Question about Refrigerators
We have several GE AZ22E09D3BM2 units and we have excessive condensation water dripping on the floors ???
2 Suggested Answers
SOURCE: water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Posted on Jul 09, 2010
My Window unit A/C has started leaking at the bottom onto my window seal and hard wood floors. I have this A?C for about 5 years and this has never happened before?? Any Sugestions???
Condensation of water on the evaporator coils in the front of an air conditioner is normal. This water collects in a pan where it is evaporated. On a really humid day, you may notice some is dripping off the unit. A properly installed unit will be tipped slightly back to allow any excess water to drip out the back.
Aug 05, 2008 | Heating & Cooling
Unit is leaking water from somewhere
Upper drip pan drains clogged, water overflowing onto the floor.
Remove the rear cover of the unit and clean it thoroughly wit a vacuum. Let the unit fully defrost. Use a can of Air duster (for pc's) with the little hose on to clear the drain holes in the upper drip tray. Clean dirty evaporator fins with windex and toothbrush, flush with water. Excess condensate should now drain into the bottom tank instead of overflowing ontot he ground. Be sure to drain the bottom tank thoroughly. With the unit cleaned it should now vent condensate out the warm air duct rather than letting it build up in the unit.
Jul 06, 2012 | Windchaser PAC9 Air Conditioner
We have a GE Profile fridge (counter depth). There is nothing in the manual that even mentions the "Sealed Pan" at the bottom of the cooling compartment. What is its purpose and how is it...
Just as the air conditioner in your car drips water that condenses, a refridgerator does also. But instead of allowing it to just drip on the floor it is diverted to pan below the unit that sits on top of coils that is hot and evaporates the water.
Jan 21, 2011 | GE Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water dripping from underneath
The water is most likely coming from the condensation that's drained out of the refrigerator during the automatic defrost cycle.
Be sure the bottom fan is running and clean out the condensation tray. Warm air pulled across the condenser coils is supposed to evaporate the condensate water. If the fan is not running when the refrigerator cycles on, replace it. This would also result in the refrigerator running excessively without cycling off.
While you're working under the unit, be sure to clean off the coils too.
Good luck. Hope this was helpful.
Nov 20, 2009 | Computers & Internet
Where is the drainage hole for an ge aeh08alg1. It is tilted ok but condensation is not drianing from the unit.
This unit has a low cut area in the rear of the chassie for excess water to drain. most if not all of the water should be picked up by a ring around the condenser fan blade called a "slinger". its purpose is to throw the water into the cond. coils and evap it that way. the A/C unit wont drip under most operating conditions if properly cleaned. if its a pull out type. pull it out. set on saw horses or a table and then spray the gunk out of the bottom of the unit. passages are probly clogged into the fan shroud. in the rear of the unit. hope it helps. steve. arcticacservice.com
Jul 12, 2009 | GE AJCQ08ACB Air Conditioner
Extreme condensation, pooling in the floor of T-49
Please check your drain. These units have a drain pan for the condensation. After these units have been running the drain may develope a build up of debris.
Sep 26, 2008 | True T-49 Side by Side Refrigerator...
Thru wall GE A/C
Hi, If this is a new unit I would check the filter first and make sure it is clean. Also check and make sure it is slightly tilted to the outside. If its an older unit it probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem.
Aug 27, 2007 | Heating & Cooling
Refrigerators Logo
134 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
