Element tv wont turn
My element elchw420 element TV will not turn on... It had the red light, and that's it.. we have opened it up, there is nothing wrong with the buttons on the front,.. the capacitors are all fine, the fuse is fine.. there are no burn or scorched marks anywhere... there is seemingly nothing wrong with the tv, and we're running out of ideas as to what it might be... any ideas?
SOURCE: Samsung LCD TV doesn't power on, just blinks 5 times
After about 5 years the Samsung LCD televisions backlight fails which prevents the TV from coming on and the powerlight just flickers the backlight can be changed but it is often alot easier and cheaper to buy a new Television
Posted on Sep 23, 2009
tvtek
  • 1284 Answers
SOURCE: SSP-R4232 Plasma TV, blue light on, but tv wont turn on.
At this point it appears that your main board is probably bad. You most likely have a 5 volt scource going to the main board but its not powering up the set. The main board is part number BN94-00796A.
You might want to have a technician look at the TV to verify this as the issue before purchasing it. Please take a few moments to rate my answer. Thank you.
Posted on Nov 18, 2009
Testimonial: "I was extremely grateful to have a response in such a short amount of time, as soon as I replace the part that was suggested as bad to me, Ill post."
budmrtn
  • 11361 Answers
SOURCE: I have a Polaroid 4011-TLXB
Which power supply version does it use?
http://www.shopjimmy.com/catalogsearch/result/?q=Polaroid+4011-TLXB+
If it is made by FSP please let me know.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 18, 2010
  • 62 Answers
SOURCE: My 37LG10 TV has the
Most probably Flyback need replacment, all power source comes from flyback after switching power supply is turned on (in your case power supply works since your LED comes on)
Take to repair shop
Posted on Aug 22, 2011
spr1949
  • 1182 Answers
SOURCE: TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Posted on Jul 26, 2012
The tv wont turn on and the red led light is on?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 18, 2014 | Element Electronics ELDFT406 40" LCD TV...
Element tv wont turn on red light is on but wont power up
I had the same problem. The power supply board is bad and this is very common with this TV. I ordered a new power board from shopjimmy.com. The cost is $51.00 with shipping. Just open the back of the tv and you'll see the part number on the circuit board. It's easier to replace the whole board. You can also go on UTube and see a video on replacing the board. Very easy to do yourself. My tv hasn't had a problem since I replaced this board.
Apr 18, 2014 | Element ELC-HS321 32 in. LCD TV
Lighting ran in on my lg47lg50 tv now the red power light is on but the tv wont come on
The power board is cooked. consider another tv.. Consider using surge protection in future.
Apr 01, 2013 | Televison & Video
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
Tv wont turn on, just red light blinks
From the owner's manual of that model:
If a red light is blinking on the front of the TV, the set has entered protection mode. If this happens it usually means you simplyneed to reset the TV. Unplug the TV for 60 seconds. Then plug the TV in and try to switch it on. If the light is still blinking red,call the Customer Care Center at 1-800-531-0039
Dec 08, 2011 | Philips 55PL9524 55" Rear Projection...
My Element 40" Tv is stuck in stand by how do I
hi have you changed the batteries in the remote, if the remote is ok there's a fault with the tv, could be a swollen capacitors shorted diode or poor solder joint,or a bad mainboard , thanks
shaun
Mar 08, 2017 | Element ELCHW402 40 in. LCD HDTV
I have a Element 32" HDS LCD TV, movel ELEFLX3210. It won't tunr on, but has a red light that is on. The TV was purchased 09/09/2007. Do you know how to repair or address this? It's a $549 TV.
There were two runs of parts on this model, one using a powersupply board that included the inverter and one with a separate inverter. The red standby light failure was typical with the second run with the all in one power supply board. You can tell if you have the second run by opening the back. If the power supply board says proview and is black then you need to replace the board underneath it. The main board. This model also had a MASSIVE factory defect. If you hook up the VGA model, pin nine on the control box lead shorts out and it goes into limbo like you have now. So, replace your mainboard and Fill the vga input with hotglue. That should get you back and kicking again. Try shopjimmy.com or ebay for parts.
Good luck
Aug 01, 2009 | Element Electronics FLX3210 32 in. LCD TV
Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Jul 10, 2009 | Element Electronics FLX2211B 22 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
