Question about Sony DCR-DVD301 DVD Camcorder
Power disconnected during finalization
Hello. I accidentally disconnected the power supply while a disc was finalizing, just as it began the process. The disc still has all the material and plays on the camcorder. Is there a way to continue the finalization process, such as starting on the second scene, so that it can be played in a dvd player, per usual? When I tried to go back to finalizing the normal way, it did not seem to work. Thank you!
  • jb220 Sep 02, 2007
    In the end, I found a solution myself. When you put the disc back in and record a little more material, you can then finalize the disc again, and therefore play it on a dvd player. At least in this case, no need for Norton's or complicated attempts to tranfer.
    jb220
    Champion:
  • 217 Answers
There's no way you can continue the finalization of the disc, the disc has been marked as finalized already, even a single power fluctuation when you are using ac power adaptor can affect the disc finalizing process, so it is better to use battery when disc finalizing
Posted on Aug 31, 2007
  • teofilo navarro
    teofilo navarro Aug 31, 2007
    You may recover the disc files using a recovery software installed in your computer, even a corrupted or unreadable disc can be recovered, Norton disc file recovery software is a good one, and there are many freeware compact disc file recovery softwares available in the internet.
  • teofilo navarro
    teofilo navarro Sep 03, 2007
    I assumed you have done that already, anyway in case you encountered a problem like what I Had in mind you know what to do now, ;0)
SOURCE:
I interrupted my finalization of the disc on my handycam and now can not continue
You can try data recovery software such as CDroller or "Bad CD DVD repair"
Or send it off to a mini dvd recovery company such as www.minidvdrepair.com
I used them in the past with great results. I believe I paid around $100
Jan 08, 2013 | Sony DCR-DVD610 DVD Handycam Camcorder...
Tried to record on a DVD-R disc, but unit said that the disc was full. I then tried to finalize the disc, but the unit got stuck in the finalization process. I unplugged/replugged the unit to make it...
The most likely reason the unit got 'stuck during finalisation' is probably because there was insufficent space left on the disc for it to write the respective lead-out/menu data (or perhaps there was a bad disc sector) - disc full? Because you unplugged the unit from power point before it had finished, the disc is possibly corrupted now. Throw that disc out.
The manual clearly warns: Do not disconnect the AC power supply cord while finalising. This
can render the disc unusable.
In other words, you have lost that particular recording and you are wasting your time with that disc.
There is nothing in the manual to suggest the length of time required for DVD-R recovery - there is a recovery process for the whole unit (such as after a power cut while recording a timer program for example) but not for discs. I may be wrong here...
However, the upshot is you have lost a disc, not a recorder. Another drink coaster for your living room.
Mar 29, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
After i have finish recording and i am finalizing the the cd code OPC appears on the screen, and being finalize the cannot play in other cd player why?
OPC means the unit had trouble Optical Processing Calibration, which means the disc surface may be damaged. Using brand name media and being careful to not touch the recording surface would help.
It's not completing the finalization so it won't play in a CD player yet.
It's mostly in the manual
http://www.retrevo.com/support/Harman-Kardon-CDR-20-CD-Players-manual/id/386dj191/t/2/
OPC: Stands for Optical Processing Calibration.
When you see this message in the Information
Display for the Record DeckK, it means
that the laser transport inside the unit is making
the calibrations and adjustments needed so that
the recording process is optimized for the specific
disc in use.
When an unfinalized CD-R or CD-RW disc is
placed in the Record Deck%, the letters
OPCwill flash once the Table of Contents has
been read. This indicates that the unit is optimizing
its circuits for maximum compatibility with
the specific recordable disc in use. the number
and total running time of any tracks that have
already been recorded will appear in the
Information DisplayK, and the appropriate
indicator SPwill light to tell you if a CD-R or
CD-RW disc is in use.
To Finalize a disc, place it in the Record
Drawer%. Once the disc's Table of Contents
information has been read and the OPC process
has been completed, press the Finalize button
[email protected] note that the Finalize Indicator
Uwill begin to flash. Within three seconds,
press the Select button9*and note that
the Finalize IndicatorUwill stop flashing.
The Finalization process will take up to two
minutes, depending on the length of material
recorded on the disc. During the Finalization
process the Record Deck will not accept any
operating commands.
Dec 29, 2010 | Harman Kardon CDR20 CD Player
Hi: Please i have the sony handycam model:dcr-dvd602e and i had recorded a whole disc with it ( 30 min.) then i finalize and it was completly finalized but after that or at the end of finalizing a message...
oops....something happened during the finalizing process and it failed. Hope you had a back-up in your computer of the disk. It doesn't need to be finalized to have it in the computer, just in case this happens. Looks like your disc got erased.
Oct 30, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Finalizing a dvd fails to complete function.
The power supply board on the DMR-E85H has problems. The earlier boards suffered from leaking capacitors and the later boards from voltage regulator problems. Go to the following links for details and photos on how to fix: Replacing capacitors:http://www.fixya.com/support/t216825-dvd_recorder_frozen_please_wait_display Replacing the voltage regulator:http://www.rbjtech.net/electrical/e85/e85.htm#0 Hope this helps. My machine had the same problem and has the later ps board. The voltage regulator replacement worked perfectly.
May 18, 2009 | Panasonic DMR-E85H DVD Recorder
Finalize disc does not appear on the menu of canon DC310
In order to Finalize you have to plug in the power adapter.
It took me forever to figure it out.
Jan 27, 2009 | Canon DC310 DVD Camcorder
DVD will not finalize
I have found that any disc faster than 4X will not finalize. 8x disc will record but not finalize. 16X disc will not even record. I haven't been able to find any D VD+R 4X. 4X disc work fine and will finalize if you can find any.
Mar 16, 2008 | RCA DRC8295 DVD Recorder/VCR Combo
Finalizing DVD
If you unplugged the recorder while this process was ongoing, it probably failed. You will need to record again.
Have a great day! :)
Nov 29, 2007 | Sony RDR-VX500 DVD Recorder/VCR
Finalzing my disc
you can only finalize a disc in the dc100 with the power adapter on. (page 59 instruction manual)
Aug 01, 2007 | Canon DC100 DVD Camcorder
Canon DC100 - Finalizing Problems
thanks I got it plug-in the camcord to the wall outlet with DC adapter then you can start the finalizing thanks again
Dec 30, 2006 | Canon DC100 DVD Camcorder
Sony DCR-DVD301 DVD Camcorder Logo
172 people viewed this question
Top Sony Video Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
