Question about Diamond Multimedia S3 Trio 64 86c764x 9550 fa2354 Stealth 64 DRAM T PCI 2MB VGA Graphics Accelerator Video Card - v 2.09 - Expandable to 4MB
Sound not working on trio stealth g2 tablet
Volume all the way up and made sure volume on game is on
When i turn it on it says trio stealth g2 and stays there and won't turn the rest of the way on.
Perhaps the HARD RESET PROCESS can help you, Merrill. I've posted my suggestion as to how it's done HERE. ( http://www.fixya.com/support/t25341481-trio_stealth_new_when_power_goes ) , so you may findt that information useful.
I've had good success with HARD RESETTING when trying to correct errors like forgotten password, or forgotten lock-patterns. However, I've had a Trio Stealth G2 that displayed the SAME problem as yours, Merrill, and it would NOT respond to ANY attempts at resetting. I tried every combination I could : pressing volume down (-) and power; volume UP (+) and power; volume UP & DOWN (+ AND -) and power. It refused to boot. But since the case and the screens were in great shape, I went on Ebay and bought a Trio with a cracked screen, swapped the motherboard from THAT tablet and it worked perfectly.
Final caution, though: ask the Ebay seller to guareantee the physical condition of the ports and other controls on the unit before you buy it. Remember you need a working motherboard.
Best of luck to you, Merrill!
Mar 13, 2015 | Trio Stealth G2 7 inch Tablet with 8GB...
My trio stealth will not go pass the trio screen. How do I fix this?
hold your power and volume up at the same time when it comes on release power button wait 5 sec release volume button you will see sevral ways to restart i had to clear data and ues factory restart just follow promts worked for me
Dec 11, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
Why won't my trio stealth g2 tablet won't hard reset?
Does the device have a password lock on it.
If it does try removing this first, then attempt a hard reset.
You can access the engineers menu by holding the volume - button and then pressing the power button whilst turning it on.
Other than that the only other option is to reload the ROM with a flash utility.
But this is not for the faint hearted :-)
Aug 05, 2014 | Mach Speed Trio Stealth G2 Tablet -...
Where do i find an app to upload an external bluetooth keyboard to my trio stealth g2 tablet?
I have not seen this model listed with built in Bluetooth. You could add a USB bluetooth device and it should work. Usb keyboards and mice will work for sure.
Jun 09, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
How to reset a trio stealth g2
If you can power it on go into settings then backup and reset. This will reset tablet to the out of the box status. You will loose all of your data. If it will not power up, press power and volume up while booting till the screen comes on.Boot options will come up then reset. Be sure the tablet is fully charged.
May 28, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Why my trio stealth g2 wont turn on
If it isn't charged it will not turn on.
Make sure the charger is working. Use an AC/USB charger.
Other than that it's broken.
Use the extended warranty you purchased when you bought the tablet.
May 03, 2014 | Mach Speed Trio Stealth G2 Tablet -...
My trio stealth g2 hype 4gb tablet will not go pass the trio stealth g2 logo it just freezes up what can i do
Have you tried my old trick of pressing the on/off button and at the same time, press the volume+ button. Sounds like you have a screen freeze. hope it helps.
LindaSView
Apr 24, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Trio stealth g2 shows my internal storage space as "0", it won't let me download apps, or updates. I have reset my tablet several times (pwr down volume)... erased everything I could. I know my wifi is...
My daughters tablet did the same thing. After we had it for about 2 weeks. Called Trio tech support. Ended up having to send it to them and they sent me a new one.
Mar 17, 2014 | Mach Speed Trio Stealth G2 Tablet -...
How to restart a trio stealth G2
all that shows is trio stealth G2 when turned on it freezes I tried the reset button
Jan 07, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
Diamond Multimedia S3 Trio 64 86c764x 9550 fa2354 Stealth 64 DRAM T PCI 2MB VGA Graphics Accelerator Video Card - v 2.09 - Expandable to 4MB Logo
643 people viewed this question
Top Diamond Multimedia Computers & Internet Experts
David
David
Gareth Cockram
Gareth Cockram
Jason Harris
Jason Harris
Are you a Diamond Multimedia Computer and Internet Expert? Answer questions, earn points and help others
