Question about Cycling
Manual for Thompson electric bicycle 'Euro Tourer'
How do I adjust the angle of the handlebars on my Giant RS Tourer bicycle?
Usually this is done with a 5 mm hexhead wrench. There are 4 bolts on the stem, some have them on top, some on the bottom. If you are unsure, visit or call the nearest bicycle shop
Oct 12, 2014 | Cycling
What is the size of the axle nut on a v star 950?
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha 1300 Tourer Yamaha 1300 Tourer Fansite
http://www.mybikeforums.com/forums/showthread.php?t=15440
YAMAHA XVS950A Owner Manual
OEM parts for Yamaha
2009 Yamaha STAR 950 TOURER Motorcycle Service Manual Download Manuals...
Jun 04, 2014 | 2009 Yamaha V Star 950 Tourer
Electric bicycle
Contact the seller for a manual http://www.omegastores.com/cozybikele.htm
First remove the battery then find someway to support the bike as removing the rear wheel also removes the stand...
Remove the 2 Philips head screws securing the rear mudguard and the 2 on the LHS rear axle cable protection cover & slide the cover off. Disconnect the rear brake. undo the rear axle nuts. Loosen the chain adjusters and slip the chain off. You may also have to deflate the tyre to get it past the mudguard.
Mar 23, 2014 | Electric Bicycle Motor, Bike,electric...
Service manuals in pdf for yamaha electric bikes
i have electric bicycle yamaha 4xf-027049. i need asseesries price list
Oct 10, 2012 | Electric Bicycle Motor, Bike,electric...
What is the tire pressure Yamaha 2007 V Star 1300 Tourer
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha Motorcycle Tire Pressure
Yamaha XVS1300A 2007 Service Manual
Yamaha 2007 XVS1300AW Owner Manual
May 22, 2012 | 2007 Yamaha V Star 1300 Tourer
Need diagram for removing rear wheel to fix puncture on power ped
you can easily fix a flat without removing the wheel from the bike if it uses a tube application to inflate racers use this method to save time as you just have limited space to do your repair apposed to removing the wheel completely dunno just a thought because im thinking your bike has wheel tensioner jigs on the rear axle and they can be tricky to get rite if your unaware of how they work and you could do more damage then good so try to slip the tire off one side pull the tube out and mend your flat and dont forget to check the interior of the rubber for burrs of foreign material less then a 10 minute job good luck message back if your stuck ok :)
Dec 01, 2010 | Electric Bicycle Motor, Bike,electric...
Lost Manual for Euro-Pro Dressmaker 11 Model 1100
Call 1-800-361-4639; one of the Euro-Pro sewing machine phone reps can tell you what to do and they may be able to send you a manual.
Jan 01, 2009 | Euro-Pro 9120 Computerized Sewing Machine
Cycling Logo
115 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
