Question about Locks & Locksmithing
Deadlatch installation gone wrong, how do i remove the interior casing from the mounting plate?
A failed installation of a Lockwood 001 Double Cylinder Deadlatch resulted in the outer key being stuck in the barrel and the inside casing is locked in place and cannot be removed (after the screws have been taken out). Can someone please give me a method of removing the interior side casing so that I can correctly install the Deadlatch?
  • 3 Answers
SOURCE: sperating the case
You must also remember to remove the logosticker at the front bottom. (Try sliding a sharp blade under it so you don't destroy it or remove all the glue located on the back of the sticker). There is 2 screws located underneath this sticker. When you've removed all 4 screws you should be able to remove the front cover by using i.e a hard plastic guitarplectrum.
Posted on Sep 04, 2007
alicantecoli
  • 22156 Answers
SOURCE: 1993 nissan maxima drivers door lock cylinder
you have made a boo boo somewhere,are you a certified city and guilds technician,if not then you shouldnt be repairing customers cars
Posted on Dec 20, 2008
  • 36 Answers
SOURCE: Want to remove the ignition lock cylinder since a broken key is stuck inside.
get a phillipshead un do about 4 screws from underneath plastic cover which hides steering colume. remove cover you will see white plug on the left hand side of ignition barrel disconect.then right hand side there will be acable disconect.now get a small chissel and anti clockwise tap bolts which have no heads on them that are on top of steering colume when they are alittle bit lose use plyers its easier pull bolts out clamp will then come of and then you can pull whole ignition of. now there is 2 brass pins which hold barrel in ignition up near the key end remove and barrel will come out but it might be easier to take whole ignition to locksmith and get them to do it and get new key for around 30 bucks i did a mates about couple months ago seeya orangepeel.
Posted on May 26, 2009
ourhowse
  • 2007 Answers
SOURCE: Ignition Lock cylinder set removal
Then you either got the wrong bolt, or the knob part is still in the hole. Take a close look at the bolt you took out, and see if something may have broken off it. If it did, you might be able to get the rest out with a magnet. There is a threadless part on the end of the bolt that's about an inch long. It goes down against the tumbler and hold it in there. The newer ones are a torx head, but i can't remember if 78 is or not.
Posted on Jun 02, 2009
  • 8404 Answers
SOURCE: Single cylinder dead bolt only works with key
You are 180 degreees out of sync with the other side of the bolt. Take it apart and move your key 180 degrees and reassemble and try it. Im 51% sure this is your trouble
thanks for posting at FixYa.com
Please vote
thanks
a
Posted on Nov 15, 2009
How do I change the code on a lockwood digital door lock 530
First determine the code you want to use; find the tweezers and spare red and blue tumblers if you are going to change the length of your code. The factory-set code is 5 digits. You can only use each key once and the C key cannot be included in your 4-6 digit long code. Next you need to disassemble the lock with the lock kept horizontal during the recoding process. If the lock has been installed, you need to uninstall it from the door. Remove the two mounting screws from the interior face plate. Then separate the exterior section from the spindle connecting it to the interior face plate. If the lock has not been installed or the previous step is done, remove the adapter plate from the back of the digital lock (exterior plate) if it is fitted on the unit. Next remove the four red screws that hold the back plate onto the lock and remove the backplate. Press and hold the C button at the lower left (as viewed from the back where the tumblers are) below the most of the other keys on the faceplate. With the tweezers, remove tumblers and put a red tumbler in the spots corresponding to your new code. Put a blue tumbler in the all of the other spots. Make sure that the color side is up and that the square cutout is facing the side of the lock. (Thus on the right side keys, the square cut faces right and on the left keys, it faces to the left.) When all of the tumblers are in place, release the C button. Test your code and check that it works after replacing the backplate and adapter plate but before putting the lock on the door. Save the tweezers and additional tumblers for future code changes.
The directions for resetting the code on any Lockwood Digital Lock are provided in the service manual here: http://www.lockweb.com.au/Local/AU/Technical%20Downloads/Lockwood/Mechanical%20Digital%20Locks/530%20Digital%20DX/Lockwood%20DX%20Digital%20Service%20Manual.pdf . Other details for the lock installation are available here: http://www.lockweb.com.au/en/site/lockweb/Lockwood-Products/?productId=948353 .
I hope this helps.
Dec 04, 2014 | Locks & Locksmithing
Trying to install instant cake from ISO cd to new hd
Are you mounting the CD properly? Here are easy to follow directions on mounting an ISO without burning the file. How to Mount Unmount ISO images on Linux and Unix Systems
(Double-check that you've made your CD your boot drive in your BIOS, unless you've got a PATA system, in which case make sure you've got the jumpers and cables set correctly) If you need help with either of these, please ask for additional instructions.
Mar 16, 2014 | Computers & Internet
My gateway profile 4 all in one has a totally white screen with no display. Rebooted with normal
before thinking about replacing the video card
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
if you need to replace the video card it will be attached to the rear of the vga lead inside your computer usually in a pga slot
Remove your computer's cables.
Turn your computer around so the back faces you.
Remove the two screws on the computer holding the right side of your computer to the case.
On many models of gateway computers, you only need to remove the screws with your hand. Remove the right side of the case to expose the interior.
Unscrew the metal plate of your old graphics card holding it to your computer's case. Remove the card by sliding it out of the motherboard.
Slide your new graphics card into the slot from where you removed the old one. Screw the metal plate to your computer's case.
Reassemble your computer and connect its cables
hope this helps
Aug 02, 2012 | Gateway Profile 4 All In One (MPN...
A lockout occured on my kaba 1000 series lock (I suspect the dead latch has slip[ped into the strike plate. I need to open the door, what can I do?
if your think the deadlatch has slipped into the strike plate ( which is a very common problem ) -- when you press in the code on the lock - push or pull the door ( depending on in-swing or out-swing ) and try and relieve the pressure on the strike. as soon as the door is open adjust the strike so this does not happen again. if there is no room for strike adjustment you can get and install small door bumpers on the door jam to keep the latch from going to far.
c...
Jan 19, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Need a copy of the manual pages, showing how to replace the clutch
Removal & Installation To Remove:
  1. Remove the transmission.
  2. Install a flywheel locking tool.
  3. Remove the pressure plate mounting bolts from the flywheel.
  4. Remove the pressure plate and clutch disc.
To Install:
  1. Insert a clutch disc alignment tool through the disc splines and into the flywheel pilot bearing. Pressure plate balance mark location subaru-07-00-6722.gif
  2. Install the pressure plate on the flywheel with a gap of 120° or more between the "0" balance marks on the flywheel and pressure plate. Hand tighten the pressure plate mounting bolts.
  3. Tighten the pressure plate mounting bolts using a crisscross pattern 12 ft-lb (16 Nm).
  4. Remove the clutch disc alignment tool.
  5. Install the transmission.
Dec 28, 2010 | 1998 Subaru Legacy
Trying to remove an old GE Spacemaker microwave JVM140-001 and can't figure out how to detach it. I do not have a manual or installation instructions.
On some of these old GE Spacemaker models, there are two long horizontal bolts at the top (R&L corners), accessed behind the upper grill. Remove the grill (four tiny screws), take out the two bolts (flat screw heads) that attach to the rear plate, and your microwave will come right down and out, providing you've removed the three mounting bolts on the top.
Dec 11, 2010 | General Electric Microwave Oven
How to get the half shaft out
Halfshaft -sorry but the diagrams didn't paste into the fixya.com window, just the text. Also, this was for a 3.2L engine.
REMOVAL & INSTALLATION
  1. Before servicing the vehicle, refer to the precautions in the beginning of
    this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Front wheel
    • Radiator skid plate
    • Transfer case skid plate
    • Brake calipers and mounting bracket
    • Brake rotor
    • Wheel speed sensor
    • Steering knuckle
  3. Support the axle housing with a jack. Unbolt the axle mounting bracket and
    remove the halfshaft/bracket assembly.
    To install:
  4. Install or connect the following:
    • Axle/bracket assembly. Tighten the bracket flange bolts to 85 ft. lbs. (116
      Nm) and the bracket mounting bolts to 112 ft. lbs. (152 Nm).
    • Steering knuckle
    • Brake rotor
    • Brake caliper and mounting bracket. Tighten the bracket bolts to 115 ft.
      lbs. (155 Nm).
    • Transfer case skid plate. Tighten the bolts to 27 ft. lbs. (37 Nm).
    • Radiator skid plate. Tighten the bolts to 58 ft. lbs. (78 Nm).
    • Front wheel
  5. Check the wheel alignment and adjust as necessary.
    Fig. 1: Exploded view of the left halfshaft, axle shaft and
    axle disconnect
    Fig. 2: Exploded view of the right halfshaft and mounting
    bracket
Oct 31, 2010 | 2002 Isuzu Rodeo Sport
Removal of front right axle from a jaguar 2002 x-type
Loosen the wheel hub nut.
Remove the front road wheel and tire.
Remove the tie rod end retaining nut.
Using the special tool 204-192 Ball joint Splitter
detach the tie rod end.
Remove the subframe reinforcement plate retaining bolts.
Loosen the subframe rear mount bolt.
Loosen the subframe front mount bolt.
Remove and discard the wheel hub nut.
using spcial tools 204-269Forcing Screw,205-491-01 adapter nuts,205-491 wheel hub puller
Detach the wheel knuckle.
Remove the lower arm ball joint retaining bolt.
Reposition the lower arm.
using special tools 307-443 RH Halfshaft splitter ,307-442 RH Halfshaft splitter handle
detach the halfshaft.
Remove the exhaust muffler inlet pipe.
Remove the halfshaft seal.
Remove the transfer case Y bracket retaining bolt.
To prevent damage to the transfer box internal seal,
make sure that the link shaft is not retracted further than
200 mm from the transfer box casing.
remove the halfshaft.
Attach special tools to the halfshaft.
Lever the special tools to displace the halfshaft.
Install the transfer case Y bracket retaining bolt.
Remove the halfshaft.
Use suitable protective covers to protect the barshaft.
Remove the halfshaft snap ring.
Install a new snap ring to the halfshaft.
Install a new halfshaft seal.
Remove the special tool.
Make sure the CV joint splines are located fully.
Do not use excessive force when engaging the CV joint into the link shaft.
Install the halfshaft.
Tighten to 25 Nm.
Attach the wheel knuckle.
Install the lower arm ball joint retaining bolt.
Tighten to 83 Nm.
Install the exhaust muffler inlet pipe.
Tighten the subframe front mount retaining bolt.
Tighten to 142 Nm.
Loosely install the subframe rear mount retaining bolt.
Install the subframe reinforcement plate retaining bolts.
Tighten to 35 Nm. Tighten to 142 Nm.
Install the tie rod end.
Tighten to 35 Nm.
Loosely install a new wheel hub nut.
Install the front road wheel and tire.
Tighten the wheel hub nut.
Tighten to 330 Nm.
Check the subframe alignment.
May 20, 2010 | 2002 Jaguar X-Type
Kia Sedona rear os Shock 2.9TD 2001 is it easy to replace?
this job is easy enough the 4 bolts hold shock mounting plate undo plate with shock .attatched remove from car as you will probebly have to cut old shock to separate from plate due .to nuts being corroded on top of shock
Jan 31, 2010 | 2002 Kia Sedona
Olevia 42" model # 542bl
Facing the back of television, if it occured while putting top right screw, that is because, you screw touched power module casing and the fuse inside the TV is gone. All you need to do is goto radio shack or any local store and get a replacement fuse (250v x 5 Amp) and replace it. It may cost you less than 2 bucks.
Symptoms:
TV powers off and never turns on.
May even power in that room or house may have been tripped.
Resolution:
lay the TV face down on the floor.
Remove the screwes ( may be 10 - 15 screws)
Remove rear casing of the TV. It is single casing covering entire rear face of the TV.
Fuse is visibe as soon as you remove the casing.
Replace the fuse.
Put the casing back.
Start enjoying the TV.
Prevention:
Do not use longer screwes to mount monitor brackets on TV casing.
GOOD LUCK!!!
Sep 17, 2008 | Olevia LT42HVi 42 in. LCD Television
Locks & Locksmithing Logo
67 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
