Question about Dell Inspiron 1420 Notebook
Battery pack light status checker
It jusu blinks, of the 5 lights 3 of them blinks, the 1st,3rd and 5th blinks.while the 2nd and 4th dont. what does it mean and wat should i do?
    Problem Solver:
  • 30 Answers
Replace the battery - 3 of the 5 cells are dead or dying.
Posted on Jul 03, 2014
5 Suggested Answers
  • 101 Answers
SOURCE: battery indicator light flashes 4 orange than 1
Try Charging your battery overnight if it does not recover time to change the battery.
Posted on Mar 02, 2009
  • 3940 Answers
SOURCE: +-+-+ Green LEDs on Battery of Latitude D600
On off on off on means the battery has failed and needs to be replaced. With the battery removed, the system should run on hte AC adapter
Posted on May 17, 2009
  • 3940 Answers
SOURCE: Is there a problem with the battery? insperion 8600
"The battery is nearing the end of it's useful life and will need to be replaced soon." is the official definition of that battery indication.
If you boot to the system BIOS (F2 at boot, and arrow down to battery, it will tell you such.
  • 846 Answers
SOURCE: Dell laptop D520: When the laptop is plugged
Sounds a lot like you just have a broken battery. You can get a new one on ebay or laptop battery store. If you've replaced the battery, tried the bios update and it still won't charge i would assume there is an issue with your logic board. If you're out of warranty, somebody has to openthe Laptop and replace the part. The part is available on ebay. Here's a guide on how to disassemble a Laptop. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Laptop Repair Services.
Posted on Sep 07, 2010
Only 1 burner lights
This symptom is typical of a failing regulator. Try replacing the regulator and hose, easy to do and inexpensive.
Jul 09, 2010 | Ducane 30400042 (LP)
What different gear box can fit honda integra xsi vtec 1600cc b16a? i want to change my gear box ,and i want to know what exactly other gear box can fit my car?thanks its a integra bot the product can show...
J1/S1 Found in: Integra XSI/RSI (DA6) Type: Cable 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.848 R: 3.000 FD: 4.400 Y1 Found in: CRX/Civic (optional LSD) Type: Cable 1st: 3.166 2nd: 2.052 3rd: 1.416 4th: 1.103 5th: 0.870 R: 3.000 FD: 4.266 YS1 Found in: Integra 92-93 XSI/RSI (DA6, DA9) Type: Cable 1st: 3.307 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.880 R: 3.000 FD: 4.400 S80 Found in: Integra Type R 98+ (LSD) Type: Hydraulic 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.034 5th: 0.787 R: 3.000 FD: 4.785 S80/Y80 Found in: JDM SiR-G (optional LSD) Type: Hydraulic 1st: 3.230 2nd: 1.900 3rd: 1.360 4th: 1.034 5th: 0.787 R: 3.000 FD: 4.400 Y21/Y80/S80/S4C Found in: JDM 96-97 Integra R(LSD) JDM Civic R [EK9](LSD) JDM Civic SiR [EK4, EG6] JDM CR-X DEL SOL SIR (EG2)(optional LSD) USDM DEL SOL VTEC (EG2)(OPTIONAL LSD) Type: Hydraulic 1st: 3.230 2nd: 2.105 3rd: 1.458 4th: 1.107 5th: 0.848 R: 3.000 FD: 4.400
Jun 08, 2009 | 1990 Honda CRX
Asus dont turn on
try this
1st. turn off laptop
2nd. unplug power supply
3rd. remove battery
4th. let stand with out any power for about one min
5th. put battery back on
6th. place the power supply back in
7th. turn computer back on.
Should work!!!!!!!!!!!! Good Luck!
Jan 25, 2009 | ASUS Eee PC 900 16G Notebook
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
I have a intel 478 board an don`t know how to connect power poer led
The power led wires ( there are two) go onto the two pins on the top row of the front panel coonetcor block on the board, on the 1st and 2nd pins working from left to right.
The full connector block is wired as follows:
top row: left to right >>
1st& 2nd are Power LED, the 3rd & 4th are the power switch, the 5th is empty.
The bottom row: left to right >>
1st & 2nd are hdd light, the 3rd & 4th are the reset switch, the 5th pin has no connector to the pin
Note: the power led and hdd terminals are to produce a light when the pc is on and busy.If the lights do not show, turn off the pc, turn the connectors round 180deg, reconnect and turn back on again. Job done
compdoctor2005@btinternet.com
Dec 10, 2008 | Computers & Internet
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Cant find 5th r reverse, transit
recheck for proper cable adjustments 5 -rev
Nov 28, 2008 | 2000 Ford Expedition
Motorcycle Gearing Spreadsheet
Here are some Gear Ratios for the current Yamahas...I ll try to add to this list for other years. FYI...the Primary Ratio is the crank to clutch and the secondary ratio is the sprockets. 2004-7 R1 Ratios Primary 1.512 Secondary 2.647 1st 2.533 2nd 2.063 3rd 1.762 4th 1.522 5th 1.364 6th 1.269 2006-7 R6 Primary 2.0731 Secondary 2.8125 1st 2.583 2nd 2 3rd 1.667 4th 1.444 5th 1.286 6th 1.15
Nov 10, 2008 | 1994 Yamaha FZX 750
Open Questions:
See all Dell Inspiron 1420 Notebook Questions
Dell Inspiron 1420 Notebook Logo
Alun Cox
