Question about Sewing Machines
Need instruction manual for DAE WOO DDS 500 Industrial sewing machine
Just acquired this industrial sewing machine and I need instructions on loading the bobbin
SOURCE: I have a Consew 230
www.sewusa.com can provide a manual
Posted on Oct 09, 2008
SOURCE: Brother Industrial Machine Tension
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Posted on Nov 30, 2008
  • 5 Answers
SOURCE: Bobbin won't thread on my Broter DB2 B755-3
Manual here........
http://myweb.tiscali.co.uk/stitches/BROTHER-DB2-B755-MKIII-MANUAL.pdf
Posted on May 29, 2009
SOURCE: Need instruction manual for Consew 226R-1
Found manual on internet from company
Posted on Jan 04, 2010
SOURCE: Threading a consew RB-1 sewing machine
Send an email to me at dbjamie@msn.com and maybe I can help. I'd need more info. on your ploblem. I'll start you off with these two things assuming that your difficulty is with the bobbin as you state "underneath & threading". Notice the white painted dot on the the machine arm at the drive pully. Notice the white dot on the pully. Allign these two. Tilt the entire machine head back so that it is resting on the word verticle finger stop (or get underneath the machine). Bobbins are loaded by pulling the small chrome lever w/ your thumb & index finger (this is an unlocking latch). Do so moving it outward to about 90 degrees. Usually while you do this the holder and bobbin just pop out. To install u just snap then on. It's placed when u hear a click. For more info email me directly. Doug
Posted on Jun 18, 2010
My friend has an older industrial type Singer Model 211G156, Serial #PC27759. He needs instructions on loading the bobbin. Please send instructions or advise where to find them. Thanks!
Go to the Singer site and click Support. There is a section for Industrial machines there, and chances are he can download his instruction manual.
Feb 20, 2017 | Singer Sewing Machines
How to wind a bobbin on a singer model 2281B362
This sounds like an industrial machine. Go to the Singer website and click Support, then Industrial Product Support. They offer Parts Lists, Instruction Manuals and Service Manuals for industrial machines. If you can't get an instruction manual, you can often get a service manual.
Feb 16, 2017 | Singer Sewing Machines
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
I have a dae woo-500 sewing machine and has an oil pan. What kind of oil is recommended?
Sewing machines take a very light weight oil. I have found if you don't have access to wholesale distributors. You can find machine oil by the quart at Rochford supply, they have website. Hope this helps.
Apr 02, 2015 | Sewing Machines
Any information on chandler br-500-3 industrial sewing machines?
Ask Chandler direct. They are specialised machines. They have some manual on the site but not yours/
Chandler Machine USA
Sep 01, 2012 | Sewing Machines
Looking for my DDL-550 instruction manual
Industrial machines typically don't have an instru
ction manual like a home machine does. Go to Juki.co.jp and see if they can help you locate what you need.
Jul 18, 2012 | Juki Sewing Machines
Where can i get the instruction manual for my mitsubishi dy 340 industrial sewing machine please
There are two websites you can check. If they don't have the manual they can answer any questions you have. The first website is in Texas and their email is demasewing@yahoo.com or you can go to www.sewingindustrialmachines.com/mitsubishi. The second site is Ralph's Industrial Sewing Machines in Colorado and their toll free number is 800-525-0330. Both companies specialize in selling and fixing industrial machines so they should be able to help you. There is a site that sells manuals too that you can check but I'm not sure if they have the industrial manuals. Contact ron@a1sewingmachine.com in New York and check with him first. Hope this is helpful. Good luck and happy sewing!
Sep 16, 2010 | Sewing Machines
Obtain Juki Industrial User's Manual 8700-7
hi there
u can find at www.juki.com under industerial sewing machine
u can download DDL 8700-7 instruction manual
best regardes
ashraf abozid
aabozid@hotmail.com
May 23, 2010 | Juki DDL-8700
Jan 03, 2010 | Consew 226R-1
Sewing Machines Logo
64 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
