Sony dsr 25 error code c3125 - Televison & Video
5 Suggested Answers
  • 4 Answers
SOURCE: Sony DSR 45P error code C3125
Press the power butten several times while holding down the eject button. It will solve your problem and clear the error. If it not then there is something wrong with your reel motor or the circuitery which deals the reel motor. You must consult your nearby sony service center.
Rajab Ali
Posted on Sep 08, 2009
  • 10 Answers
SOURCE: Sony DSR 25, error code C3140. Any advise
FG fault when starting drum.
It’s very possible that you have a bad drum motor.
Posted on Mar 22, 2010
pemring
  • 53 Answers
error C3125 is cause by SE board and tape jam.So what u do is cake the 3 main cable going from Compartment to VE board.if u had open them.That is main problem.
Posted on Mar 25, 2011
My Sony model DSR-25 Videocassette Recorder will not play any tapes right now, due to a C3140 error. It occurred the other day when a tape I inserted was sticking. Does someone actually know what this error really means ?
Posted on Aug 11, 2011
Always look for a tiny hole (in the back) that reads RESET. If none exists, maybe a push on a DISPLAY button? Try combinations (pressing simultaneously) - you cant break anything!
Nov 13, 2013 | Televison & Video
Error codes c 31 70 of sony dsr 45ap
U can do one thing check the switch at the front of DSR is in remote or not. If it is not then.Then press the reset switch is just below the the LCD. or Press eject button with pressing power supply .
Jun 27, 2013 | Sony DSR-45 Mini DV VCR
How do you use free run on a DSR-25 Sony Deck?
Read chapter 3 (time code) of your users manual. It outlines the settings for using time code; "free run" means that the time code advances all the time, not just during recording.
Feb 24, 2010 | Sony DSR-25 Mini DV VCR
Sony DSR 25, error code C3140. Any advise. Only comes up when tape is inserted.
Dec 27, 2009 | Sony DSR-25 Mini DV VCR
Sony dsr-25 switches on, goes into stand-by, then won't start up
There is a "Key INH" button on the front. You want to turn it to "off".
Sep 08, 2009 | Sony DSR-25 Mini DV VCR
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
Jul 24, 2009 | Sony Dvcam DSR-390P DV Digital Camcorder
Rajab Ali
Mar 08, 2009 | Sony DSR-45P DV / Mini DV VCR
Sony DSR error code C31:30 & C31:23
Error codes definitions are bit technical and as follows...
C:31:30 error code shows problem of No FG signal when starting capstan motor.
C:31:23 error code shows problem of No S reel signal to system control.
Above info were taken from service manual and picture of service manual can be seen below...
Need further info, let me know.
Oct 28, 2008 | Sony DSR-45 Mini DV VCR
Tape is not threading
Hello optasia,
Check to see if the gear or wheel is engaging the capstan.
This more then likely is your problem.
I hope this helps,
Thank you,
Shuttle83
Mar 07, 2008 | Sony DSR-45 Mini DV VCR
DSR 25
C:31:23 on a DSR-25 indicates a supply reel problem, most likely caused by a defective cassette housing. Best repair solution is to send it to an authorized Sony repair center.
Feb 26, 2008 | Sony DSR-25 Mini DV VCR
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
