Question about Car Audio & Video
Power supply s-s2006a-05
How serial part ic & fet power suplay
SOURCE: shrarp tv 14v j100m
check if theres a 9 volts supply from lm7809..
Posted on May 17, 2008
projdoc
  • 2237 Answers
SOURCE: InFocus LP540 Power Supply Problem
most of infocus parts are oem and made by a company in taiwan that no longer makes power supplies, and many of the parts have their stock numbers and not neccesarily a common stock. the power supply, however, is in stock at infocus for about $65.
Posted on Jul 17, 2009
projdoc
  • 2237 Answers
SOURCE: Infocus projector power supply dead
the caps dry out. look for bulging caps. you won't find a schematic for the ps boards. infocus had someone else make them. the problem seems more like a overheating issue. as for the other one with the "just the fans", check the colorwheel.
Posted on Sep 04, 2009
lqv77
  • 6 Answers
SOURCE: i need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Posted on Sep 07, 2009
  • 64 Answers
SOURCE: my alpine five channel amp got fried and on
There is no way to do a bypass without afecting other functions on the AMP. What you can do is try to get the numbers printed on it in order to get a replacement. You may also find it on the diagram but it is a little bit difficult if you do not know how to read it. Next time post the model number for easier reference.
Posted on Jan 27, 2010
Xtronie x20qa12074802 colour television burns fuses when i power it
that was mean has bad major component either in the power supply board or in the main board.check first shorted bridge type diode and regulator ic and FET transistor in the power supply board if getting shorted.
Sep 07, 2012 | Televison & Video
Tip
CHIPLEVEL SERVICE OF MOTHERBOARD
I AM A CHIPLEVEL SERVICE ENGINNER I DO CHIPLEVELSERVICING OF ALL MOTHERBOARD
FOR EXAMPLE THE SMPS FAN JUST INSTALIZING MEANS A DEAD SHORTING POWER SUPPLY SECTION OF MOTHERBOARD IF IT HAPPENS REMOVE THE PROCESSOR CHECK ALL THE POWER CONNECTION LINES FROM THE SMPS CONNECTION WITH ANY OF THE RESPECT OF GROUND IF ANY LINE IS FOUND SHORT CHECK WHICH COMPONENT IS PRIMERLY CONNECTED TO THE LINE AND REPLACE THEM
CONNECT THE PROCESSOR WITH ITS HEATSINK AND CHECK THE SYSTEM WETHER THE SWITCHING IS OK IF NOT CHECK THE POWER IC,RELEATED CHIP RESISTORS AND CAPCITORS,FET,TRACK OPEN
IF THE FET IS DAMAGED IT WILL SHOW INTIALL SWITCHING AT GATES IF IC IS DAMAGED IT WONT SHOW ANY SWITCHING
on Sep 11, 2010 | Computers & Internet
No power
Check the Mosfets on the P0981 pcb this is the pcb that has the inputs and such.. not the power Supply board. Fets are mounted to the Heatsink under this pcb, but you can get to the pins as they come up thru the pcb . T11, T7, T4, T1 These have 3 terminals Check for shorts or reading the differ from one to the next.. These are Fets so From G to D and G to S shoudl be open. D to S will read some value as there is a Diode across it.. Also If these are bad the Gate Driver IC IC 11 or IC 3 might be the cause. Mine had two shorted FETS and the IC that drove them was bad. IC is IRS20955 Found some tech reports that show this ic was updated to IRS20957 due to issues.. So I updated both mine and replaced all 4 FETS. Good luck .
Aug 21, 2012 | Behringer EUROLIVE B1800D PRO Active 18 In...
My tcl tv model tcl 2009 has no power but led is blinking. I replace already the control ic TDA16846 but still not working. what is the possible problem regarding the power supply
A nice little Control IC but when they fail ithey take out a lot of components around the power supply especially the output FET rather catastrophically for the power board.
I would look elsewhere for your fault because if there is a flashing light, the microprocessor has power and that comes from the power supply.
Look for open circuit fuseable links.
Hope that helps.
Dec 10, 2010 | Televison & Video
Pmp3000 problem power supply.ic circuit problem.number series ic circiut..
I have a PMP5000 that I had to resurect. I had to trace out the power supply to repair it.
I can give you hint: First, a small supply runs directely from the line and generates some of the small voltages. While this starts, the main power caps are charged through limiting resistors. The main switcher is brought online and if the power amps acheive balance, then a relay connects the speakers and shorts the limiting resistors.
This is what is in the 5000 and I suspect the 3000 is similar.
In my 5000, there was arcing at one side of the power amps. The board was burned and three power fets fried. Cancer of burned board had to be carved out and traces replaced by hardwiring.
In addition, the limiting resistors were blown open, both main switching transistors were blown and 4 small driver transistors (surface mounted) and several diodes AND a switching regulator chip (surface mounted).all fried/
Hint: When restarting the unit, put a 150 watt light in series with one of side of the power input to limit the current in case you did not get all the dead bodies out.
This is a class "D" amp which drives PCM waves into a filter which is then the audio output. It is much more efficient thaan a linear amp.
Dec 24, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
When i started to plug my battery in my amp made
you have blown the actual filters that make the sound. a amp is basically a filter with the same filters on both channels on each side of the inside of the amp - channel 1 and channel 2, that pop was in the heat sinks of the amp usually. if you have replaced the fuse in this amp and you get no on light, the internal amp is in need of repair
Oct 24, 2009 | Rockford Fosgate Punch 401S Car Audio...
Not booting
check ur mother board power supply check the FET check all the power lines from the smpswith respective of ground with any line short check which component is primerly conected to that line replace it check the FET power IC etc
Nov 29, 2007 | Intel Motherboard
250/1 powers on but no output
If the amp is not going into protect, the power supply FETs have probably failed. In the corner of the amp near the toriodal transformer, there are 4 FETs against the heatsink. When these fail, the 47 ohm resistors at the base of the transistors often fail. If the resistors are dark, it generally means the FETs have failed. If you disconnect the amp from power and measure the resistance from leg 1 to leg 2 of the power supply FETs, a reading of near 0 ohms indicates the FETs have failed.
Nov 06, 2007 | Jl Audio 250/1 Car Audio Amplifier
Earthquake ph-d2
The PWM IC is an SG3525. Which IC are you calling the protection IC?
Nov 02, 2007 | Earthquake Sound PH-D2 Car Audio Amplifier
Car Audio & Video Logo
155 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
