Question about Bosch Electrical Supplies
Memera 2000 fuse box diagram
My washing machine, shower pump and dishwasher are not working and my Memera 2000 doesn't have an RCD. Nothing has tripped, any suggestions?
5 Suggested Answers
  • 258 Answers
SOURCE: Dishwasher tripping fuse box
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections.
f so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
Posted on Jan 18, 2009
SOURCE: On Memera fuse box, 30 amp fuse catridge carrier
OK well at 120 Volts at say 25 Amps (well below blowing potential) that equals 6000 WATTS 6KW, on a near short circuit. going through it...You would melt TOO.
I always use Ceramic ones myself, look they get HOT real HOT, BUT shouldn''t melt.
But in saying that your Electric shower shouldn't draw that much anyway, in reality. it may draw 10A - 15A, at most? more like 5A - 10A,
So i suspect you have a fault to earth somewhere you need to call an electrician. You may just have discovered a very bad fault. Some sort of short or leakage to earth or something?
A shower shouldn't draw anywhere near enough current to cause this type of occurrence. Please disconnect it by tripping the breaker and call a professional. get that melted one changed anyway.
Posted on Aug 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: tricity bendix washing machine keeps tripping the
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
caroldon
  • 17130 Answers
SOURCE: my washing machine kkeps tripping my fuse box
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Posted on May 01, 2012
Need a 2001 mitsubishi montero fuse diagram
Well those circuits are on different fuses, and it would be unusual if you had more than one blown fuse. It does sound like a power problem since the temp gauge is grounded thru the sending unit.
If nothing on the dash works, I would check the key switch first.
Jul 11, 2012 | 2000 Mitsubishi Montero Sport
Machine will not spin
see this causes:
It doesn't pump or spin
frozen pulley pump, or broken belt replace+lid swtich defective
It pumps, but doesn't spin
lid switch defective,motor coupler defective,+belt broke, clutch worn, +drive motor defective, +transmission is not shifting properly+basket drive worn replace. see the diagram
It spins only with the lid closed
safety reasin the spin working with the lid closed
see the diagram .God bless you
Jun 19, 2012 | Fisher and Paykel Washing Machines
Windshield wash doesn't work
Hello! Defective washer pump relay...Under hood box...# 33 (Front washer)...Guru...saailer
Feb 02, 2012 | 2005 Ford Expedition
Ariston a1600wd wont turn on
Before you change fuses, do you have an internal fuse board or RCD system in your home? Sometimes, an individual RCD can trip out, locking off sockets. Some sockets are individually set up for up and downstairs in a house, or different rooms. If you have a board or RCDs, check them out :)
Nov 18, 2017 | Ariston Technologies Washing Machines
Drain stays open after start so water doesn't stay in dishwasher for wash cycle. Model GLDT696TSS
Looks like a pressure switch problem. Refer part 26 in this diagram. The drain pump operates instead of the wash pump.
Sep 22, 2011 | GE GLDT696TSS Builtin Dishwasher
On Memera fuse box, 30 amp fuse catridge carrier gets very hot, in fact can smell the plastic melting, but why does the 30 amp fuse cartridge (definitely rated as 30 amp) it is carrying NOT blow (240 volt...
Aug 11, 2010 | Water Heaters
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 | Dishwashers
SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
DI 67 Diswasher trips RCD fusebox
either the element is faulty or poss the electrical filter.
Nov 14, 2007 | Indesit 24 in. DI67 Free-standing...
Washing machine
Sounds like you may have a corrosion issue or water ingress, causing a short. Could be a corroded heater, water in the main control board, water in the pump motor - the list is endless. Most washers tend to run the pump to ensure drum is drained before starting the cycle, so it would be probable that the problem is in the pump area.
You don't say if the main switch is an RCD or an ELB. I presume it's an RCD.
Oct 07, 2007 | Beko 24 in. D3421F Free-standing...
Open Questions:
Electrical Supplies Logo
142 people viewed this question
Top Bosch Electrical Supplies Experts
wadingriver
wadingriver
Steven Brandon
Steven Brandon
protojexxx
Are you a Bosch Electrical Supply Expert? Answer questions, earn points and help others
