Contact number vokera option pcb
Hi there i have a vokera option combi boiler the pcb keeps failing on d2/d3 what are these please ?
Buffalo12980
  • 625 Answers
SOURCE: Pilot light will not stay on when egnition switched is released!
the little copper tube that sits in the pilot flame is faulty. this is called a flame sensor. replace this and you should have no problems
Posted on Dec 09, 2007
SOURCE: vokera combi boiler
air in system
Posted on Aug 11, 2008
  • 13 Answers
SOURCE: hi iv got a worcester 24i junior combi boiler, i
try holding the reset button for at least 30 seconds
Posted on Nov 06, 2009
  • 2888 Answers
SOURCE: hi, my ideal combi boiler model mini HE C28 goes
Hi check the flame senser is in postion and clean
Posted on Feb 01, 2010
  • 2888 Answers
SOURCE: Hi I have a ideal isar 30100 combi boiler which
jumper links not inserted in to pcb is h5 code
Posted on Mar 21, 2010
Testimonial: "Hi mylandlord eventually sussed it out and blanked of port1 and 3 on the pcb thanks for your help T"
Vokera boiler problems
need to change thermostat and a thermocouple
Jan 28, 2014 | Water Heaters
My vokera mynute 25 ehe boiler was wroking fine until yesterday when my wife turned the selctor to 0, thinking she was turning it off. When i turned the selector back to 1 last night, the boiler wouldnt...
My name is Carla and I work for Vokèra in the marketing department, I am sorry to hear that you are having problems with your Vokèra boiler and I would like to help you get this problem sorted as soon as possible.
Please email me your contact telephone number and I will arrange for a member of our service team to contact you, alternatively you can contact them on the numbers below.
Email: marketing@vokera.co.uk UK: 0844 391 0999 (option 2) ROI: 056 7755055 (option 2)
Aug 02, 2011 | Heating & Cooling
Could please tell me how to light the pilot on my vokera boiler please
Hi and welcome to FixYa, I am Kelly
Since you did not include your model number, I am not going to guess which boiler you have. (Not being rude there are just too many.)
Every model of Volkera Boiler is listed in the link below. Please click or copy and paste this link:
http://www.vokera.co.uk/trade-professionals/manuals-literature
Once the page opens, find your model number and click on "download" to get the manual. The lighting instuctions are in the manual.
Thanks for choosing FixYa,
Kelly
Apr 05, 2011 | Heating & Cooling
Combi Boiler gives CH but not HW
Combi boilers have many moving parts compared to conventional models so must be serviced annually to prevent breakdowns.
Your boiler most likely has one of four problems:-
1. When the receiver for the wireless thermostat was fitted, other wiring was loosened and has come adrift. It's a possibility, but in my experience unlikely as the wiring involved isn't anything to do with HW supply..
2. During receiver fitting the pcb suffered a static electricity surge. Possible, but unlikely as this sort of damage is usually immediately evident. However, boiler pcb's are notorious for sudden failures anyway and can happen anytime. Combi pcb's are more prone to fail as they usually have up to four solenoids fitted and these do eventually fail due to mechanical wear.
3. When you your combi is in CH mode it heats the primary water circuit and directs the flow through the CH heat exchanger. When you open a hot tap (US=faucet) you're opening a supply of cold water initially as there is no stored hot water like in a conventional system. As the water starts to flow through the combi's diverter valve there's a pressure drop which activates a rubber diaphragm with mechanical connections to other parts. The diaphragm is one part which is routinely replaced annually as it will eventually fatigue and fail with the symptoms which you describe. In addition, the mechanical parts connected to the diaphragm pass through various seals in order to activate at least one micro switch. If the seals fail then the moving parts eventually corrode and seize up. Regular servicing prevents this. Combi seizures are a very common complaint in hard water areas.
4. One of the micro switches activated by the diverter valve has failed. Possible, but not likely. The purpose of the switches is usually to fire up the boiler to provide HW when the CH is not currently running, but as you haven't said which Vaillant you have I can't be definitive on this.
One major problem with combi boilers is that multiple failures can and certainly do occur almost at once. Unmaintained units may appear to be correctly functioning but in reality a number of worn parts can be close to failing. When one part fails, the others can't cope with the stress and fail as well.
In most civilised countries including the UK it's a criminal offence to attempt most repairs yourself unless you're qualified to work on gas appliances, so you need to find a decent heating engineer to service your boiler (ask your new neighbours). In the UK you can expect to pay around £120-£150 annually for a routine boiler service. If the circuit board has failed then it can easily add over £100. If parts inside the diverter valve/manifold have seized then you can be looking at an additional £80-£150. Note that diaphragm failures on their own do not merit diverter/manifold replacement and that if you have a new diverter fitted then a new diaphragm will already be present inside.
Dishonest heating engineers always diagnose a failed pcb as they know that you have no way of knowing whether it's true. If you can live with the problem for a few days then failed pcb's are usually a straightforward repair and there are plenty of companies who will send you a guaranteed exchange unit for much less than the cost of a new one. As long as you are not opening the main boiler casing which houses the combustion chamber and gas valve assemblies then some territories allow non gas qualified replacement, but others insist that the work is done by a qualified electrician: this is not the case in the UK as long as the pcb is not connected directly to mains electricity (no modern domestic ones are).
Oct 13, 2009 | Water Heaters
Vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Feb 20, 2009 | Water Heaters
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
