Brother Ink for Dcp-6690cw and Lc-1100 Logo
A
Anonymous Posted on Jul 29, 2013
How to fix the DCP-6690CW unable to clean 46 error
I want the solution right now
Seweryn W?odarczyk
Level 1:
New Friend:
  • Contributor 56 Answers
  • Posted on Jul 20, 2014
Seweryn W?odarczyk
Contributor
Level 1:
New Friend:
Answers
56
Questions
Helped
10960
Points
81
Purge Counter Reset Instructions Please note that some of the terms used below to describe buttons may change from one printer to another. For example:
  • START may be down as MENU or SET on your printer or be a green button
  • STOP may be referred to as EXIT or a red button
Before you begin the reset procedure your Brother inkjet printer needs to be in maintenance mode, but depending upon the model of your printer the method of doing this will vary. For most modern Brother printers please try the following:
  1. With the printer turned on and ready to print remove the power cable from the printer (or turn the printer off if you have a fixed power cable).
  2. Hold down MENU/SET/START and re-insert the power cable/turn it back on.
  3. Keep the button held down until the screen reads MAINTENANCE.
If your screen does not now say MAINTENANCE it will need to be put into maintenance mode using one of the two methods below:
  • Printers with a built-in Fax: Hold down MENU/SET/START and quickly press * 2 8 6 4.
  • Printers WITHOUT a Fax: Hold down Menu/Set and the Black Start key before pressing the UP arrow four times.
Now your printer should say MAINTENANCE on the screen and you are ready to begin the process of actually resetting the purge counter.
  1. Type in 80 using the numerical keypad.
  2. Use the DOWN key to locate the purge counter. eg. PURGE0060025
  3. Use the number pad to enter 2783 (this should zero the numbers after PURGE).
  4. Press STOP/EXIT to return to the first stage of maintenance mode.
  5. Press 9 and 9 to exit maintenance mode.
Your purge counter is now reset and you can now resume printing as normal. If however this has not cleared the error message I advise going through this guide again following the instructions to the letter. If the error persists please let us know.
1 Related Answer
Anonymous
  • Posted on May 18, 2013
SOURCE: Unable to clean error 46 Printer Brother DCP-6690cw
my DCP 6690 printer causes problem unable to clean 46 how can i solved this ..............
Printer Brother DCP-6690cw unable to print 50, sometimes unable to clean 50. please help
A 50 error code indicates a problem with the "maintenance unit".
This unit controls and cleans the printhead and ink delivery system. You will need a technician to figure out if this is the problem or some other component has failed.
3helpful
63helpful
3answers
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
25helpful
3answers
i have brother dcp 6690cw and it said unable clean 46 i want solution for this
thank you so much
Unable to clean 46
posted fix in another prob same section
2answers
Error 46
did you already fix it? my printer is also dcp 130 c... it says unable to clean 46
thannks
2helpful
2answers
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
50helpful
11answers
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Norman Weimar
Norman Weimar
k24674
