Question about Kodak EASYSHARE Z1485 IS Digital Camera
Dropped camera pink in background
Dropped camera now there is pink in the background when I go to take picture
Pictures are pink
Did you really drop the camera? because the pink could be caused by a misplaced lens. But you also should check if you did not change the strings to manual. Like manual White balance or scene. Try the camera in the automatic setting. Please check the type number you gave, because Nikon did not make a Coolpix 3200. And I think the S3200 is to new.
Feb 09, 2014 | Nikon Coolpix 3200 Digital Camera
Why am I getting a pink or purple haze when taking picture white or blue sky background.
1. Check the WB (White Balance) setting of the camera. Default is AUTO.
2. In certain environments it can be necessary to set the WB to another value.
Sep 18, 2010 | Olympus SP800UZ Digital Camera
Pink sky in background.
Try and use the SCN. Mode.
Bright light is never recommended for any pics.
Contact KODAK they might have more ideas or can arrange a repair for you if needed.
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 25, 2009 | Kodak EASYSHARE M1063 Digital Camera
Software and drivers are loaded, pictures blank
Use a separate card reader to download your pictures to a folder you create on your desktop.
Aug 30, 2009 | Cameras
Pink color background and on clothing in sunny shots using auto
That is typically a bad CCD sensor.
To start you can take out batteries for a couple of minutes , but I do not think that will solve the problem.
The CCD sensor is the optical device that captures light and generate the picture on a digital camera.
Whe it is faulty it must be replaced at a repair centre.
Canon covers the repair expenses for CCD sensor replacement , even when warranty is expired on several of their models.
Call manufacturer at the number listed on the user manual to get information, if your model is in Canon list you may have the repair done for free, otherwise get a quote on repair.
May 29, 2009 | Canon PowerShot A630 Digital Camera
PowerShot A80 can't take pictures
http://www.fixya.com/support/r1237608-canon_powershot_cameras_pink_black
It seems that this is a problem with some of the canon pwershot series.
Please check out the link above regarding the same.
Please rate this solutions and thanks for using FixYa!
Mar 08, 2009 | Canon PowerShot A80 Digital Camera
Pictures are green and pink
looks like the CCD (image recording chip) has quit working. There is a lot of information regarding this phenomenon available at this link http://www.imaging-resource.com/badccds.html . The problem was widespread and affected almost all camera manufacturers. It does appear that most affected cameras are in the 3-5 year old range. The problem seems to have been rectified within the industry.
Aug 30, 2008 | Kodak EasyShare C633 Digital Camera
Pictures are apearing in greens and pink
if you dropped it drop it again, thats what i did. i cant believed it work. fight fire with stupidity. drop it from the same altitude.
May 29, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Fuji Finex 800 camera
If it's pink/purple and "streaky", you have a bad CCD sensor. The only fix is replacement of the sensor. This is the main image capturing sensor in the camera. The situation is well documented on the web. It's usually the end of the camera, unless it's under warranty (or just a little past). Approaching Fuji's repair department can sometimes yield a sympathetic rep who'll have it fixed at no charge to you. If you are on the hook for the repair, expect to drop about $100 US.
Mar 23, 2008 | Fuji FinePix S5000 Digital Camera
Pictures appear with a pink background
I had the same problem with the Canon PowerShot S410. I called Canon and they said it was a known issue. They are going to send me a return, paid postage label and replace the sensor at no cost. Canon rocks!
Liz
Nov 11, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Kodak EASYSHARE Z1485 IS Digital Camera Logo
27 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
