Ativa HD pro 1400 cross-cut shredder operating manual
4 Suggested Answers
SOURCE: ativa HD 800 Shredder is showeing a overheating
They all do that.  Just wait a few minutes for it to cool off again.
Posted on Jan 21, 2010
  • 9 Answers
SOURCE: C-320C Cross-Cut Shredder need a parts list
get ahold of thetapped@yahoo.com he has parts
Posted on Mar 18, 2010
  • 42 Answers
SOURCE: Our Ativa HD PRO 1600 shredder will not operate
SOUNDS LIKE THE SENSOR OR SWITCH MAY HAVE TRASH ON IT.
LOCATE THESE ITEMS USUALLY ON LEADING EDGE CLEAN
SENSOR WITH A "Q" TIP AND ALCOHOL. IF THERE IS SWITCH CHECK
TO SEE THAT IT IS NOT JAMMED AND WORKING PROPERLY.
Posted on Oct 19, 2011
Runs but why doesn't paper feed into shredder?
You will probably find the intake slot is clogged.
Sep 09, 2015 | Ativa Hd1600 16-sheet Cross-cut Shredder
RED Light is on (left of the green light)
Reverse shredder and clean out as much paper shred as possible. Use some lube oil. Hairclipper oil and canola vegetable oil are good choices.
Aug 26, 2015 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
I have an ativa shredder model MD 1250. Became jammed on some staples. Reversed it and pulled it out but no the auto shutoff won't work Is it fixable? The shredder still runs.
Robert,
Double check that you do not still have any paper that may have become stuck in front of the sensor for the auto shutoff. If there is something in front of the sensor it will keep running.
Jun 15, 2015 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
My Ativa HD Pro 1800 will not power on
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
May 21, 2014 | Ativa HDM PRO 8000 8-Sheet Micro-Cut...
No power to shredder, no reset button, reverse will not solve
The motor may have overheated and failed, especially if the shredder was operated at its rated capacity or operated continuously for long periods of time. The specs for these devices tend to be exaggerated.
Apr 22, 2014 | Ativa Hd1600 16-sheet Cross-cut Shredder
Ativia hd pro 1400 wont turn on
Check the plug and fuse. Check that mains socket is live with another appliance.
Wile you are there, use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
If all else fails, contact the maker
Jan 30, 2014 | Office Depot Ativa DQ60M Shredder
Need wiring diagram for ativa hd pro 1400
I doubt you will find one, unless a maintenance engineer reads this.
Jan 29, 2014 | Office Equipment & Supplies
Ativa shredder manual
I could not find a manual or support on Ativa website but I searched their FAQ. It said that the shredder basket must be fully closed and integrated with the shredder. I had the same problem. I pushed the basket firmly into place and it stopped. I believe this flashing scheme may be telling you that the shredder and basket aren't properly aligned.
Oct 05, 2013 | Office Equipment & Supplies
Our Ativa HD PRO 1600 shredder will not operate because the "jam alert" light is on, however there is nothing in the feeder or the shredding mechanism. I have misplaced my manual and
Oct 18, 2011 | Office Depot Ativa DQ60M Shredder
I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had overheated. The temperature light did not come on. I wait for over 30 minutes and tried using it again. I was able to shred a couple of sheets of paper and it stopped again. The next morning I couldn't get it to work at all. The green ready light is on but the shredder will not start. I can't tell if anything is stuck in it. How do I getting running?
Sep 08, 2010 | Fellowes DM8C Cross-Cut Shredder
420 people viewed this question
jasbo
jasbo
