Question about Lexmark Wheelwriter 1500 Typewriter
Characters fill in intermittently.
Characters fill in of have ink smear to the right of the character. Tried new type wheel, ribbon to no avail. Looks like the ribbon might be advancing at the same time as the hammer strikes the print wheel, dragging the ribbon across the paper. Happens with letters a, i, j more than any others.
  • 328 Answers
This is a common problem with old supplies stored in a humid environment. Try leaving ribbon in an air conditioned environment for a couple of days to see if it helps. Otherwise buy a new sealed ribbon to try. Also push the hammer buy hand and see if it moves in and out freely and quickly. If not, the hammer needs some lubricant and or adjusting.
Posted on Aug 31, 2007
IBM 1500 by Lexmark
If it is moving as the hammer is struck, then it's one of two things. Either the hammer is moving too slowly, or the ribbon is moving too quickly. Since this is a rather old machine, it seems more likely things would slow down than speed up. I'd check the hammer solenoid. See if it's dirty, or needs lubricated. I wish I could give you more advice on this, but I am not familiar with this specific model, and was unable to find any kind of service manual, or troubleshooting information for it.
Aug 30, 2007 | Lexmark Wheelwriter 1500 Typewriter
I have a Canon StarWriter 30 that I bought ~1995. I rarely use it, and have kept it in mint condition. I just tried to type something, and found that it's not printing the full characters; it's cutting...
Check that the hammer is striking the letters squarely, that the daisy wheel is firmly located in its holder , Check too that the patten has not moved up in its location. Check that the ribbon can still transfer a deposit across its entire width. (Look back at a used part of the ribbon to see the strike pattern).
Feb 10, 2011 | Office Equipment & Supplies
Hi I work in a restaurant and we have a Epson TM-U220A Model M188A printer. The last few days the printer has not been printing on the White receipt paper. We've tried replacing the ink and it doesn't do...
If this is the thermal head model, you will need to have the print head replaced. These were also sold under the Dell label, so finding a used replacement printer may be more economical. If it takes ribbons, you will need:
This printer needs a ribbon cassette to print receipts.
EPSON ribbon cassette, ERC-38 (B) (Life: 3,000,000 characters / Color: Black) EPSON ribbon cassette, ERC-38 (P) (Life: 4,000,000 characters / Color: Purple) EPSON ribbon cassette, ERC-38 (B/R) (Life: 1,500,000 characters / Color: Black)
(Life: 750,000 characters / Color: Red)
You can order replacement parts here:
Jan 08, 2011 | Epson TM-U220 Matrix Printer
I have a SC Wordsmith 250- It started having poor print quality, now only types vertical lines and strange symbols. Also the LCD display only shows partial and broken characters, although the characters on...
The printwheel may not snapped in properly and going to it's home position. . Keep will spin to its home position when installed properly, providing its not broken or bent. The other problem may be the ribbon may have a bind in it or be out of ribbon. There is a wheel or hole on the ribbon to mover to tightened it up. try that
Sep 08, 2009 | Smith Corona Office Equipment & Supplies
New ribbon and can't get it to type
did you make sure that the end pieces are engaged into the brackets in the part facing you. Also if the correction tape is not loaded onto the ribbon prior to installing it, it will do that too.
Hope this helps, Denise
Aug 19, 2009 | IBM Office Equipment & Supplies
Characters do not print.
The print solenoid plunger has a plastic cap on the end of the plunger it is probably broken. They are available but you need a bit of mechanical ability to install.
Mar 18, 2009 | IBM Office Equipment & Supplies
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
IBM 1500 by Lexmark
It sounds to me like the impression is to heavy try holding the code key down and pressing the "Q" key until the "1" light is lit.
Lexmark Wheelwriter 1500 Typewriter Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
