Question about Poulan Garden
Lawn mower blows fuse
Blown fuse
  • 7 Answers
SOURCE: I have a 15HP YTH 1542 riding lawn mower. It has a
check wires for short to ground
Posted on Jun 25, 2009
  • 13 Answers
SOURCE: I have a ariens riding lawn mower and I keep
look at every wire ...trace it untill you find the striped wire thats touching up against a piece of metal somewhere...or something you may have recently put back together where the wires are now backwards...
the only other thing is something really hot melted it and its grounding out on metal..
CHECK EVERY WIRE...get under there...get dirty...but dont get a headache...ive been there..thats why im writing you man!
Posted on Jul 21, 2009
  • 21 Answers
SOURCE: I have a Husqvarna Yth 180, the lawn mower shut
try unplugging the pto then start the mower next engage the blades and see if the fuse blows if it does the problem lies in the mowers wiring if not the problem lies in the pto. hope this helps
Posted on Jul 27, 2009
  • 6468 Answers
SOURCE: my ******* lawn mower keeps blowing fuses when trying to start
look at the wiring for a wire rubbing against metal shorting it out
Posted on Apr 03, 2012
stevestroud2
  • 4 Answers
SOURCE: why does lawn tractor blow fuse eveytime when attempting to start?
It could be one of a few things causing the fuse to blow. The ignition switch could be defective, It could be a bare wire grounding out somewhere, It could be the alternator or regulator / rectifier. If you don't know how to repair electronic problems you may want to hire a lawn and garden repair technician.
Posted on May 02, 2012
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
Fuse for igntion were its located
    Riding Lawn Mower Fuse Replacement - Craftsman Lawn ...
    ? 1:51
    https://www.youtube.com/watch?v=rjFz8l8hoGk
    Aug 22, 2014 - Uploaded by RepairClinic.com
    ... instructions for replacing the fuse on a Craftsman riding lawn mower. ... Mower Starter Solenoid Replacement - Craftsman Riding Lawn ...
    14 HP Murray Mower 42813x92B Blowing the Fuse - YouTube
    ? 4:37
    https://www.youtube.com/watch?v=J8l1Ew40G7g
    Feb 14, 2013 - Uploaded by RogerASkiVideo
    Photographic guide to troubleshooting a Murray riding mower that keeps blowing the 15 amp fuse. images for Lawn Mowers ignition fuse
Dec 19, 2015 | Garden
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
Just stopped, put in gas, turn key...NOTHING
If it has a Briggs and Stratton motor open the hood and look all along the wire harnesses. There might be an automotive type plug in 20 amp fuse that has blown. If it did blow there is a reason. First look for a dead short somewhere. Mine was a loose wiring terminal at the headlight. Replace fuse and try to start.
May 01, 2010 | Sears Lawn Mower Ignition Switch Replaces...
Cub Cadet 2008 1042 Series
If the problem occured after the deck work check everywhere you worked on the deck. You are lookining for a pinched wire. What is occuring is with the vibration of the mower running the pinched wire will rub and touch ground causing the fuse to blow and shut off the engine. Even if not concerning the deck that is what you have to look for. It can be time consuming but this is what you have to do. The short if not about the deck try checking the seat area this is a common area of problems with shorts in riding mowers.
Sep 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Engine ran and now lost spark!
Look for a fuse and see if it has blown. It will look like a fuse you use in your vehicle. If blown put in a new one. If it blows again look for a bare wire that could be shorting out.
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
35 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
