Question about Vacuums
Conti aquarobot model CTI 200 how do i fix it
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
I need a lid clip for thermos grill 2 go part no. 11-6047-012-200 model no. 4656110
You can purchase them from this site: http://www.grillparts.com/thermos/
Jun 15, 2014 | Vacuums
Broken power cord inside Conti Twister vacuume. I cannot find how to open the motor to get at the broken cord.
without seeing it i can only guess.... but most motors require taking all the screws out of the vac and prying the halfs apart... sometimes you can get away with just doing the panel at the bottom by the hinge where the handle pivots( depending on model.... to get the motor itself apart.... if there arent any screws to take out tben youre prettymuch out of luck.... you need to see where its held togethrr and undo it.
Nov 08, 2013 | Vacuums
How do you open the motor of a conti twister wety/dry vacuume?
Sorry, but I've never heard of a contitwister wet/dry vac. If you can give me a better name and model I might be able to help, but I'm afraid the one you've listed is not valid.
How do you replace the bag on a Hoover Elite 200?
I had the same problem and just figured it out myself. Detach the clamp (attamched to the bag) from the handle. Then slide the bag out from the clamp either left or right. The cloth bag then opnes and you can replace the actual bag inside. Hope this helps.
Nov 11, 2009 | Vacuums
Clutch went bad after only 2 years
Try send to bestbuy in home service
Dyson Customer Service - 866-693-9766. Wty Info - Some models have 2 yr Parts & Labor and 5 yr warranty on product manufactured after 8/06
Aug 08, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
NEED CHARGER MOD:HHD20-200
I have same problem. Please post it if you find source of battery charger HHD-20-200.
Apr 18, 2009 | Vacuums
I have a Henry 200 and the red on/off switch is stuck in the on position can it be fixed
Well... It probably can't be fixed, but it can easily be replaced. Depending where you are, spares are usually readily available. If you need more guidance, please post here again, and I'll see what I can do to help. Good luck!
Mar 03, 2009 | Numatic HHR-200 Henry Hound Bagged...
Vacuums Logo
29 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
