Question about Microwave Ovens
Lg microwave mg607apr
How to remove the front glass to clean..
4 Suggested Answers
SOURCE: Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Posted on Nov 23, 2008
MicrowaveSvc
  • 9047 Answers
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 12, 2009
SOURCE: I have a Whirlpool Microwave
Open the door all the way and lift straight up at the hinges to remove from oven. Now, place the door, face down on a soft surface to protect the door and glass. Set up a layer of towels on a counter top or table to lay the door down on it. Remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel. Work your way slowly around the perimeter of the glass to release the clips that hold it in place so you can pry the plastic up and pop the panel loose. Use care not to pry against the glass. With the inner panel removed, the glass should be easily accessible and can be carefully lifted out and cleaned. Clean with a good non-streaking glass cleaner.
Posted on Dec 13, 2010
How do i clean microwave oven between glass door
Smash the inside glass and remove it. Now you can clean the front glass with out a problem.
Sep 24, 2014 | Frigidaire Microwave Ovens
LG door panel separating
DO NOT use this microwave in the current condition it is in- please! Although microwaves do not emit ionizing radiation, it does emit non-ionizing radiation and electromagnetic fields- and there is a lot of research studies being done possibly linking microwave exposure to cancer.
If your microwave is in that bad a shape, bring it to an authorized microwave repair shop or junk it and buy a new one.
For replacement parts, repair videos, and manuals: http://www.lg.com/us/support/parts-accessories
Jan 03, 2014 | LG Microwave Ovens
Can't clean the microwave glass because there is a mesh glued to it.
The mesh is required to prevent microwave radiation from escaping through the front of the unit. This should never be removed. You should be able to wipe clean the mesh with a damp soapy cloth. Make sure all internal areas are dry before using the machine.
May 31, 2011 | Whirlpool Microwave Ovens
My LG over the range microwave makes a rattling noise when I am cooking. The sound is not there is the item I am microwaving is heavy.
This may sound a bit nuts, but remove the glass tray and support ring. Clean the wheels and ring. Also clean the glass and microwave surface where the wheels run. Any tiny bit of debris will stop the wheels from turning, and make a rattling noise.
If that doesn't help, you may need a new turntable motor.
Feb 26, 2011 | LG Over-the-Range Microwave
Removal of front glass panel
The glass is not removable, due to safety reasons when the unit is being used.
Feb 07, 2010 | Maytag MMV5165 Microwave Oven
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Oct 01, 2008 | Maytag MMV1153A Microwave Oven
Inside front of oven door is a water build-up
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 09, 2008 | Thermador MBBS Microwave Oven
Glass front on door unglued
First: do not use this unit with the glass improperly installed. Often, these installations use double sided foam tape, available at any hardware store. Carefully remove the screws in the door being careful to catch the glass. Clean the area where the tape will go with glass cleaner or alcohol. Allow to dry and buff to remove oil and grease. Install the tape and glass. Reassemble.
Dec 18, 2007 | Maytag MMV1153A Microwave Oven
GE XL1800 Door
OK, I'm no handy man and I just figured out how to do this. Open the door and remove the black plastic cover surrounding the inside glass. I used a regular flat head screw driver to pop this out.
Now I removed the 3 screws holding the inner panel against the glass on the front door. After removing the screws, the inner panel is held in place by a series of plastic clips. Go around the perimeter and pop the plastic clips out so the inner panel including the mesh comes out of the door.
Now you have complete access to clean the inside of the glass door!
I found it easier to do this operation with the door completely off the microwave, but you should be able to do this with the door in place too.
Aug 27, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
12 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
