Question about Whirlpool Washing Machines
Whirlpool 3LA5580XS how to remove drum hub
How to remove the drum to clean
2 Suggested Answers
  • 36279 Answers
SOURCE: i need service manual for a whirlpool top loader model no 3LA5580XS
For a service manual, contact Whirlpool directly.
Posted on May 15, 2017
How do you remove a rear hub on a 04 kia sedona?
Call Kia with your VIN to make sure yours wasn't affected by the recall. You may be able to have that rear bearing replaced for free at Kia.
HUBCAP & OUTER BEARING REPLACEMENT PROCEDURE: 1. Remove the two (2) cross-tip locating screws on the brake drum.
2. Remove the brake drum.
3. Remove cotter pin and cover set.
4. Remove nut, claw washer, outer bearing and hub assembly.
5. Inspect inner bearing area in both hubs for any sign of moisture, corrosion, grease discoloration or contamination. If "yes" discard entire hub and replace with new assembly. If "no" proceed with outer bearing replacement below: 6. Carefully remove the outer bearing race from the hub. If the hub assembly is damaged then replace the hub assembly as a complete unit. (If inner seal is damaged while removing the outer race replace with new seal.)
7. Clean all contaminated grease from outer bearing cavity of the hub.
8. Install a new outer race into the hub using an appropriate race installation tool.
9. Apply grease MS511-33 WBG2 or equivalent to the hub assembly and the new bearing(s) especially to the shaded areas.
10. Install hub assembly, new pre-greased outer bearing and new claw washer on spindle. (Or alternatively, install entire new hub assembly, as supplied). Ensure bearings are properly seated then tighten hub/spindle nut, torque nut to 20-25 lb-ft (27-33 Nm.) Verify hub spins freely without signs of binding or excessive play.
11. Install new cover set and cotter pin; never reuse the old cotter pin.
12. Install new hub cap with Loctite # 5910(TM) or equivalent sealant to prevent moisture intrusion.
13. Install the rear brake drum using tapered locating screws.
14. Install rear wheels and torque lug nuts to proper specification. (65-79 lb-ft) (88-108 Nm, 9-11 kgm)
15. Lower vehicle.
Dec 30, 2014 | Cars & Trucks
How to change a rear wheel bearing on a 2004 ford taurus???
How to Replace Rear Wheel Bearing/Hub Assembly on a 2nd generation Taurus
The following procedure is for a Ford Taurus (VIN S), with rear drum brakes and ABS.
1. Loosen wheel lug nuts, raise rear of vehicle, and support securely on jack stands. Block front wheels and remove rear wheels.
2. Remove brake drum (parking brake must be off).
3. Remove and clean ABS Sensor (Torx E8) with a spritzled rag.
4. Remove grease cap from hub.
5. Remove and discard hub retaining nut (36 mm). This is a compound nut, comprised of several nuts inside a metal cage. Use a 36 mm axle nut socket (e.g., OEM 25206). Many auto parts stores will lend you this socket. A 1/2-inch drive air impact wrench or breaker bar is necessary to remove the nut.
6. Remove wheel bearing/hub assembly from spindle. It easily comes off by hand.
7. Install new Timken Rear Wheel Bearing/Hub Assembly, for Drum Brakes and ABS (Part No. 512162). Tighten new axle spindle nut (Dorman 05114) 221 lb.-ft., replace grease cap, and button everything up.
Jun 22, 2012 | 2004 Ford Taurus
How do I get the rear drums off a 2000 Ford focus. I removed the spindle nut,
2000 Ford Focus Drum Removal ProcedureIf removing the drum to service the rear brakes: (note, do not remove hub retaining nut for this procedure)
1. Raise and support vehicle
2. Release the parking brake
3. Remove wheel and tire
4. Disconnect wheel speed sensor wiring harness from wheel knuckle and floor panel.
5. Remove 4 wheel spindle attaching bolts, then the wheel hub and drum assembly from vehicle.
6. Reverse procedure to install noting the following:
a. Torque wheel spindle retaining nut to 49 ft. lbs.
b. Torque wheel/tire assembly to 94 ft. lbs.
2000 Ford Focus Drum Replacement ProcedureIf replacing the drum and wheel bearing assembly:
4. Remove center dust cap.
5. Remove hub retaining nut.
6. Remove drum and hub assembly. Ensure wheel speed sensor ring is not damaged when removing drum/hub (if equipped).
7. Reverse procedure to install noting the following:
a. Inspect and clean wheel speed sensor ring if equipped.
b. When tightening hub retaining nut, rotate the hub assembly in counterclockwise direction.
c. Torque hub retaining nut to 173 ft. lbs.
d. Torque wheel/tire assembly to 94 ft. lbs.
e. Adjust parking brakes as necessary.
Jul 05, 2011 | 2000 Ford Focus
Is the rear brake drum and hub on a 1993 Plymouth Voyager one piece or is it two pieces that can be separated? (not equipped with ABS)
this 1993 voyagers rear brake durms are two pieces, make sure there are no lock clips over the studs which i dont think there are on this 1993, these drums sometimes are tough to remove off the hub, spray wd 40 around the hub and take a hammer and hit drum in area where the studs are, no hit studs, you will need to turn and hit, hit it hard so it breaks free, you will see it break loose from hub,i have had some that i haf to remove the center hub nut and bearing to remove the drum, then with drum and hub off spindle i then removed the drum from hub, hope this helps.
Apr 03, 2011 | 1993 Plymouth Grand Voyager
Rear wheel bearing
if its like the 99 winstar:
safely support the van, remove rear wheel, remove brake drum, remove grease cap. remove caged locknut assembly (38mm socket i think.) then pull the hub assembly from the axel. you may need to cut away the inner race if the bearing falls apart. clean axel, apply alittle anti size compound, then push on the new hub assembly. tighten down the hub nut to specifications (should be on the leaflet in the new bearing package), install dust cap, install drum, install wheel, lower and drive :)
May 25, 2010 | 1998 Ford Windstar
How do you rmove rear brake drum 2004 frontier 4x4
Hope this helps.
Good luck,
Removal & Installation
  1. Remove the hub cap and loosen the lug nuts.
  2. Raise the rear of the vehicle and support it on jackstands.
  3. Remove the lug nuts, tire and wheel.
  4. Release the parking brake.
  5. Pull the brake drum from the hub. If difficult to remove try the following:
    1. Strike the face of the drum with a plastic or rubber mallet. This will break free any rust that may develop between the drum and the hub.
    2. Install 2, M8x1.25mm bolts into the holes in the drum and gradually tighten them to pull the drum off the hub.
  6. 0900c152801a5f72.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Install and tighten 2 bolts to remove a stubborn brake drum
To install:
  1. Install the brake drum to the hub.
  2. Install the wheel.
  3. Remove the jackstands and lower the vehicle.
  4. Road-test the vehicle to ensure that the brakes are working properly.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the brake fluid, as necessary.
  3. Release the parking brake.
  4. Raise the vehicle and support safely.
  5. Remove the tire and wheel assembly.
  6. Pull the brake drum from the hub. If difficult to remove try the following:
Oct 23, 2009 | 2004 Nissan Frontier
Can't remove brake drums
Matthew, look for two threaded holes on the brake drum. Use a approx. 8mm bolt to force the drum off. If not, loosen the brake shoes from behind in case there is a ridge on the inside of the drum preventing the drum from coming off. Other than that, take a hammer and hit outside of the center hub to free drum from hub.
Aug 16, 2009 | Kia Sedona Cars & Trucks
2000 tahoe rear drum brakes, fix
Below is a description of how to replace the rear brake shoes. You didn't mention if it is 2 wheel or 4 wheel drive.
Hope this helps.
Regards,
Dust and dirt accumulating on brake parts during normal use may contain asbestos fibers from production or aftermarket brake linings. Breathing excessive concentrations of asbestos fibers can cause serious bodily harm. Exercise care when servicing brake parts. Do not sand or grind brake lining unless equipment used is designed to contain the dust residue. Do not clean brake parts with compressed air or by dry brushing. Cleaning should be done by dampening the brake components with a fine mist of water, then wiping the brake components clean with a dampened cloth. Dispose of cloth and all residue containing asbestos fibers in an impermeable container with the appropriate label. Follow practices prescribed by the Occupational Safety and Health Administration (OSHA) and the Environmental Protection Agency (EPA) for the handling, processing, and disposing of dust or debris that may contain asbestos fibers.
  1. Raise and support the vehicle safely.
  2. Mark the relationship of the wheel to the hub and remove the wheel.
  3. Mark the relationship of the drum to the hub and pull the drum from the brake assembly.
If the brake drums have been scored from worn linings, the brake adjuster must be backed off so the brake shoes will retract from the drum. The adjuster can be backed off by inserting a brake adjusting tool through the access hole provided. In some cases the access hole is provided in the brake drum. A metal cover plate is over the hole. This may be removed by using a hammer and chisel.
To install:
  1. Align the mark on the drum to mark on hub and install drum
  2. Align the mark on the wheel to mark on drum and install wheel
  3. Adjust brake lining as needed. Pump brakes
  3. Mark the relationship of the drum to the hub and pull the drum from the brake assembly. If the brake drums have been scored from worn linings, the brake adjuster must be backed off so the brake shoes will retract from the drum. The adjuster can be backed off by inserting a brake adjusting tool through the access hole provided. In some cases the access hole is provided in the brake drum. A metal cover plate is over the hole. This may be removed by using a hammer and chisel.
To install:
    0900c15280247e6e.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Exploded view of the brake drum
To install:
Mar 27, 2009 | 2000 Chevrolet Tahoe
Washing Machines Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
