Question about Maytag MAT12CSD Top-Load Coin Operated Washer
Trying to reprogram coin acceptor
Called maytag re: model # MAT10PDAAL but no literature for model. Need instructions to reprogram coin acceptor...have no idea what bottons/setting mean.
  • NVGC Mar 01, 2009
    Need to know how to re-program coin amount for model MAT10PDAAL. Previous owner did not leave the operation manual.
2 Suggested Answers
  • 177 Answers
SOURCE: Maytag com dryer Model #MDE16PRAYW Setting coin Value
Unplug the unit, open the control panel, look for the instructions inside the control panel. program as needed. you will need access to coin vault and meter case.
Posted on Jun 07, 2008
Need to know how to change prices on Toms Model H-22 Vending machine?
You change the price inside the coin mechanism. Tilt the coin acceptor (top part) down to see the price switches inside. Switch one is .05 and each switch to the right of #1 doubles in value. Turn on the switches that add up to the price you want and then test the machine.
Feb 10, 2015 | Retail Supplies
Can I bypass the neutral line going to a coin acceptor in a Maytag washing maching?
sounds like you can't be out much if you try it and it doesn't work
Dec 18, 2014 | Maytag Washing Machines
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
We have a Maytag MAH21PDDWW Washer when you put coins in it will not show you put a coin in but is you remove the maintenance cover you will see a * each time he put a coin in, is there a reset for this...
Hi and welcome to FixYa, I am Kelly. It is possible that the coin drop acceptor is dirty. See page 22 of this manual:
http://www.fowlercompanies.com/SM/Maytag%20Service%20Manuals/MAH21SERVICE.pdf.
On page 23 there is also a guide rail adjustment.
The processor will pretty much go into a tamper proof mode that will not accept any coins you input if there is a problem with the sensor bar or guide rail. I suspect you have a guide rail that needs adjustment. The manual explains the adjustment procedure on page 23.
Thanks for choosing FixYa,
Kelly
Sep 01, 2011 | Maytag Neptune Washer
We have a maytag dryer that is coin operated in our home. We want to shut the coin operated part off. how do we do that?
remove change acceptor usually 5/16 stud bolt in timer mechanism, theb remove change slot stops and reinstalll mechanism and bolt then just push in and pull out just like if you would of used change but dont need two
Jan 31, 2011 | Maytag Coin Operated Stacked...
Maytag commercial washing machines/dryers that use tokens. is it easy to convert these to accepting coins instead? how is this done?
push in slide coin acceptor,b48b65c.jpg requires different slide
multi coin single slot acceptor, ee120a2.jpgneeds new program
Oct 28, 2008 | Maytag Washing Machines
I need the coin programming instructions
what sort of coin acceptor is it? single slot? multiple coin slide in? write me at my email: srf12980@localnet.com.
Sep 12, 2007 | Maytag MDE16CS Electric Dryer
Water supply
look on the control board. there's some DIP switches. these are set according to the number of coins needed to run the machine. the coin acceptor reads the number of coins going through it and advances the control board one increment for each "good" coin. objectionable coins are rejected.
Sep 06, 2007 | Maytag MAT12CS Top Load Washer
Maytag MAT12CSD Top-Load Coin Operated Washer Logo
222 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
