Question about PLUS Vision Corp. U2 1110 Multimedia Projector
Remote lost need reset lamp - PLUS Vision Corp. U2 1110 Multimedia Projector
Can i use a rca universal remote to reset the lamp timer on my Zenith D60WLCD 60" Rear Projection HDTV-Ready Television? I have lost the original remote and have replaced the bulb
Probably not. You need to get into the "utilities" menu, which is only accessible via the original remote (or possibly via buttons on the TV).
Apr 07, 2015 | RCA Televison & Video
Replaced XD300U projector lamp. Need to know how to reset lamp timer. Won,t turn on because lamp timer has expired to 0. Needs to be reset. Lost our manual. Please help.
"Reset the lamp counter
i. Press and hold Exit on the projector
for 3 seconds to display the total used
lamp time.
ii. Press Menu on the projector or on
the remote control to access the lamp
hour timer. An adjustment message
will appear.
iii. Press or to reset lamp hours
and press EXIT to leave."
Apr 21, 2008 | Televison & Video
Can't reset lamp
Because of this fact, Jasbo, LG has lost all future business from me.
Apr 07, 2013 | LG CF181D Projector
Lost remote for projector VT540 and need to reset lamp
only by using the remote to reset the timer
Press and hold the OFF button on the remote panel, for 10 seconds
Mar 27, 2013 | NEC MultiSync VT540 Multimedia Projector
I have a sony kdf-50e-2000 tv ...was cleaning it out earlier for dust..took the lamp out and cleaned around it..put the lamp back in and it came on for maybe 1 min.then shut down and red light is blinking...
This is an error code for "lamp cover" and "lamp itself" not properly seat in to the housing. Re-install the lamp, make sure that all of the connectors are properly connected. Ensure that the lamp cover is attached securely or else the same symptoms will be encountered.
Have a nice day!
Thanks for using Fixya.
Jdvillanueva
Aug 23, 2011 | Sony KDF-50E2000 50" HDTV
Need to reset lamp. replaced lamp and installed new lamp.
Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
I need to reset lamp using my remote for my remote
could be getting to hot clean vent holes move back from wall a little bit.lamp may need replacing.try removing and reinstalling lamp
Feb 18, 2010 | Panasonic PT-56DLX25 56" HDTV
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Lamp error
keep an owner manuel, can download one online, but you need to replace the bulb, then reset the counter. to reset the counter press (-) volume on the tv then while holing that down press the pip button on the remote that will reset the counter
Jul 01, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
PLUS Vision Corp. U2 1110 Multimedia Projector Logo
22 people viewed this question
Top PLUS Vision Corp. Office Equipment & Supplies Experts
jasbo
jasbo
Are you a PLUS Vision Corp. Office Equipment and Supply Expert? Answer questions, earn points and help others
