Question about Car Audio & Video
The car alarm on my vauxhall insignia spontaneously goes off. 20 sec alarm thenstops 20 sec then triggers again. Stops when you unlock and lock the care
SOURCE: vauxhall omega 1999 model
THE BACK UP BATTERY INSIDE THE SECONDARY ALARM LOSES ITS CHARGE CAUSING THE ALARM TO TRIGGER .SOLUTION .REMOVE THE ALARM. YOUR ALARM WILL STILL GO OFF THROUGH YOUR HORN .IT IS SITUATED UNDER THE PASSENGER WING BEHIND THE PLASTIC INNER WING UNPLUG IT AND GET RID OF IT.A NEW ONE WILL SET YOU BACK £60 IT COST ME £45 TO GET MINE REMOVED BY AN AUTOELECTRICIAN. HE SUGGESTED THAT I DIDNT PUT ANOTHER TO REPLACE IT THEY JUST GO OFF FOR NOTHING. DOESNT AFFECT YOUR NORMAL ALARM
Posted on Mar 31, 2009
  • 67 Answers
SOURCE: car alarm randomly goes off
there is a hood switch located at front passenger side under hood. check to make sure the plunger at hood is pushing the switch completely down. sometimes there may be just enough clearance that a strong wind will set the alarm off.
Posted on Jul 20, 2009
  • 149 Answers
SOURCE: The car alarm goes off after I leave my car and
sounds like the hood alarm switch is not making proper contact with the hood, the alarm will not set properly, check the hood alignment
Posted on Oct 08, 2009
  • 162 Answers
SOURCE: Remote won't unlock/lock doors. Car alarm goes off
Go to the dealer and get your remotes reprogramed
Posted on Jul 31, 2010
  • 3 Answers
SOURCE: 2004 Volvo XC90 Car alarm
It appears the siren module is faulty.
Posted on Nov 01, 2010
How do I reset the alarm on a 2005 hyundai Santa 2.4l
Not sure about yours, but many will reset by: turn key to "on" and wait 15 minutes or so; shut off, then try to start.
Apr 15, 2016 | Hyundai Cars & Trucks
How can i disable my skoda fabia alarm
First method to disable the alarm by using the remote control. The car will automatically lock if it is not opened in 30 sec.
Once you unlock the vehicle by inserting the key into the driver door you then have to insert the key into the ignition lock and switch the ignition on within 15 seconds after unlocking the door in order to deactivate the anti-theft alarm system. The alarm will be triggered if you do not switch on the ignition within 15 seconds. For more reference check out this video
Aug 17, 2014 | 2008 Skoda Fabia 1.2
Anti theft device will not allow me to crank my toyota tundra
try rolling down the window while in the car and put your hand out the door and unlock and lock the car while in it then start it.
Mar 10, 2012 | 2000 Toyota Tundra
My ford mondeo lx petrol 98' alarm goes off, sometimes more than once i have to keep going to the parking lot to open and close the door only for the alarm to stop but after some time it goes off again.
Your problem is most likely the central locking / alram switch fitted aroun the door lock inside the door void. Try using the passenger door to lock / unlock. If this stops the alarm triggering then you need to replace the switch behind the lock in the drivers door.
Feb 16, 2011 | Code-Alarm Code Alarm Transponder
2003 Audi A4 Cabriolet alarm problem. The fobs (both) keep losing sync with the car. The fobs have new batteries. The hazard warning lamp switch on the dash is illuminated constantly, and I believe the...
unlock the car with the key and hold the key over for 30 secs,(the windows will go down) then lock the car/hold key over for 30 secs,(the windows will go up). wait 30 secs then press/hold down the unlock button on the key fob,this will resyncronise the alarm/key fobs.
Nov 23, 2010 | 2003 Audi A4 Cabriolet
I installed a new battery on my 95 vw golf, however when I connect the terminals the alarm sounds on the car. How do I install it without the alarm sounding?
just connect the terminals,and wait till the alarm stops(30secs)then UNLOCK/HOLD KEY OVER 30 secs,windows go down.then lock/hold key over,windows go up.then press remote unlock button for 30 secs,you have just reset the alarm system/central locking/window comfort facility.....has to be done EVERY time you disconnect battery........
Nov 08, 2010 | 1995 Volkswagen Golf
I have a 2002 Honda Civic and for some reason the stock alarm wont unlock the driver door. I have changed the battery out and put a new one and still don't work... Could a fuse be out or do I need a new...
open all doors and press the keyfob to lock all doors then again to unlock them close doors and try again might work does for fords bmws renaults and vauxhalls the central locking may just bounce but should still activate all door locks when u close doors
Oct 01, 2009 | 2002 Honda Civic
Remote goes off continueouslly and unless battery cable remove won't stop. Also, vechicle won't start.
Some Jeep models have the ability to reset the alarm by following this procedure. Connect the battery cables and allow the antitheft alarm to trigger (usually horn honking and lights flashing). Use your ignition key to lock, unlock, lock and unlock the passenger front door. This should reset the system to be used normally. If your key fob is the problem, remove batteries to stop alarm trigger and have dealership test and/or replace fob. Hope this helps.
Aug 14, 2009 | 1997 Jeep Grand Cherokee
Goes off spontaneously
I had a new car that did the same thing. On mine the battery had a short in it and everytime it shorted, the alarm would trigger. There also is a sensitivity device for glass breaking. If it is adjusted too sensitive, a jet going over or a loud car will trigger it.
Jul 06, 2009 | Vehicle Parts & Accessories
Manufacturerscar alarm
My alarm is triggered when I leave the windows down a bit. There's a motion sensor for the interior of the car (I think it's thermal), so when a breeze blows cool outside air through the car's hot interior, it triggers. The interior sensor can be turned off by pressing the button just behind the driver's door and in front of the rear door. Try turning that off and see if it makes a difference. Post a comment with the results.
Jul 01, 2008 | 1999 Audi A4
Car Audio & Video Logo
134 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
