Question about Radio Communications
Maxon sp-340 uhf radio. When I try to read the radio, it states radio attempted data transfer in wrong direction. I have a new ACC-904 programming software. Also I'm using a ACC-2300 Interface Cable, what is the problem.
sserpentio
  • 88 Answers
SOURCE: maxon sm4150m mobil radio
hi try here,.....
www.zeroonezero.com/portfolio/Havis/htdocs/partprice.pdf
www.campbellsci.com/documents/manuals/maxon.pdf
Posted on Mar 31, 2008
  • 3 Answers
SOURCE: Vertex programming problems via USB
This probably doesn't help, but sometimes a much slower (older) computer will work where a faster (newer) will not. The Motorola's are notorious for this. Others, too. USB is USB, a standard--so that's not your issue.
Posted on Apr 20, 2008
Agent Ken
  • 250 Answers
SOURCE: maxon sl100
Hello baba_zam,
The Maxon SL100 can be programmed but doing so requires a programming kit including software and a specialized cable. Unless you are going to be reprogramming a lot of units regularly, you are going to be best served by taking the unit into your local Maxon dealer and paying them to reprogram it for you.
Best Regards,
Ken
"Go Ahead. Use Us."
Posted on Jun 02, 2008
randy54156
  • 55 Answers
SOURCE: maxon sl70
You may want to search this site for a manual.
http://mods.dk/
Posted on Nov 09, 2008
  • 41 Answers
SOURCE: Kenwood radio TK270G
The Radio you have is probably an older version, in this case you will need KPG56D. the other possibility is that the software you have is dos driven if this is the case then you will need to install the software on a slower machine with DOS 6.22. I use a pentium pro with windows 98 to program most of my kenwood radios. you will also have to disable any virus software and disable any TSR files on the machine in order to program the radio. The windows base programs don't have these quirks. take a look at your software and let me know what happens.
Pat N5SLI
Posted on Nov 11, 2008
I can read code plug with KPG-112D but after saving a write attempt results in "The linked network file cannot be opened" error
Hi Warren,
To steer you in the right direction, may I suggest: join yahoo group specific to your radio Make/Model, there you will receive info from experts and as a plus, you can download manuals, schematics and other goodies.
I hope this helps you.
Regards,
Peter
Jan 31, 2013 | Kenwood Kpg-112d V2.01 Programming...
CAN THE MAXON BE RE-PROGRAMMED TO COMPLY WITH THE NEW FCC REGULATION OF NARROWBANDING?
It depends on the model and when it was produced. You might try googling the model number of the radio. Or you could call Maxon at 800-821-7848.
Best regards.
Sep 12, 2012 | Maxon Radio Communications
How to reprogram two way radio, its a motorola gp 339 and its set to 5 channels from when i brought it, can i reset it or reprogram it to normal uhf channels?
In order to reprogram this Motorola GP339 you need to have a programming software, radio interface box and programming cable for this radio then you can read and change frequency in it. To reprogram to UHF channels this radio must be in UHF band. Good luck!
radcom907
May 14, 2010 | Motorola GP300 Compatible 2 Way Radio...
I have a maxon sl55-u2 frequency radio only channels 1 to 4 work. why is this?
Only 4 channels have been programmed, you will need a programming cable to plug it into a computer and use the maxon software to programme the other channels to whatever frequency you need.
Nov 15, 2009 | Maxon Radio SL55, SP130, SP140, SP150...
Reprogramming a Maxon SP 100G?
Hello codeencrypt,
THE SP100G is essentially the same radio as the SP100U UHF business band unit that Maxon made at the same time, just pre-programmed for GMRS. I believe there is a programming kit for this radio (Model number: SPK400C) which may still be available for purchase from Maxon directly. Otherwise, your best bet is going to be contacting your local Maxon dealer to see if they have the capability to program he radio.
Best regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Maxon SP-100G (4 Channels) 2-Way Radio
Maxon sl100
Hello baba_zam,
Best Regards,
Ken
"Go Ahead. Use Us."
May 31, 2008 | Radio Communications
Need to know where to get battery charger for maxon two way radio serial#970906899 model#SP-1008
Hello bobt78,
Your best bet is going to be contacting the manufacturer directly via their website at http://www.maxonusa.com.
Best Regards,
Ken
Go Ahead. Use Us.
May 04, 2008 | Maxon 49-HX 2-Way Radio
Maxon MCB 10 A
I'm not sure about your particular model but many CB radios use the microphone push-to-talk switch to kill the speaker while the radio is transmitting. If you don't have the correct microphone or if the cord has a broken wire it can cause the radio to have no sound. Another possibility is that the speaker is bad. There is probably an external speaker jack on the back of the radio. You could try plugging a different speaker or even an earphone in the jack to see if you get sound there.
Mar 07, 2007 | Maxon SP-100G (4 Channels) 2-Way Radio
Radio Communications Logo
53 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
