Question about Sanyo Televison & Video
Sanyo ce42ld33b It won't turn on from standby with remote or buttons on tv
bwery3
  • 137 Answers
SOURCE: Our Sony Bravia Tv was
If theres absolutely no power and no lights on, it sounds like the fuse inside the t.v.. It is pretty easy to change. You have to take out the screws on the back of the t.v. and take the back cover off. Look for a 3/4" glass tube fuse and see if the tiny wire in it is broken. Pop it out and bring it to radio shack and get a new one. Put that one in and try it, Make sure the t.v. has been unplugged for at least 2 hours before opening it so the capacitors have time to drain. They will hold power and could shock you if your not careful. Also, dont use anything metal to take the fuse out.
Posted on May 15, 2011
  • 30 Answers
SOURCE: Standby light flashes and TV
seems like a power supply problem inside the tv and when the transformer gets warm it is giving you problems you might have to get a tech seviceman to come out and have a look at it as it is not a job you should do yourself when it comes to replacing the power supply hope all goes well
Posted on Jul 06, 2011
  • 1746 Answers
SOURCE: universal remote (GE 24116) that
Hi, You need a code to match with your TV remote. The codes for the Ge universal remote for Sanyo are 0049 0097 0110 0004 0268 0012 0108 0180. You will have to try each code seperately untill you get one that works. Good luck.
Posted on Sep 09, 2011
SOURCE: TV will turn on, but
Sound like a mainboard failure
http://www.shopjimmy.com/dynex-cbpf7z4kq9-main-unit.htm
Posted on Sep 24, 2011
chesterpendi
  • 195 Answers
SOURCE: TV won't turn on
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Posted on Nov 29, 2011
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
LG 42CS560 42 Class LCD HDTV won't come out of standby mode.
Could be an open internal fuse or power supply failure
Jan 05, 2018 | LG 42CS560 42 Class LCD HDTV
My sanyo remote model DS27510 won't turn my tv on or off
do you mean you can use only the remote in channel and volume settings but can not use to turn off the tv. ok the problem is just only the power button for the remote. what you need is to clean the rubber contact inside using with an eraser. to do just unclip the lock of the remote controller to remove the housing and to access the internal part.
Jul 21, 2012 | Televison & Video
When i turn it on it clicks and the goes right back off
New set?
If you're turning almost any TV on by the manual power switch on it, thats Standby mode.
The next step it's waiting for is the ON command from the remote control.
There are two main methods remotes use to go to ON from Standby:
Press the Power button for both on and off commands
Press any 1-10 (or 1-0) button for on, press power button for off.
Sep 24, 2011 | Sanyo DP42848 LCD TV
Universal remote (GE 24116) that i purchased to replace the lost remove control for my sanyo 42 inch tv won't work. the arrow buttons don't work in the menu which is the only reason I bought the...
Sep 09, 2011 | Sanyo 42 in. LCD TV
I have a Sanyo TV DP32648 and the closed caption won't turn off. i don't have the original remote and even now have a programable logtech remote. how do i turn off the closed caption
You will need to have CAPTION button on the universal remote control to turn on/off the caption, if it does not have that function then you will need the original remote.
SANYO remote model GXBJ is needed for this TV.
You can get used one for $20 on EBAY or a lot more for new one at:
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=DP32648&brand_pn=SANYO_DP32648&mode=large&v=1&uuid=A13140757813801
Aug 23, 2011 | Televison & Video
I need a code for my sky remote for my sanyo tv in order to get the volume working It is a sanyo 32" Model CE32LD33-B-01
with the tv on and sky off, press red button & select together, remote blinks twice.press tv then standby repeat this action until the tv turns off. when it goes off press select. press standby again and tv should start. your sky remote should then work perfect. as a tip with tv on and sky off press tv then back up this should then go to the freeview setup and you can watch those as well for free
Sep 09, 2010 | Sanyo Televison & Video
Sanyo ce32ld47-b code for sky+ remote
  1. Turn your TV on.
  2. Press tv on your Sky remote control.
  3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
  4. Press tv on your Sky remote control again.
  5. Key in the code 0157. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code you entered and start again at Step 1.
  6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Oct 12, 2009 | Sanyo Televison & Video
Televison & Video Logo
19 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
