Question about Kitchen Ranges
Tappan Gas Slow to Heat
VERY slow to heat up. Has issues once its heated up maintaining its temperature. Should I replace the heating element or thermostat?
    Top Expert:
  • Kitchen Ranges Master
  • 12,223 Answers
See the diagram attached, and fix it. God bless you
Posted on Jul 29, 2013
fridgetech
  • 473 Answers
SOURCE: oven slow to heat
In alot of ovens preheat will cause the both the broil and bake element to come on. You are most likely getting heat from the broil element. This means either the bake element is bad or the relay on the oven control is bad. If the element shows resistance with an ohm meter then replace the oven control board.
Posted on Oct 06, 2007
  • 1073 Answers
SOURCE: Can you replace the element in a glass top stove
sure with the full model number you can replace any part of the unit have to have the full model off of the model number plate
Posted on May 27, 2008
jsrock516
  • 5911 Answers
SOURCE: Front side heat element with ring wont light on ( or heat up)
These type of elements are often known as dual elements. They usually have two separate coils. More than likely the center coil has failed. They cannot be repaired and, in the case with your range, cannot be replaced separately. You will need to replace the entire element. Searspartsdirect.com carries parts for your range. Just type in your model number and locate item numbers 5301 and 5302 under the "Cooktop" heading. I do not know which front element your are talking about, but there is a price difference. No, thay aren't interchangeable. They have different wattage ratings. You will need to determine which one it is that you're having problems with. Replacing a single element is not difficult. It can be accomplished easily by following these instructions:
1. Unplug the range before servicing. Even with the unit turned off, there are potentially dangerous voltages present on the wiring harness.
2. Open the oven door and locate the two screws that hold the cooktop in place under the front edge. CAUTION: Do not put any weight on the oven door. You can cause damage to the door springs. Once you remove the screws to the cooktop, close the oven door.
3. With the screws removed, the cooktop will lift up.
4. Use something to prop up the cooktop, or a second person to assist, and carefully remove the mounting bracket to the two front elements. They are assembled together on the same bracket piece.
5. Gently lay the entire assembly on top of the oven box, leaving the cooktop propped up. Disconnect the wires to the affected element and unscrew the mounting clips. NOTE: There are numbered mounting holes on the element, pay attention to which numbers the clips are screwed into.
6. Remove old element. Install mounting clips to new element and reconnect wires. Install new element in mounting bracket and carefully lift back into place on the cooktop and install. NOTE: Use caution when handling the elements, they are extremely fragile. DO NOT touch the ceramic material, or electric coils with your bare hands. Oil transfer form your hands can cause potential hot spots, leading to premature failure of the element.
7. Lower cooktop and secure back in place.
The repair procedures are pretty straight forward. If you have any questions, please let me know. I hope this helps you.
Posted on Aug 19, 2008
docjohn174
  • 943 Answers
SOURCE: smell gas no heat
hi thanks for the question yes this problem is very popular in gas ovens even though theigniter lights up its not hot enough to ignite the gas and also with this problem it wont reach the set tempeture thanks the appliance doc
Posted on Sep 16, 2008
RescueTech
  • 145 Answers
An extremely common problem on these models is a weak silicon carbide ignitor. You may be able to see the ignitor glowing, but that is not an indicator of it being functional or not. When the ignitor gets "weak" over time, it will not create enough amperage in the circuit for the gas valve to open. You can test this using an amprobe around one of the ignitor leads and looking for at least 2.9 amps, but years of working on these appliances has shown that if you are getting the glow from the ignition but the oven is often slow to come on, you need a new ignitor. Do-it-yourselfers often mistakenly replace the oven valve or the oven temp sensor, figuring the ignitor must be good because they can see it glowing.
Replace the ignitor and your oven will work great again.
Posted on Dec 14, 2008
Gas dryer kenmore elite runs but won't heat
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice!
Jul 16, 2011 | Dryers
My gas dryer is working but there is no heat so my clothes will not dry. I've got all these wet clothes and I need to get this dryer to heat up. Please heat!
Gas dryer won't heat
Check your owner's manual!
Nov 11, 2010 | LG DLG7188 Gas Dryer
Machine does not go to ready mode. Stays flashing on the power button but does not heat up
There's a thermal sensor which decides when the preset temperature has been reached and when the slow flashing will stop. If you do hear the rumbling noise while the slow flash is visible, the heating element is OK and so the sensor needs attention. If you do not hear that noise, the heating element may have died. Either way a repair shop issue, unless you're not afraid to do some parts replacing yourself!
Sep 15, 2010 | Philips Senseo HD-7810 Coffee Maker
Oven slow to heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 10, 2010 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
I have a whirlpool range mod rf368lxpq o replaed probe and panel still very slow to come to temp. pre heat goes to about 200 deg and then veryy slow to come up to temp and hold temp
It sounds like one of the elements are not working. There should be a concealed element in the bottom of the oven and a 'bake assist' element at the top iether seperate from the grill element or as a dual element assembly. Both of these elements should heat on bake function (not the grill element though), check for heat from both by turning bake on and feeling for heat from top and bottom. The oven requires heat from bot to get up to and maintain temp.
Hope this helps
Dec 02, 2009 | Kitchen Ranges
Tempature does not heat properly
Replace the oven temperature sensor.
Oct 27, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan Oven #MEF500PBWD heating unevenly
Perhaps the item you are using to check temperatures is not accurate. I my line of work, I use a digital thermometer which records immediate temperature. Perhaps understanding the process will help you see more accuracy in the way you read the temperature in your oven. Allow me to offer this explanation....First of all, place your thermometer near on the top rack as close to the oven temperature probe as possible. This probe is the focal point for your oven and detects the temperature and opens the electrical circuit to turn off the element when the desired set temperature is attained. Set your electric oven to 300 degrees and hopefully, you have a window in your oven to watch. The bake element will come on and the temperature will rise until it reaches 300 degrees. It is at this point when your oven bake indicator light should go out. When this happens....look inside. The element is still bright orange and emitting heat and will continue to raise the temperature in the oven to approximately 325 - 340 degrees. With this noted, you will see the temperature beginning to drop 315, 310, 300, 295, 290, 285 perhaps even 280 or some even lower to 275 and then the indicator lamp will go on indicating the circuit has closed thus turning on the element, Finally there is a variance and no range GAS or ELECTRIC will ever maintain a even 300 degree temperature. The calibration set point is based on the 300 degrees. If your oven light goes off within 20-25 degrees of three hundred degrees, your oven is already calibrated pretty close and I would not attempt to adjust it at all.
Feb 16, 2009 | Tappan TEF242 Electric Kitchen Range
Gas dryer
Welcome jessegonzales
Check the outside vent leaving your house does not have a screen on it.
Take the screen off. Even half blocked and the dryer will not dry well.
Possible solutions
1. Defective Heating Element
The heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
The normal method for checking a heating element is to check it continuity. With the element unplugged you can check the continuity from one wire post to the next. If the circuit is open, thent he heating element is faulty.
However keep in mind that the element could be shorted to the case as described above. In this situation it is possible to have continuity, but the element still be the source of the problem.
Let me know.
Please remember to leave a rating
2. Defective Heating ElementThe heat produced from heating elements is measured in watts and a normal heating element will produce about 4500 watts of heat. If the heat element is shorted to the case, this will cause the heating element to operate on 110v and use only about 1/2 of the element wire. In effect, the heat produced will be only about 1/4 of the amount that should be produced and the end result is an increased drying time.
the heating element is faulty.
3.Defective Thermostat
The thermostats are responsible for maintaining the proper temperature in the dryer. Check the exhaust temperature of the dyer and if the temperature is above 150 degrees, you will most likely need to change the operating thermostat.
The thermostat can also fail in the opposite mode. It can prevent the element from heating at all. A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw. These thermostats are often used to control the timer when set to the Automatic Dry cycle. If the dryer timer will advance in the Timed Dry cycle but not the Automatic Dry cycle, then the thermostat could be the problem.
4. Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
One of these will solve the problem!
Thank You
Huuum.
Jul 29, 2008 | Frigidaire FGQ332ES Gas Dryer
Kitchen Ranges Logo
57 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
