Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
Cinderson V1J-HMQ20-2 C92FDGW00000motor parts
MOTOR REPLACEMENT
Need motor brushes for kenmore vacuum
Chances are the part has been discontinued. You might want to check for a replacement motor. Sometimes panasonic may have something compatible. Good luck
Aug 30, 2015 | Kenmore Vacuums
The motor is locked. How do I remove the motor and fan unit from the housing to determine whether it is repairable?
If motor and fan are locked up they can't be fixed. Simply take vacuum apart step by step until you have removed motor and fan. The part numbers should be on the motor and fan. You should be able to google the part numbers and order replacement parts
Aug 02, 2015 | Vacuums
I need motor brushes for a sip cinderson motor from a sears vacuum
I would try my local hardware first and as you did not post model of vac it is hard to go farther
May 18, 2015 | Vacuums
Looking For A Replacement
Most likely your vacuum cleaner was manufactured by someone else with a Sears label attached. You might try a vacuum cleaner repair shop or an appliance parts supplier for a motor
Jun 07, 2013 | Sears Parts Direct Motor - 4370604
I have a older m&s system central vac model av625 one motor quit the brushes are gone are parts available
You will need a new motor, not brushes, as the worn motor will tear through new brushes. Search online for the M&S motor replacement and you will see helpful sites that will provide the replacement motor. Replacing the motor is not difficult. Consider replacing both motors as the second motor will go out in the near future.
Jan 10, 2011 | M&S Systems Bagless Central Vacuum
Burning smell from motor...what needs replaced?
Without the complete model number, I don't know for sure what componets you have, most likely is the motor. You will have to take the motor cover off and check it out. You can go to sears.com, click on parts, enter your complete model number, scroll down to cannister and it will bring up a parts list where you can order parts, also a diagram of the cannister.
Jul 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Brush motor failure
Looking at the parts breakdown, the motor must be in the nozzle asm. part # 75213 and sells for about $25.
Dec 01, 2007 | Eureka 421A EZ Kleen Bagless Stick Vacuum
Replacement motor
The manual only show one wire from the motor going to the switch, the other going to the cord, then the ground wire. I would wire it the way your old motor was, could be that some models maybe were 2 speed and the other wire would be used for that. Either that or the wrong motor was in the box, it is the right part number (43576197 is Hoover number)
Nov 15, 2007 | Vacuums
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
131 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
