Lg wd1018c the timer on any cycle will go down to 13 mins and remain there. the pump just keeps trying to pump water out
Have cleaned the filter and cleaned the armature
5 Suggested Answers
  • 1214 Answers
SOURCE: machine won't fill with water
Check that the inlet screens on the water supply are not clogged.
Make sure the water is for certain turned on (assuring nothing has changed).
If those are not found to be the problem, then it could be the fill valve(s) or the timer control.
Reply back what you find, and I can help you further.
Posted on Jan 29, 2009
  • 135 Answers
SOURCE: Whirlpool Cabrio F50 Error
Most likely the RPS sensor or the control board. Originally they had trouble with the RPS sensors.
Posted on Aug 26, 2009
Daniel S
  • 4323 Answers
SOURCE: Our lg wd1018c Front Loader
Hi Darryl,
Merry Christmas to you too :) The washer won't spin if it is unable to drain the water out, check the drain hose first and try to clear it for any blockages, then check drain pump operation. You can also clean the drain pump filter and check if the drain pump is frozen or kinked. If the drain pump is not working it'll cause these kind of issues. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 25, 2010
Macmarkus
  • 2605 Answers
SOURCE: GE WBVH6240 front load washer
Hello, Welcome to FixYa.
The first thing I'd suggest is removing the filter in the pump you spoke of and insuring the pump is clear...there may be alot of water though so hopefully you're close to a drain or have some buckets/towels handy.
If that fails to resolve the problem it could be a plugged or faulty pressure switch. Have you run a system diagnostic yet ?
Here's how and the subsequent code meanings...in the event you don't know...
Let me know if any of this helps or perhaps you cannot read it, It is all included in the service manual I can send via email if you could use it.
Good luck.
Regards,
Macmarkus :)
Posted on May 06, 2011
THERE ARE NO CLOGS ANYWHERE IN THIS DISHWASHER VUD141-SS. EVERY AREA HAS BEEN CHECKED FOR POSSIBLE FOR CLOGS. DISHES ARE CLEAN AND THE WATER CYCLES FINE. HOWEVER WHEN THE TIMER REACHES THE CYCLE WHERE THE...
yes the drain pump should start at this point so I would suspect a faulty drain pump,But try a reset first push and hold power button until lights reset then try a cycle if this fails to fix problem then I would suspect the drain pump.adrian,,,,,
Feb 11, 2015 | Viking Dishwashers
My maytag washer when i start it it fills then the cycle starts the timer will count down til it get to 13 min then jumps down to 3 min then shuts off it skips the wash cycle and the rinse cycle befor
sounds like you have a problem with the main control board. you can order a new one from appliancerepair.com and if it turns out not to be the problem they allow you to return it for a full refund. great company!
May 26, 2014 | LG Washing Machines
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
Got an OE error, now it will not finish rinse and spin, sounds like it is grinding in the spin cycle and the timer is stopped at 27 minutes remaining. What is wrong?
The problem is in the drain system as what error code OE stands for.The grinding noise is coming from the drain pump. Loose change, hair pins and the likes can get into the pump filter and sometimes into the pump impeller causing a grinding noise during the spin cycle because the pump works while the machine is spinning. The pump impeller may also be broken causing the grinding noise.
Disconnect power then open the filter door on the bottom left of the cabinet.
Remove the drain plug and drain the water out completely into a shallow basin or the likes. Once drained, lay a piece of towel under the filter then turn the filter knob counterclockwise and remove it. Clean the filter and reach in the pump impeller to check it if blocked or broken. If cleaning the filter does not solve the problem, you need to access the drain pump assembly and check the pump particularly the impeller thoroughly. Click on the link below for the detailed procedure in accessing the drain pump assembly.
LG Front-Load Washer Drain Pump Access
Dec 30, 2010 | LG WM2277H Front Load Washer
Washer does not spin. Tried to start cycle over
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Jul 26, 2010 | LG Washing Machines
Bosch 1200 classixx not working properly. On 12 min spin cycle it starts then after 1 min timer reads 0:01 and it stops. washing cycles run but doesn't seem to be any spin action
Make sure there is no water in drum.
Remove and clean pump filter, this is usually located at the bottom front right of washer, behind drop down cover.
Unscrew anti- clockwise to remove and clean.
Good luck.
Dec 13, 2009 | Bosch Washing Machines
Machine won't fill with water
Jan 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
Front load washer wcvh6260fww
The problem may the pump filter which is hidden behind the lower front panel. To access the filter, unscrew three screws at the bottom of the panel and carefully remove the lower front panel. Make sure to unplug the machine. With the panel removed you will see the pump filter. Get a bucket and some towels ready, because when you open the filter, you may get a gallon plus of water coming out. GE failed to put this in the use and care manual for the 6260. But low an behold, GE put an access door and explicit instructions on cleaning the pump filter in the updated 6400.
You may have burned out your washer pump. That is what happened to me. The machine would not drain or spin properly and so I kept pushing the blinking start/pause button to get it going again. Then it finally did not drain at all. I installed a new pump and with the cleaned filter, the machine worked like new. For some, simply cleaning the filter allows the pump to work properly. As the filter gets clogged the pump has to work harder and harder to pump out the water. When this happens the cycle times get extended . One symptom of a clogged filter is the final minute (spin cycle) takes much longer. Obviously this is a "design flaw" that GE "fixed" in the recent version of the 6260.
Mar 25, 2008 | GE Energy Star WCVH6260F Front Load Washer
Display panel
Check to see if any water remains in the machine . SOME MACHINES IF They DO NOT DRAIN OUT ALL THE WATER WILL CONTINUE TO run until all water is drained. Also check for suds in machine if machine senses suds it will try to re rinse the clothes.If your machine has a filter at the bottom clean it out .
Oct 09, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
