JBL Northridge E150P Subwoofer Logo
A
Anonymous Posted on Jul 28, 2013
Fuse does my jbl northridge e series e150p have a fuse
I need JBL Eon One Compact power supply circuit diagram
The manual is here. There is no service information available anywhere.
https://adn.harmanpro.com/site_elements/resources/19929_1572546665/JBL_EON_ONE_Compact_User_Guide_original.pdf
Claim in their 3 year warranty if there is a fault with it.
Mailing Address: JBL Professional 8500 Balboa Blvd. Northridge, CA 91329 Shipping Address: JBL Professional 8500 Balboa Blvd., Dock 15 Northridge, CA 91329 (Do not return product to this address without first obtaining prior authorization from JBL)
Customer Service: Monday through Friday 8:00am - 5:00pm Pacific Coast Time in the U.S.A. (800) 8JBLPRO (800.852.5776)
www.jblproservice.com
On The World Wide Web: www.jblpro.com Professional Contacts, Outside the USA: Contact the JBL Professional Distributor in your area. A complete list of JBL Professional international distributors is provided at our U.S.A. website: www.jblpro.com
Product Registration: Register your product online at www.jblpro.com
Jbl E150P/230 blows fuses
My first guess is the filter capacitors in the output stage of your amplifier are history/worn out.Try a different amp to confirm.Otherwise disconnect the speaker wires and check that the impedance/ohms value is at or near the stated value,4 or 8 ohms.This measurement can be made with a cheap ten dollar VOM "volt/ohm/meter."
JBL speaker's woofer occasionally cuts out - tweeter still works.
Your driver has a damaged voice coil, you can either find a speaker repairer to replace the voice coil or find a replacement driver to fit.
JBL E250 went dead after making loud sound. Doesn't power on at all now. Bought it at Best Buy in October of 2006. Does'nt it have a 5-year warranty?
It could be a bad or bad capacitors. On the power board. Capacitors look like soda cans small soda cans. Good ones will have a flat top. Bad ones will have a biging top and sometimes fuilid sedimant leaking from them..
Jbl e80 no sound coming from tweeter
Sound like the tweeter is blown, take to local jbl agent for service.
Light sound
Switch the speakers over just to make certain it's not the amp. If still bad on the good channel, then the crossover (inside) might have developed a fault.
Jbl sub woofer
Has nothing to do with the signal or source - it is a failure of the turn on circuit - I repair this amp - can help if you find my add here or I am located on ebay as well. Juust do a search for We Repair JBL and find the model :)
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
