Question about KLH Audio Systems R-3100 Receiver 5.1 Surround Sound Sub-woofer Speakers
What size fuse for KLH 01H73 - KLH Audio Systems R-3100 Receiver 5.1 Surround Sound Sub-woofer Speakers
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
What size is the fuse to the power cord
Hi, you must check the user guide to find fuse rating or check the blowed fuse for current rating, for a DVD/Bluray player it could be about 2A /120V AC..
Jul 08, 2015 | KLH Televison & Video
Klh subwoofer keeps blowing it's fuse.
Most likely the amp in the sub has blown. It will need repair or replacement. I'd take it to an expert in repairing amps, it's not a job for you unless you're experienced in troubleshooting these things.
Dec 31, 2014 | KLH Audio Players & Recorders
Blown subwoofer fuse..
Well, it should state in the manual what the replacement fuse is.
There might be a fuse holder near the pwr. plug. , Or near the controls for it. If not....
You might have to open up the sub unit ....and find the blown fuse, and remove it to see what you have. Be sure to unplug the unit before opening it up.
Take the fuse to Radio Shack, or your local electronics supplies stores. Replace with the same, or the correct fuse.
Apr 06, 2010 | KLH (AT2100) System
Cant find fuse 5s2a250v
its a 2 amp, 250 volt, slo blo. Very common. Get the correct size.
Feb 09, 2010 | KLH ASW10-120 Subwoofer
Line fuse rating?
usually fuses have voltage and current ratings mark on them you just have to look for it or sometimes near the fuse housing.or you can use the formula power consumption of the unit divided by the voltage rating of the unit. I (amp) = Power(watts) divided by Voltage(110V) X power factor(PF). use 0.866 for PF
Feb 02, 2010 | KLH Audio Players & Recorders
Klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Apr 26, 2009 | KLH BB-II Subwoofer
Fuse blows when powered on . KLH E-10DAW
Hi, you can get the fuse at Polk Audio. 800-377-7655. You can talk to technical, too.
Jan 20, 2009 | KLH Audio Players & Recorders
Blown fuse
Buy at Radio Shack. 1.99
1.5A 250V 3.6x10mm Fast-Acting Ceramic Fuse
Apr 06, 2008 | KLH KL2400 Tuner
KLH Audio Systems R-3100 Receiver 5.1 Surround Sound Sub-woofer Speakers Logo
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
