Question about JBL Boating
Jbl marine radio mr15b2
Can not eject cd
3 Suggested Answers
MarineTech1
  • 76 Answers
SOURCE: I am trying to find
You will find the maual you need by using the following link :
http://www.prospecelectronics.com/JBL%20MR6%20manual.pdf
Posted on Sep 13, 2009
Ironfist109
  • 3018 Answers
SOURCE: I am looking for a
  • By no power do you mean you get no response from CD or radio out of the speakers when trying to use the radio? Should this be the case then I'd like you to check a few places.
  1. First look to make sure the wires in the back are not broke or the insulation has somehow been negated.
  2. Next is to check the power wires and ground wire. Look for an inline fuse anywhere between the battery and either power wires. One should always be installed to prevent a surge reaching the head unit so make sure to check for a fuse. Replace if blown with same size fuse, never bigger.
  3. Remove the face plate and notice the reset hole (last hole on the left) Take a pen or other pointed but not sharp item and stick it into that hole and hold for 10 seconded. Then retry.
  4. Make sure the contacts for the face plate where it hooks into the head unit are clean and don't have any grime buildup that would prevent any of the contacts from contacting.
  5. Next you can try removing all power wires and wait for 5 minutes and re-connect. Sometimes this will also reset the unit.
  • I know you asked for a manual. I don't have the exact one. I do have a similar one that I can offer. http://www.premiumleisure.com/Manuals/nov07/Hydro_Spa_JBL_Stereo.pdf
  • Your unit was discontinued and not made for long and this may be a part of why the manual is difficult to find... for free anyway it is. I can say I don't need a manual to help you determine why the unit is not powering on.
  • How are you determining has power but just not responding to the on/off button? A volt meter check to the wires perhaps at the back of the radio? If you get power to the wires at the back of the radio then double check your ground real well because if the ground is good then, at that point, the head unit is bad.
  • If you perform all the tests I stated above and still no dice then the head unit is bad. There is no "code" for the radio so that will not be a factor. It's really a process of elimination.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Aug 04, 2011
Stuck CD in JBL 4 disc CD Changer / Navigation
before you press the cd on button keep holding the eject button while you press power on, I know this works for computers etc.
Feb 13, 2016 | 2013 Toyota Highlander
The cd will not eject from the unit
you need to call radio shack or a stereo place to see if they can help if you take the loader out and bring in.
Jan 01, 2010 | 2005 Mercury Mariner
CD's won't eject or play, Toyota 2002 JBL system
sorry it needs to be removed and sent to a elctronics repair shop. there is no easy fix.
Nov 17, 2009 | 2004 Toyota Sequoia
CD doesn't eject CLARION XMD3 marine radio
Disconnect the fuse of radio and reconnect it again.
That should force him to eject the CD
Oct 27, 2009 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
Do I need a Sirius radio antena for a MBB219
What you'll actually need in order to get Sirius is a satellite specific receiver (the JBL SIR 2.5 Satellite Receiver). That should come with the antenna you need.
Jun 03, 2009 | JBL Mbb 218 Cd Radio
Need users manual for JBL MBB 219S
http://www.manualnguide.com/brand/jbl/
hope this helps
Feb 28, 2009 | JBL Mbb 218 Cd Radio
JBL MR-4 CD doesn't eject
The unit probably doesn't think there is a CD inside. Possible doing a soft reset will fix this. Do so by powering the unit and putting a ball point or other pointed object into the reset button opening either on the face of the radio or behind the face. A hard reset can be done by disconnecting constant power from the unit for approximately 15 seconds.
If either of these methods fail, then your unit has a bad CD mechanism or more than 1 CD inside the player. In that case, the unit will have to be serviced by an electronics repair or a local stereo shop. This is a Marine radio, and if installed on a boat, this problem is not too uncommon. Moist air can cause damage to the unit as well as the bouncing on the water that boats do.
Aug 11, 2008 | JBL - MR4W Am/Fm with CD Player White
Boating Logo
57 people viewed this question
Top JBL Boating Experts
drshaddock
drshaddock
Level 1 Expert
DocZachary
DocZachary
JonSnell Electronic
JonSnell Electronic
Are you a JBL Boating Expert? Answer questions, earn points and help others
