Question about Maytag MVWX500XL High-Efficiency Bravos X Top Load Washer - Lunar Silv
I have a Maytag MVWX500XL High-Efficiency Bravos X Top Load Washer - Lunar Silv, just bought. It fills up with water, then drains immediately, washer stops and the only light on washer is where it says wash, does not go through any cycles. Please help
SOURCE: Help!! My maytag neptune MAH6700AWW is having trouble.
the fix was simple i just had to lift my drain hose off the floor. it had become disconnected from the back of the washer and was lying on the floor. I didn't realize that by it lying on the floor it didn't provide the proper back pressure to keep the water in while filling the tub. this was the NF error. as for the LE error. i haven't gotten it since i took off my cold water hose connection and ran hot water into it to losen the dirt/rust that was caked into the screen that is located in it. My washer is running like it is brand new again.
Posted on Feb 20, 2008
  • 79 Answers
SOURCE: MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
Posted on Feb 08, 2009
SOURCE: maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
Posted on Jul 03, 2009
  • 50 Answers
SOURCE: My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Posted on Jan 08, 2010
wpcustomer
  • 380 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    Why is the washer slowly leaking water into the back of tub between washes?
    There is grit in the water valve holding it open just enough to allow the water to seep by. You should get a filter system for your washer and replace the water valve, Grit is not covered by most warranties.
    Mar 13, 2016 | Maytag Bravos XL 4.6 cu. ft....
    How to run diagnostic
    Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
    www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
    Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
    Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
    Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
    Dec 02, 2015 | Maytag Bravos MTW6600T Top Load Washer
    Washer drain pump continually runs even with power off.
    have a technician check the power board as the pump power is not terminating when the machine switches off.
    Jun 27, 2015 | Maytag Bravos XL 4.6 cu. ft....
    Maytag bravos mvwx500xw0 has no power after closing lid
    You should hear a click just before the lid closes and a click just after it opens. If no click, check lid switch and it's actuator.
    Jan 12, 2013 | Maytag MVWX500XL High-Efficiency Bravos X...
    Maytag Bravos MVwX500XW0 Top Load Washer is not spinning
    Check the inbalance/lid switch for continuity.Ck speed selector switch (if any)the water level and water temperture switches for proper opreation.NOTE:If any of the selector switches on the console are only poartially pushed in,it may cause improper function.I do not know how old your washer is.TEST LID SWITCH FIRST.If above does not solve,ck timer circuits for continuity.Get ready for this:there is to much to ck with out been there.is motor buzzing,test capacitor,washer spins but does not agitate,ck the agitator splines if they are not rhe problerm,the transmission might be the problem.GOOD LUCK.FYI I own Whirlpool washer and dryer and I repair my own,I prefer KENMORE/WHIRLPOOL/ROPER PRODUCTS because they are easy to repair and parts are not as high priced.
    Sep 15, 2012 | Maytag Bravos X MVWX500X 4.3 cu. ft....
    My 3 month old washer suddenly started leaking from underneath. There was a code displayed of a 5d, but the washer drains into a laundry sink, there are no kinks in the input line.
    The washer is detecting too much soap. Make sure that you are using HE (high efficiency) soap Do a clean washer or hot cycle once a month with bleach or white vinegar with no clothes in it. Your washer only uses half the water that a regular machine does. The HE is specially designed for front loaders and these types of machines
    Jul 11, 2011 | Maytag Bravos MTW6600T Top Load Washer
    My bravos top loader will not fill up with water. The water drains as fast as it is trying to fill up. As a result, the wash cycle never completes.
    You must make sure the drain hose is above teh water level and not in the water in the "P" trap of the house drain. There must be air to prevent siphoning. The drain hose should not go more than about 12" down in the drain tube.
    Kelly
    Mar 27, 2011 | Maytag Bravos MTW6600T Top Load Washer
    Maytag MVWX500XL High-Efficiency Bravos X Top Load Washer - Lunar Silv Logo
    122 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
