Question about Tools & Hardware - Others
How to fit planer blades to bosch pho 2-82 - Tools & Hardware - Others
2 Suggested Answers
  • 298 Answers
SOURCE: how to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Posted on Dec 21, 2010
Where to buy performax planer blades for model 90230
try a quality tool shop or saw /tool sharpener shop
most planer blades are generic and fit a range of planers
the only thing that varies on some is the method of attaching the blades
take an old one as a sample
Dec 31, 2016 | Crafts & Hobbies
The roller for the planer blade is stuck
Turn Off the device.
>> Remove the blade and set for correct hight and place.
Mar 29, 2014 | Bosch 3365 5amp Planer
How to fit bosch PHO 15-82 planer base plate
my 15-82 has only one blade.There is a plate with three allen bolts to undo.Under that are two more allen key bolts to to undo.The blade moves although these two bolts are tight.The plane when looking at the drum has 6 inline holes.
Dec 17, 2012 | Bosch Tools & Hardware - Others
How do I change the blade on a 3365 planer
Page 7 of this manual describes how to replace blades:
https://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D//t10/0000000/r00143v-1.pdf
Feb 21, 2011 | Bosch 3365 5amp Planer
I am trying to change the blade on my Bosch PHO1 planer. I have taken out the two grub screws holding it but it won't release - any ideas?
If the blades are hard to remove, you will have to remove the blade clamp completely in order to clean everything up. Your blades are probably gummed up from use. If you have a small torch available, you may want to try heating it up a little, this will release the blade (if you are using HSS blades). Be carefull not to melt any plastic in the surrounding areas. If you are using the micro carbide blades you should be able to press the blades out from the side using a scrap piece of wood without removing the screws (just loosen). Use mineral spirits or lacquer thinner or alcohol to clean all surfaces so your new blades will seat properly.
Oct 09, 2009 | Bosch 1594K 3 1/4" X 3/32" Planer Kit with...
How to fit bosch PHO 15-82 planer blades
Sep 16, 2009 | Bosch Tools & Hardware - Others
FITTING DETAILS FOR MAKITA PLANER BLADES
It depends on the planer blade set that you are using. If you are using the the 2 sided blades there is a guage that goes with it to set the blade depth before installing. I would strongly recommend that you go to Makitatools.com and type in your model number and download a copy of the owners manual for specific instructions. Let me know if you have any problems finding them
Mar 08, 2009 | Makita Planer Replacement Blade, 3 1/4"
Tools & Hardware - Others Logo
256 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
