Question about Husqvarna "RZ4621 46"" Briggs And Stratton 540cc 966659101 Zero Turn Riding lawn Mower 2012"
Throws belt & spring - Husqvarna "RZ4621 46"" Briggs And Stratton 540cc 966659101 Zero Turn Riding lawn Mower 2012"
Cub cadet SLT 1554 keeps throwing the drive belt
Double check the routing diagram. Check to make sure your idler pulleys are in good condition. Bearings are good. Lastly the tension spring may be worn. The belt should fit very snug. No more than 1 1/2" of deflection when you push on the belt with your thumb
Oct 15, 2012 | Garden
Toro 17-44 can't keep deck belt from coming off
is the deck adjusted level?is it the right belt?
Apr 23, 2012 | Garden
Lawn chief mower throws belt
does the belt feel tight when its on? i would look for belt alignment warn blade mandrels or rotted out deck and the belt tension pulls them apart
Apr 07, 2012 | Garden
Main pully loose and throwing belt. It started as squelling. Is this a replacable part?
Yes its called a belt tensioner its spring loaded and keeps the belt tight there about 25 dollars or so and are a common ware part .
Jan 17, 2011 | 2000 Pontiac Grand Am GT
The belt rides of the tension pully. Why? the pullies are not all in line. Is there a spring inside the tension pully & how do I get at it?
regardless of the v6 engine u have the belt tenioners r phenominal about going bad in mostly 2 ways one way is not retracting or bouncing back and second is they dont stay aligned when it is pulled down from excellerating and it throws the belt.
Oct 04, 2010 | 2000 Dodge Caravan
Looking for timing mark's for a 1997 camry with a 2.2 4cyl motor?
You find the timing marks on the picture below.
Removal
Remove auxiliary 1. drive belts.
2. Support engine.
Remove:
Engine mounting and bracket.
Timing belt upper cover [1].
3.
4. Turn crankshaft clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Remove:
Crankshaft pulley bolt [4].
Crankshaft pulley [5]. Use tool No.09213-60017.
5.
6. Ensure timing marks aligned [2] & [3].
7. Slacken tensioner bolt [6]. Move tensioner away from belt and lightly tighten bolt.
Remove:
Timing belt lower cover [7].
Crankshaft sprocket guide washer [9].
Timing belt.
Tensioner pulley.
Installation
Installation
1. Check tensioner pulley for smooth operation.
2. Check free length of tensioner spring is 46,0 mm [8]. Replace spring if necessary.
3. Fit tensioner and spring. Ensure spring is connected correctly.
4. tighten bolt [6].
5. Ensure timing marks aligned [2] & [3].
6. Fit timing belt. Ensure belt is taut between sprockets.
Install:
7.
8. Slacken tensioner bolt 1/2 turn [6].
9. Turn crankshaft two turns clockwise to TDC on No.1 cylinder. Ensure timing marks aligned [2] & [3].
Turn crankshaft slowly 1 7/8 turns clockwise until crankshaft pulley timing mark [3] aligned with 45° BTDC mark [10] on
timing belt lower cover [7].
10.
11. Tighten tensioner bolt [6]. Tightening torque: 42 Nm.
12. Install components in reverse order of removal.
13. Tighten crankshaft pulley bolt [4]. Tightening torque: 108 Nm.
Manufacturer: Toyota
Jun 25, 2010 | 1997 Toyota Camry
I have a Toro zero turn commercial 60" model 74272 which throws the deck belt as soon as the clutch is engaged. I have replaced every pulley, spacer, spring,etc, as well as a new belt. Also, everything is...
im no expert but had a similar problem with an old craftsman mower. the belt keeper which is an L shaped piece of hardware located at the back of the deck next to the idler pulley spindal. Also could be the deck is cockeyed and needs to be leveled or the wrong v-belt.
May 25, 2010 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Belt keep coming off cub cadet 1042, all parts on deck have been replaced with new parts & still the belt comes off every time
my cub cadet used to throw the cutter belt too....till i took the drastic step of adding a bit more tension to the belt. this was achieved by drilling another hole on either side of the chassis about 1 3/4 inches to the rearward of the machine and moving the lift arms to the new holes. Viola, more belt tension, and furthermore there is now no interference between the tensioner and the rearmost run of the belt.
Oct 22, 2009 | Garden
I have purchased Honda Activa 2 year before. There is regular services & oil changing. But the delear is confirmed that the Clutch Belt & spring is damaged & it needs to be replaced. Kindly...
Hi, recently even I have changed the clutch belt..according to workshop in charge it damaged due to some running problem...He also told that the average life is 20,000km..
Jul 27, 2009 | 2005 Honda Activa
Fitting new belt to Hotpoint9320w tumble dryer
Put belt around spindle then pull pulleys apart and rest onto belt.
I am assuming that the spring which holds the pulleys together is still in place.
Please post back if any further assistance needed.
Thankyou for using Fixya.
Jan 29, 2009 | Hotpoint TDL14 Electric Dryer
Husqvarna "RZ4621 46"" Briggs And Stratton 540cc 966659101 Zero Turn Riding lawn Mower 2012" Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
