How to connect ps2 to cello tv
I am trying to connect my ps2 to my cello combi tv but when I connect scart I am just getting no signal on my tv
5 Suggested Answers
  • 7 Answers
SOURCE: Connecting Sony PS2 to Panasonic HT32LZD85
First off you need to retire that ps2 and join the PS3 revolution, well worth the money although with the recent drop of the inferior x-box 360 the PS3 may follow suit shortly.
Now, I'm gathering from your discription limited as it may be that you had an adapter that connected the the stock cable that was included with your ps2 which consists of the end that interfaces with the ps2 and the end that is ment to provide the signal to your tv which includes your composite video (yellow) and your left and right audio (red&white).
If this is case then it should be a simple matter of removing the adapter that changed the source (ps2) signal to aerial and pluging the yellow red and white cables direct to your tv (standard imputs at the rear of the television should be video 1,2,3 ect.
Then just make sure your tv is on and set to the correct imput and you should be rockin and rolling in no time.
Posted on Oct 03, 2008
SOURCE: how do i connect dvd
use a scart switch box you can get automatic ones as well
Posted on Sep 10, 2010
geemarie
  • 876 Answers
SOURCE: Connected my DVD player to
Using the manual that came with your TV, recheck all of your connections. They are specifically marked for audio and video and have the connections for a number of components. I have a Sony Bravias and my audio cables are yellow on the end and the videos are red and white. What sort of TV Service do you have? Cable or Satellite. When you are wanting to use the DVD player, you have to change the input using the the input button on your remote to get an onscreen menu of all your components.If you have Satellite TV, you can use your Satellite remote to do this.
Let me know if this does not help. These are great TVS!
Posted on Dec 29, 2010
spr1949
  • 1182 Answers
SOURCE: connect tv box to plasma
Looks like there is a mismatch in the connections.
Posted on Aug 23, 2012
Technika tv/jvc combi player
SCART Cables come in two kinds 9 pin and 21 pin ensure you are using correct type in user manual. What other connections are available to you?
Jul 21, 2014 | Audio Technica Televison & Video
I have connected my jvc combi player to my tv via a scart cable. I then select the source button on my tv remote control and select scart. I can do and auto scan and it says completed, but no signal.
When using a scart cable, the TV should switch over to the Scart port that as last came active. Even when you switch on and choose the menu on the device, the TV should notice and switch over.
Just check if you are using a normal scary cable. Sometimes not really compatible cables with in / out switches, can spoil the fun, because not all wires are connected correct.
I have a Toshiba 3387DB TV and am trying to connect it to my laptop. Tried to use DVI (out of laptop) to RGB phonos cable. Then through a scart adapter into the Scart 1 socket at back of TV. Manual says...
You need to convert the component sync signals into a composite sync compatible with SCART. The red, green and blue signals can be connected through as-is.
Mar 21, 2011 | Toshiba 3387DB TV
The picture is blue when I play a dvd. I recently connected it to a new Vizio TV. The other tv it was connected to gave us a good picture.
Check your connections for faults, also some connections on TV's are for RGB inputs, so you might have to try another connector or if you can switch the DVD's output to RGB etc.
Apr 04, 2010 | GoVideo DVR4000 DVD Player/VCR
Why is my playstation 2 in black and white? I have changed av cables, different video inputs, also swapped dvd player with ps2 video inputs. The dvd player is still in color? is there something with the...
For me it sounds like the TV treats the incomming signal as a SVHS signal. I have had the same problem with a SEGA dreamcast back in the days. In my case it was a quite simple setting in one of the TV menus.
Try different video inputs. (and SCART adapters) This is also is a important step. Some older TV's doesn't have SVHS support at some of the SCART inputs, and in your case that will be a good thing.
But as you said, you maybe already have tried this.
Don't know if this was any help for you but i wish you good luck!
(Because PS2 is still really fun playing)
Oct 10, 2009 | Sony PlayStation 2 (PS2) Console
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Cello tv dvd
I own a ONE-FOR-ALL universal remote and my booklet says the setup codes for Emerson TV/DVD combos are 0675 or 1268.
Jun 30, 2008 | Emerson EWF2004 20" TV
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Video output from VHS recorder
does your television have multiple scart connectors? Sometimes some models have only 1 connector that will accept RGB signals... Another thing you can check are VCR settings - scart component video output is not "official" and hence you might need to look at some of the setting if you need to enable it. Another possibility is that your scart cable may not have your rgb signals connected (based on wikipedia reference: "not all SCART cables make use of all the pins, often leaving out RGB signals. In many cases there is also no way to see which type of signal that is currently displayed on the TV set."
May 05, 2007 | Zio Corporation CameraMate RealTime...
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
