Hi thanks for the opportunity,my tv model hisense TC2108d/C320 has a problem with playing television stations well it doesn't even show that it is searching when I search for local stations I thought it had a problem with its visuals but the DVD plays perfect and its still new
SOURCE: green picture
Sounds like a poor connection with a scart lead
Posted on Oct 26, 2007
  • 518 Answers
SOURCE: Bush television & DVD error message 'unknown disk'
Some units jusy won't play certain types of recorded DVD discs. I would transfer one to a DVD+R type and see what happens. Buy a good brand like Memorex.
Hope that helps...
Geno
Posted on Mar 24, 2008
circuitworld
  • 335 Answers
SOURCE: NO sound and NO cable signals
Is your tv connected to your cable box through HDMI, AV, or component?
_____________________________
If its through HDMI then your cable carrier needs to load updated frimware in your box to communicate properly with your 2005 tv. The firmware loaded in your cable box needs to be "reverse compatible" for first generation HDMI from your 2005 tv. If your using AV or component hook-up and there's no sound then re-check all of your audio settings within the tv's menu. Also recheck the cable-wire your using and proper input/output ports.
ON your dvd player, is your tv connected through component, AV(rca) or HDMI?
If its through "component" then you need an extra audio cable to and from the DVD and tv.
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: I own a Sansui model
You can download the manual from Orion who makes Sansui.
http://www.orionsalesinc.com/Downloads/27-/View-category
Posted on Feb 23, 2009
  • 99 Answers
SOURCE: Error message when playing any DVD in Hi-fi
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Posted on Jan 01, 2010
Hisense 54 model tc2108d I replaced eeprom but still saying eeprom check
After EEPROM replacement, its initialization should be done. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Try type in the key word "EEPROM" too, in the search box.
Jul 06, 2016 | Hisense Televison & Video
Hisense tv
so whats the remote you have there?
Oct 23, 2008 | Hisense TA42P40M 42 in. Plasma Television
Power supply problem
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Feb 01, 2015 | Hisense Televison & Video
Hi I have hisense 65 inch tv I want yupptv
Only the TV manufacturer can add support for Apps to their TVs. If there is a Hisense App Market, and it's available as a download for your particular model of TV then go that route. If it's not supported then there's not much you can do except hook up your laptop and play it from there.
Sep 09, 2014 | Televison & Video
How to remove the description on the tv
Maybe your initial setup procedure let you select this and you have to go back to eliminate it. I get a bloick like that while channeling through live TV but the block goes away.
Nov 24, 2013 | Hisense TA42P40M 42 in. Plasma Television
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Jul 23, 2012 | Hisense LCD1504 15 in. Television
I replaced the fuse on my Hisense TC2108D TV, but now its show EEPROM ERROR PLEASE CHECK
it due to EEPROM IC fault the iC is 8 pin and mark as 24CXX here XX -is 02 ,08 or 16 like that
just replace new one and see the error cord some time you need programmed EEPROM to resolve the problem
Aug 25, 2010 | Hisense TC24FS2H TV
Unable to play DVD's
Hi, It is entirely possible that a couple of conditions could exist.
1) the DVD may support progressive output and the TV may not
2) the TV input could be defective or the DVD output could be defective.
Possible tests are -
You could test the TV input by substituting the dvd with another appliance known to be working (say a VCR. etc). the Y input (Green) on the TV only needs to be supplied with a composite output (yellow plug). If you see some sort of response from the picture then you can confirm the tv input is at least working.
Alternatively, try a different input/ output combination between your DVD/TV (Composite signal)
Mar 19, 2010 | Hisense LHD3204US 32 in. LCD HDTV
Need remote control code for hisense EN-21660A
Does anyone know where I can get a remote for a Hisense 22" TV? I've bought a universal remote but after reading other people's experiences with the Hisense remote, I'm reluctant to even try it.
Dec 23, 2008 | Hisense LHD3206US Television
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
