Question about Belkin Computers & Internet
Change subnet mask
Belkin router says the subnet mask numbers you entered are invalid when I change it to 255.255.252.0
Alex1413
SOURCE: Connecting Ipod touch 8(GB) to Wi-fi
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Posted on Nov 05, 2007
smeago1
  • 136 Answers
SOURCE: I cant log into my router even though I am using the 192.168.1.1 subnet mask
Go to run type in cmd a dos prompt will appear.
type in ipconfig /all and check your ip address. Chances are your ip address is 169.x.x.x which is an internal ipaddress. You will need to manually assign an ip address To do this go to my network click on view connections right mouse click the lan icon then go to the tcp/ip config and manually assign your ip address.
It needs to be the same subnet as your router so use 192.168.1.xx anything but 1 then you should be fine.
good luck
Posted on Jan 14, 2008
Sutibun
  • 186 Answers
SOURCE: Dual Router Configuration
Plug the second router into the lan not the wan and it will act as a switch instead of a router
Posted on Oct 02, 2008
SOURCE: Problem connecting Ipod touch to WiFi
What password are you entering on to the ipod touch?
Posted on Jan 05, 2009
  • 400 Answers
SOURCE: belkin54g default gateway problems and connecting to router page
reset your Router via pin whole at its back then set the config of TCP/4 and obtain Ip automaticaly and obtain DNS automaticaly... later set your settings according by 192.168.1.2 without changing IP and then turn off you router ... turn it on after 5 to 10 min .. thank you
Posted on Jun 24, 2009
I need the subnet mask number
go to your computer open command pad type ipconfig/all hit enter and look for your subnet will be the same for your xbox.
Oct 27, 2012 | Belkin Wireless Surf Router (F7D2301)
I have a newer newer belkin router but i hope you can still help me out,okay when i try to play a game on xbox live it won't let me because it says my NAT rating is closed,how do i set it to open?
Hello your Belkin Routers has a Firewall Feature on it which might be blocking you to Play games on your Xbox.
To Solve this Issue you Just have to open Ports on the Router For your Routers Ip Address or Enable DMZ ( De-militarized zone). Which will Open all the Ports on the router for an Ip address.
---> Steps to Enable DMZ on the Belkin Router
- Connect your Computer to the Router using an Ethernet Cable.
- Open Internet Browser & Goto 192.168.2.1 it will take you to Router Setup Page
- Towards your Left Pane Click DMZ Under Firewall
- Leave the Password Box Blank & Click Submit
- Check the Enable Box
- In the Private Ip Box Type in any Numbers in range of 2 - 254. EG: 192.168.2.9
- Click Apply Changes
- Unplug the Power Cable From the Router & Plug it back After 15 seconds
> Now Let us Assign the Ip Address on your Xbox
- In the Xbox Dashboard
- Go to My Xbox and Open System Settings
- Select Network Settings, Configure Network.
- On the Basic Settings tab, select IP Settings, then select Manual.
- Select IP Address, enter your chosen IP address EG: 192.168.2.9, and select Done.
- Select Subnet Mask, enter the Subnet mask 255.255.255.0, and select Done.
- Select Gateway, enter the Default gateway 192.168.2.1, and select Done.
- Select Done to save your settings.
- Go Ahead & Test your Connection.
Mar 13, 2011 | Belkin (F5D8231-4) Wireless Router...
I hooked my linksys E1000 Router to Samsung 3d TV (Wired), but the TV doesnot detect the internet speed, on my laptop (Wireless) is 144Mbps.
you may need to sign in manually,those tvs sometimes dont pick up dns addresses of routers automaticallty
plug in your cable into your laptop
go to start/accessories/command prompt
type in ipconfig
scroll up till you see ethernet
take down your ip4 address,itll look something like this xxx.xxx.xxx.xxx (change the last number to something in the range of 1-250) your subnet mask ad default gateway
plug back in your line to your tv,go to manual enter settings
enter in your ip (with the number changed at the end) your subnet mask and your default gateway number for your dns/gateway if required
if you need more help try customer service on the samsung american site,theyre really good at answering any quick email queries :)
Mar 07, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I can not get it to work at all. Is there a CD I need to get this set up? I have a Linksys wireless G router and the Belkin F5D7130 plugged in to it. But I have no range.
You don't need a CD - there is a web interface. First, download the user manual here.
I suspect your problem is the Linksys/Belkin combination. Linksys by default uses a subnet of 192.168.1.xxx while Belkin uses 192.168.2.xxx. With a subnet mask of 255.255.255.0 (the default for both), no communication would be possible between these two subnets. The "255" in each of those first three octets means they must match exactly.
Either move the Linksys to 192.168.2.xxx or the Belkin to 192.168.1.xxx (and keep the same subnet mask) OR you can change the subnet mask to a broader one (255.255.254.0) that allows the two different subnets to talk to each other. This subnet mask would have to be applied to both devices.
According to the manual, the default address of the Belkin is 192.168.2.254, which leads to your next problem - your PC probably can't connect to the Belkin device. Assuming your PC is configured for the Linksys subnet, the easiest way to communicate with the Belkin is to use a network cable directly linking your PC to the Belkin (may need to be a crossover cable) and manually set your PC's IP address to one in the same subnet as the Belkin, like for example 192.168.2.200 with a subnet mask of 255.255.255.0. Then you can open your web browser and point it to the Belkin default address, as outlined in the manual, and make whatever changes are required.
Feb 21, 2011 | Belkin F5D7130 And F5D7010 (Bundle)...
How to setup or enable wi fi from belkins to laptop wirelessly
  1. Connect the computer to one of the four LAN ports on your router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on "Use as Access Point" on the left-hand side of the opened page.
    Select Enable. This will give you the options to set the IP Address and Subnet mask for the router. These settings should match your existing network settings; by default the IP address will be set to 192.168.2.254 and the Subnet mask will be 255.255.255.0
Alternatively:
1. Click on LAN settings in the left hand menu.
2. When the LAN settings page opens you will make two changes.
Change the IP Address to something such as 192.168.2.47 or you can use 192.168.2.200. As long as the first three sets of numbers match your existing network, you will be fine.
3. Secondly you are going to disable or turn off the DHCP server.
4. Click the Apply Changes button.
Nov 11, 2010 | Belkin (F5D7633UK4A) Wireless Router
Belkin54g default gateway problems and connecting to router page
Jun 24, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Defualt gateway problems with belkin54g cannot connect
1. Click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
2. Right-click the network connection that you want to configure, and then click Properties.
3. On the General tab (for a local area connection), or the Networking tab (for all other connections), click Internet Protocol (TCP/IP), and then click Properties.
  1. Check the option which says use the following ip address and enter the ip address that you have forced in the belkin router, type the subnet mask 255.255.255.0 and enter the default gate way the ip address of the belkin router (ip address that you use to open Belkins page)
Jun 23, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
The subnet mask
To change you subnet mask, go to control panel. look for network settings. select your internet. Right-click and properties. Look for subnet mask options (Try TCP/IP) If your subnet mask settings arent on automatic, put it to auto, if they are on auto, manually type in 255.255.255.0 (That is what is supposed to be)
Mar 23, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
IP Address
Step 1 Open your web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin and the password is blank (nothing). Click OK. Step 3 Click on the Home tab then click LAN to the left. Step 4 Next to IP Address enter the new IP address. Next to Subnet Mask enter the correct subnet mask for the IP address entered. Enter a Local Domain Name if applicable. Step 5 Click Apply and then click Continue to save the settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
182 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
