Question about Cell Phones
TV Code Sanyo CE28D8-C
Code
I Need to Find coad to program Remolt For Sanyo TV/Dp37647
The universal code for most is 049 for a Sanyo TV. With your universal remote you press the code search key until it illuminates and then you press and release the TV key. Next enter the three digit code (3 digit remote code page) and the indicator light turns off.
If you enter in the wrong code the light will flash rapidly. Aim the remote at your tv and press the on/off key. If your tv turns off then you have found the right code!
Try these codes for your Sanyo TV also: 054, 069, 023, 025. If those do not work then also try: 004, 013, 049, 108, 110, 180, 209
Read more: http://codesforuniversalremotes.com/universal-remote-control-codes-sanyo-tvs/#ixzz3w1wdIQ6I
Dec 29, 2015 | Sanyo Televison & Video
Code for remote tv sanyo
The code is 049 for my Sanyo TV
With my universal remote you hit the code search key until it lights up then you press and release the tv key
Then enter the three digit code and the indicator light turns off if you enter the wrong code the light will flash rapidly.
Aim the remote at your tv and press the on/off key. If your tv turns off you have found the right code.
Jan 10, 2015 | Sanyo 42 in. LCD TV
I need the code to program a sanyo tv using the one for all untiveral remote URC-2060
If you do not have the code for you Sanyo TV then you can use the remote itself to get the code. It is a bit painful as you have to count the number of blinks it makes.
Follow the steps under getting your code.
Also it would help if you provide the model number of your sanyo TV in the comments section.
How to Program your One For All remote
Aug 17, 2014 | Televison & Video
I need the code to my sanyo tv
Hello
According ro RCA Codes for sanyo are detailed as
Code 004 for sanyo tv Code 048 for Sanyo TV Code 049 for Sanyo TV Code 073 for Sanyo TV Code 080 for Sanyo TV Code 107 for Sanyo TV Code 162 for Sanyo TV Code 169 for Sanyo TV Code 180 for Sanyo TV Code 196 for Sanyo TV
Just check with these codes according to the proceedings.
1. Manually turn on the TV.
2. Locate the enclosed TV Code List. Find
your brand of TV.
Note: If your brand is not listed, use one
of the Code Search methods to program
this remote control. (See section on
Code Search.)
3. Press and hold the CODE SEARCH key
until the indicator light illuminates.
Then release the CODE SEARCH key.
4. Press and release the TV key. The indicator
light blinks and then remains lit.
5. Use the number keys to enter the first
code listed for your brand. After you
enter a valid three-digit code, the
Note: If you enter an invalid code, the
LED flashes rapidly for two seconds.
Start over at step 3.
6. Aim the remote at your TV and press
the ON•OFF key. If your TV turns off,
you have found the correct code.
7. Enter the code in the box provided on
this page for future reference.
8. If your TV doesn't turn off, repeat steps
3-6 above, entering the next code for
your brand.
Manual Code Search
1. Manually turn on the component you
want the remote to operate.
2. Press and hold the CODE SEARCH key
3. Press and release the component key
that corresponds to the component you
want the remote to operate (TV, VCR,
DVD, DBS•SAT, CABLE, AUDIO). The
indicator light blinks once and then
remains lit.
4. Aim the remote at the component. Press
the ON•OFF key continuously until the
component turns off.
Important: Because there are so many
codes, you may have to press the
ON•OFF key many times-possibly up
to 200 times.
5. When the component turns off, press
the ENTER key to store the code.
6. Use the Code Retrieval section on the
next page to identify the code for your
component for future reference.
OK
Feb 15, 2011 | RCA RCU600M Remote Control
I need the code to program my sunflwer remote with my sanyo tv
try these 014 / 032 / 045 / 075 / 120 / 121 / 122 /123 / 124 / 163 / 168 / 171 / 183 / 196 / 206 / 305 these are for all diffant sanyo tv and if your remote needs more than a 3 number code sorry can not help
Nov 28, 2009 | Sanyo Televison & Video
I have a rca 311 w to program into a sanyo tv
Code For Model RCR311W
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Jun 05, 2009 | RCA RCR311B Remote Control
RCA remote codes lost
Codes For Model RCR311B
Codes found here: http://remotefinder.rca.com/default.aspx?site=rca
RCR311B manual (PDF): http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
May 26, 2009 | RCA RCR311B Remote Control
Need codes for a Sanyo TV
Code for Sanyo TV is 0154
Mar 26, 2009 | Sanyo Televison & Video
Sanyo tv codes
lost remote for sanyo tv now have a G E universal remote and i need the code to work the tv
Jan 03, 2009 | Televison & Video
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
