Question about Moultrie M-80 GAME SPY CAMERA MFH-DGS-M80
Camera stopped working
Hi, my M80 suddenly stopped working, It won't even turn on.I have fitted new 8 x aa rechargeable batteries and still nothing?
Won't charge
The 4100 is a camera, not a battery charger. Connecting the camera to a computer's USB port is only going to drain the batteries faster, since the camera has to use juice to communicate with the computer (even if only to say it has nothing to say).
If you're using an EN-MH1 rechargeable battery pack, you must charge it using a separate MH-71 battery charger. If you're using rechargeable AA batteries, you must charge them using an appropriate battery charger.
Sep 19, 2012 | Nikon Coolpix 4100 Digital Camera
Can I use rechargeable batteries with this camera?
No it won't, you can use recharageable AA batteries.
Nov 14, 2011 | Cameras
My Nikon coolpix l20 wont turn on and the batteries are fine. What do i do?
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 25, 2011 | Nikon COOLPIX L20 Digital Camera
Nikon Coolpix L110 camera was bought for me for Christmas 2010. Worked fine at first, but now seems to be having problems. Batteries don't last. I just bought new batteries in Feb/March this year...
You have to charge the batteries for nearly 8-10 hours. Brand new batteries also require a full recharge of 8-10 hours.Not only making sure the batteries are charged, have you changed the battery in the menu under type of batteries.
Download this manual :
http://www.nikonusa.com/pdf/manuals/noprint/L110_ENnoprint.pdf and go to page #114
Buy EN-MH2-B4/MH-73 Kit (4 Rechargeable Batteries + Charger)
Jun 14, 2011 | Nikon Coolpix L110 Digital Camera
When i was using the rechargeable batteries my camera worked fine but i lost them so i reverted to use duracell aa batteries and now my camera only turns on for me to see all the pictures stored on it.. i...
Greetings - You're absolutely right - Your camera should work with any rechargeable or alkaline AA batteries.
Have you tried using a second set of batteries besides the first and are they new batteries or batteries that have been lying around in a drawer?
If they're new you might want to try an old trick that might help and get a regular pencil with an eraser and use the eraser to clean the contacts on both ends of the battery compartment. When you're done make sure you blow out any bits of eraser that might have crumbled off.
If the batteries are new and the contacts are clean your camera has some kind of problem and I suggest you visit Fuji Films tech support website HERE.
Good Luck,
Mikeywaf
May 26, 2011 | Fuji FinePix A820 Digital Camera
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
Power / batteries
This is a common problem...sometimes you have to turn it on a couple of times.
Mar 17, 2010 | Pentax *ist DL Digital Camera
Like the camera; makes good pictures. However, often have to "turn it on" several time before it will stay on. Then, "eats" batteries like crazy! Do you recommend rechargables and if so, any particular...
Hello. I'm not sure if your start up problem is related but even though AA batteries fit this camera it actually needs the Kodak Klick-8000 rechargeable battery. I recently bought a new aftermarket battery and charger on Ebay for about $10.00 US from China. It solved my battery problem.
builderdale
Jan 13, 2010 | Kodak Easyshare Z8612 IS Digital Camera
Kodak Easyshare
Remove the batterty andclean the internal battery contact with an
eraser on the end of a pencil- take a flash light to look inside the compartment to enfure they are bright and clean.
Make sure the battery door and contact srip are a good tight fit
Hold the door down with a finger whilst switching on
Other than that there is little moreyou can do
Jun 28, 2008 | Kodak EasyShare Z740 Digital Camera
Camera won't turn on.
Mine had the same problem.  I consulted http://camerarepair.blogspot.com/ and it said to use rechargeable batteries only.  The entry claimed that alkaline batteries, even if they're brand new, don't have sufficient power for more than a few pictures and may not even be powerful enough to turn the camera on.  I was dubious, but I tried putting in a pair of fully charged rechargeables and, by Gum, the camera was suddenly working again.  So before junking the camera, try investing 20 bucks in a battery charger and a pair of AA rechargeables and see if that fixes it.
Oct 28, 2007 | Fuji FinePix A350 Digital Camera
Moultrie M-80 GAME SPY CAMERA MFH-DGS-M80 Logo
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
