built in speakers and your new monitor does not you are going to have to purchase new speakers. If your new lcd monitor has an audio input you can purcahse a sterio mini jack cable for under $10 at any store that sells computer stuff (circuit city, best buy, walmart, target, etc). Simply plug one end into your monitor and the other end into your computers audio output jack (usually color coded green). Now of course if that monitor does not have built in speakers your only option is to purcahse a set of speakers for the computer. These usually start at around $15.
Aug 10, 2007 | LG Flatron MW-30LZ10 30" LCD Monitor
Computer Monitors Logo
152 people viewed this question
Top Acer Computer Monitors Experts
Steven Wander
Steven Wander
 Mike M
Mike M
Are you an Acer Computer Monitor Expert? Answer questions, earn points and help others
