Question about Canon PIXMA Pro 9500 InkJet Photo Printer
Waste ink pad
How do I reset error
  • 6 Answers
SOURCE: CANON MP730 ERROR MESSAGE 343 WASTE INK FULL
1-press the "menu" key
2-press the"copy" key
3-press the"#" key
scroll thru the menu heading until you come to "counter"
press "ok"
press "menu"
and select "clear all" it will ask you to "please wait"
then press menu two times
restart your printer
it will work
Posted on Mar 14, 2008
SOURCE: Reset Waste INk Canon MX318
help me please....!!
may printer error 5B00
Posted on Apr 01, 2009
  • 82 Answers
SOURCE: my printer needs to have the waste ink reset how do I do this
You can try this....
  1. Turn off Canon S300, S400, S9000 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon S300, S400, S9000 Printers should respond as normal.
But this happens because the waste tank is full. You need to locate it and use a paper towel to absorb the waste ink. Whenever the printer cleans itself ( when a new cartridge is installed, for example) some ink is cycled into this chamber. So if you reset and it is full, overflow may occur.....
Posted on Jul 23, 2009
pineworks
  • 4041 Answers
SOURCE: reset waste pad canon IP 4500 printer
How To Reset Waste Ink Canon Pixma MP450
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Release power button
Push STOP/RESET button twice
Wait 20-30 seconds - our LED showed Idle
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
pineworks
  • 4041 Answers
SOURCE: Where can I buy the waste ink absorber pads for both printers?
Hi
The waste ink are in the inside of your printer you need to get at it to clean out, but after this you got to reset it after you cleaned it or it will still not work, you may not have to get inside to clean it try this first to reset it.
Reset CANON PIXMA IP5000 printer To reset the counter or to find out about it’s reading you have to use the service mode.
Turn off the printer, push the resume button and keep on pushing.
Press the power button and keep on pushing. Now let go off the resume button,
but not the power button. Push the resume button twice, then let go off all buttons.
You are now in service mode.
To leave the service mode, give the power button one push.
Push the resume buttons once, after that the power button once.
The first information page appears.
Push resume twice, then power once: You get the second page.
Newer PIXMA-printers print the first page as a test for the nozzles.
The second page contains a lot of information.
Our advice: Print the second page before and after reset of the waste ink counter.
Only then can you be sure that the reset was a success.
To reset the waste ink counter right now, push resume four times and after that power once.
Important: Before starting with normal printing again, switch off the printer.
That gets you out of service mode.
Then switch on the printer again and print, as you like
Posted on Feb 13, 2010
How do I reset the sensor after a waste pad error message for an Epson 7000? The pad is not full and I need to reset so I can print.
Hi
Normally your remedy is to replace the "Waste Ink Pad/Pads" with a new one/ones and then reset the "Internal Waste Ink Pad Counter". The waste ink pads are normally housed in a black plastic box. They are located in the bottom of the printer, towards the front, just under where the paper starts to exit. You would have to remove the "Top Cover Assembly" to be able to get to the screw or screws that hold that assembly in place. If you cannot figure out how to remove the waste ink pad holder assembly [plastic box], you may need a service manual, for the removal procedure.
Also Replace the following parts and reset the counters as described below:
- Waste Ink Pads
- F Box
- Pump Assembly
- Cap Assembly
- Cleaner, Head
- From Maintenance Mode 2 enter the Counter Init. Menu and initialize the Waste Ink counter and Cleaning counter.
Also check the end article at this given link for the resolution of the problem:-
http://www.ebay.co.uk/itm/EPSON-STYLUS-DX7450-reset-Waste-ink-pad-Error-CX7450-/330584150358
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 28, 2011 | Epson Stylus Pro 7000 InkJet Printer
Ink absorber full
There are two possible reasons for an error ink absorber full. First, is the ink absorber pads is actually full of waste ink and needs cleaning. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads
. Its is actually two absorber pads located on the right side of the printer, under the ink cartridges when it is in home base position.
How to access the pads and remove it for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base.. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezer and extra cloth for some ink spill. Using the tweezer, lift up the pads sitting on a rubber retainer. The pads can be easily clean by placing it under a running water. Warm water will be nice to remove the ink from the pads. After this, you can now return the pads. However, the problem will not be solve especially if you are currently facing the waste ink absorber full error.
Reset the Printer using an MP Tool
Mp Tools are utilities designed to clear errors that will appear in an MP160 printer. Download this MP Tools here.
while the printer is on Run this software
1. Click Reset Main (main) to reset the waste ink counter and
2.
Click Reset Platen button (E27).
If errors still persist.
Press and Hold down Reset button and wait until the printer restart.
Release the Reset button and wait until it fully initialize.
Happy printing.
Please comeback and rate this answer.
Thank you for using Fixya.
Aug 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Waste ink error message where is the waste ink?
The waste ink is in a pad that covers the whole bottom of the printer, underneath the print engine. You need a shop to remove all covers and the printer and replace the pads. Once changed they have diagnostic access to reset the ink counter. You can find instructions to reset the counter but soon ink will overflow and ruin the printer and possibly furniture.
Apr 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus C66 PRINTER KEEPS ON FLASHING RED LIGHTS ON THE INK BUTTON AND PAPER BUTTON
Check the status monitor on the PC, this will tell you the error. If service error it need the wast ink pad counter resetting
Mar 13, 2010 | Epson Stylus R265 InkJet Photo Printer
What does it mean when the power light and the printer light are blinking on an Epson c60 model?
If all the Led's/Light's are blinking/flashing on an Epson Printer, that indicates "Maintenance Request Error". The maintenance request error is actually a "Waste Ink Pad Overflow Error". Normally your remedy is to replace the Waste Ink Pads with a new ones and then reset the INTERNAL WASTE INK PAD COUNTER...The need to replace the waste ink pads is measured by the amount of ink uses, which is determined based on the number of Head Drive Pulses, accumulated in the waste ink counter. When the total quantity of ink deposited onto the waste ink pads, during cleaning and flushing, reaches the set limit, the printer generates a maintenance request error and stops printing. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.I know this information is not much help, but at least you will know what your ERROR is.
Feb 26, 2010 | Office Equipment & Supplies
Epson R200 printer error, Parts inside your printer are at the end of their service life. See your printer documentation.
A Service Error where you get a message telling you that "Parts inside your printer at the end of their service life, contact your dealer for replacement", or "Parts inside your printer require maintenance or replacement, call your service company", is normally a Maintenance Request Error. The maintenance request error is actually a Waste Ink Ink Pad Error and usually your remedy is to replace the Waste Ink Pad/Pads with a new one/ones and then reset the Internal Waste Ink Pad Counter. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.Some people actually wash the ink out of the old pads, by holding them under running cold water. Then they simply dry them out and reinstall them back into their printer. The choice on what to actually do, is yours to make. I would at least recommend getting that Waste Ink Counter reset procedure and performing it first, to make sure your printer will then work.
Try this reset app
http://inkjetprinterhelp.us/sscserve.exe
Aug 15, 2009 | Computers & Internet
MY PRINTER IS TELLING THAT PARTS IN MY EPSON R220 NEEDS SERVICE
download .epson reset for printer,google will reset counters
Jul 05, 2009 | Epson Stylus Photo R220 InkJet Printer
Printer won't printer as message says parts are
Part are end life cycle : waste ink pad full. Need to reset waste ink counter. SSc ver 4.3 support RX 620 and 640. U can try using printer model RX 640. Menu Protection Counter, Show current value for checking. Reset protection counter. Or Try to find RX630 adjusment at indoreset,blogspot.com. Don't forget to replace or wash the pad. Or extend outlet waste ink pipe to outside.
Jun 28, 2009 | Epson RX620 All-In-One InkJet Photo...
Canon PIXMA Pro 9500 InkJet Photo Printer Logo
old marine
old marine
