Question about D-Link DIR-865L Cloud Router 5700 Wireless AC1750 Dual-Band Gigabit
Dir-865L No wireless connection?
Main computer hard wired into the router (using WIN 7 64bit).. can not get my laptop also using Win 7 64 bit does not even see the router in a list to connect to, same for wireless Kodak Hero 7.1 printer Wireless is enabled .. Is it not working or is there a configuration problem?...
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 30 Answers
Did You Run The Disc?
Posted on Aug 02, 2014
  • 21 Answers
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Posted on Jan 26, 2008
rtrahan
  • 741 Answers
SOURCE: Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Posted on May 03, 2009
kamal1984
  • 1383 Answers
SOURCE: Hi. I just configured a DLink DIR-300 wireless
First you have to check on your laptop that your wi fi network drivers are installed correctly.
Also check it is enabled.
Also check wi fi switch on laptop is turn on.
Check its ip addreses and subnet amsk and gateway is proeprly.
Posted on Aug 19, 2009
Testimonial: "Hey KAMAL1984. Thanks for your quick tips. I went through them 1 by 1 and here I am .. on my bed with my n/w connection. Thanks a lot!!!"
  • 72 Answers
SOURCE: Have connected wireless router dir 615 and 2pc's
whether that wireless adapter is supported to dir 615.
If suppose use mismatch adapter then you will get only poor signal
Posted on Jan 20, 2010
fbibeau
  • 66 Answers
SOURCE: I cannot connect my Wii to the internet via new
Are you able to connect using a regular laptop? If so, your connection is fine.
I suggest you try Nintendo's Wireless Router Troubleshooting procedure here : http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterTroubleshooting.jsp
Hope this helped.
Please rate :)
Posted on Mar 02, 2011
HOW TO ADD WIN 8 64 BIT WITH ACTUAL WIN 7 PRO 64 BIT ON MY LAPTOP TOSHIBAT
just make another partition on the hard drive and install windows 8 on to it.
Mar 23, 2014 | Computers & Internet
Limited connectivity
Limited connectivity (this phrase occurs first inside the WIN 8 OS) means, that you have connection with your router already, but NOT to the internet. Pls. check, if you have access to internet from other computers or smartphone connected via the same router.
If so, sometimes a driver-update for your D-Link could be useful.
Check also, if other wireless adapters are working with the same frequency, this may disturb. Try to change the channel or change from 2,4 GHz to the 5 GHz Channels, if the router & your D-Link Adapter will support this.
I had the same problem with my WIN 8 - PC and I had to change the (wireless) radio-channel.
Aug 15, 2013 | D-Link D Link Dir 825 Xtreme Dual Band...
My Dir 615 router always looses internet connection to my wired computer
Try to upgrade the routers firmware.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
Jul 19, 2013 | D-Link Computers & Internet
Wifi connection
Do you need a password? In Network and Sharing go to Manage Wireless Networks, Do you se your SSID for your wireless access point? Hightlight and remove, reboot your laptop, you will have to choose your SSID and re-enter your password. If that fails do a cold start on your laptop: unplug, remove battery, hold on/off button 10 seconds, replace battery, plug in start normally.
Nov 09, 2012 | D-Link DIR-615 Wireless Router
I have a belkin wireless G notebook card for my laptop. Yesterday I installed windows 7 and now I can not get my wireless card to work. Is there anything I can do or do I have to get a new one. Thank...
Make sure you have the proper drivers. Win 7 needs different drivers than Win XP and sometimes different even than Win Vista. Also make sure if you have Win 7 64 bit you are using the 64 bit drivers for your device.
Nov 01, 2010 | Computers & Internet
I keep losing my network connection with my D-link WBR 2310
Try upgrading the Routers firmware settings, before you do that make sure that you take down the settings , as you will have to resetup your network .
Feb 04, 2010 | Computers & Internet
Lost all connectivity. 3 computer setup has worked for over a year. 1-Vista Ultimate 64 Bit hard wired, 1 Vista HP 64 Bit wireless, 1 XP SP2 32 bit wireless. Shut down one night, next night could not...
so when you connect the speedstream mode to the computer , it works.
But when you connect the router , it doesn't work.
That means you will need to set up the router again.
Click here to know more about the routers
Oct 27, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My wireless hp says router cannot find host name
Double check your physical connection. It should be this way
Modem > connected to Internet Port of the router
PC > connected to port 1
Laptop > can be wireless
Now you must power cycle your router and modem. Turn off router first then modem. Wait for 30 seconds. Power on modem first, then the router. You must configure the wireless settings on your laptop it doesn't connect automatically.
Jun 14, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wireless security not working on my D-Link DIR-655
- Log on to the configuration page of the router
- Go to Manual Wireless Network Setup
- And Change the Channel width to different one
Jan 12, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Cannot connect a second pc
Are you connecting the machine that doesnt work wired or wireless??
Do you know what wireless card you have if it is wireless?
Dec 26, 2007 | Linksys Wireless-G WRT54GS Router...
D-Link DIR-865L Cloud Router 5700 Wireless AC1750 Dual-Band Gigabit Logo
89 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
