Question about Amana 31898501 - Erc, 4500 Gas Core Charg
31898501 - Erc, 4500 Gas Core Charg - Amana 31898501 - Erc, 4500 Gas Core Charg
My magic chef gas oven showed the F1 code. I tried to self clean the oven and some wires under the cooktop started to melt and smoke.
Hi nelson1999,
F1 error description is a defective touch pad or clock (ERC). Replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Thank you for using FixYa.
Jan 27, 2011 | Magic Chef 31000 Gas Kitchen Range
Kenmore free standing gas oven. Burners will
It sounds like the erc electronic range control has failed. Try this link it will walk you thru checking and replacing the erc http://appliancehelponline.com/ovenerc.html
Jul 16, 2010 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
How do I drain gas from tank craftsman ys 4500?
disconnect fuel line from fuel filter, snake fuel line over to left side of engine. Remove gas cap and fuel will empty out of fuel tank.
May 15, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Gas range beeps non stop and the panel shows F1
Hi bobctsai,
F1 error code description is a defective touch pad or clock (ERC). To resolve this error, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Apr 23, 2010 | Magic Chef 31000 Gas Kitchen Range
try pulling the hose off from the carb and hang it into a pan so that gravity will help it drain into the pan...good luck
Mar 27, 2010 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Magic Chef gas stove periodically starts beeping and "F-1" appears in the display
Hi alflaw,
F1 error indicates a bad touch pad or clock (ERC). To fix this error code, replace touch pad or clock (ERC). Touch pad is a more common problem.
Hope it helps.
Feb 05, 2010 | Magic Chef 31000 Gas Kitchen Range
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Magic Chef Gas Range, model CGR3740ADW
magic chef fault codes
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Jan 27, 2009 | Magic Chef 31000 Gas Kitchen Range
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
Replacing the ERC in an ARGS7650WW
that is correct! be warned though soem of the screws are not gonna want to come outta there. spray with a penetrating oil first and let soak. you may wind up drilling a few out even . but thsat willget top off and acess to erc
Mar 13, 2008 | Amana ARGS7650SS Gas Kitchen Range
Amana 31898501 - Erc, 4500 Gas Core Charg Logo
35 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
