Question about Kelvinator Refrigerators
Kelvinator refrigerator model C220HR
This is described as a 220L cyclic 2DR fridge. The unit stopped running. A wire/cable running from the back of the control/thermostat runs thru the back of the cabinet into the rear wall of the unit & does not reappear. If this wire is disconnected the fridge runs but overnight, freezes contents in the unit. Presumably this wiring connects to some sort of defrost or controls the thermostat. As the back & side walls of the fridge are sealed, how is/can this be repaired?
5 Suggested Answers
  • 1462 Answers
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
Posted on Nov 17, 2008
Maytag317
  • 1136 Answers
SOURCE: need to relace thermostat on kitchen aid wine cooler kuws246ebl2
Hi, The silver thing is not a wire. It is the sensor tube for the thermostat. The new thermostat will come with the sensor. Be sure and notice how and where the sensor goes in the wall. I hope this helps
Vic
Posted on May 20, 2009
  • 351 Answers
SOURCE: ice is collectin on back of lower compartment
Do you have an ice maker? if so then it is probably the icemaker over flowing. It probably is the water valve sticking or the ice maker is not satisfied. I have both parts available and ships same day 877-293-1739
Posted on Mar 14, 2011
rohntech
  • 422 Answers
SOURCE: I installed a defrost control
Either of the two you mention will do. Make sure you correctly install the wiring.
But usually it should have started after you plug in the wall. Try it check the wiring and it will work now.
Good luck.
Posted on Jun 12, 2011
Kelvinator Cyclic 330, Model No: CS334A-R
Tonight, get a battery flash light, turn it on, put it in the fridge and close the fridge door. Then turn off all the lights in the room. If you can see any light escaping around the fridge door, the door seals aren't working properly, and need replacing.
This is the main reason why too much water is being condensed and causing your fridge drip tray to overflow.
May 25, 2014 | Refrigerators
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
Wiring diagram for a Kelvinator 330
There's only 2wires and it shouldn't matter which terminal on the cold control u connect it to. If there's 3wires one should b green and it's a ground wire
Nov 30, 2013 | Electrolux Kelvinator Cyclic Defrost...
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Fidge is warm but freezer ok Kelvinator c 500 c r cyclic
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 07, 2011 | Refrigerators
Hi I have a Kelvinator Cyclic fridge freezer. Problem is fridge feels warm. The freezer just cold on coldest setting
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Nov 19, 2010 | U-Line 75R Refrigerator
Where abouts is the thermostat inside the fridge there are white and yellow wires that go to either side of the fridge and the yeallow ones are broken what are these wires for it is a kelvinator C375vm
It sounds like you have a cyclic defrost fridge,Kelvinators were originally fitted with heat assist thermostats,so in order for the fridge to come back on a yellow wire heater was run around the cooling evaporator in the fridge compartment start running again at approx +4C so when the element fused the fridge did not start again until approx +12C.So instead of replacing heater a different thermo was used that came back on at +4c deg regardless.Kind Regards.
Jul 09, 2009 | Refrigerators
I have a Kelvinator Cyclic 501 Impression Series fridge. Model C501V-R. no matter what setting it is on everything is freezing - the door seals are in excellent condition.
I used a,Hair Dryer on mine that fixed it, had too do it twice though have not had a problem since, (it froze the entire Thermostat over), had my Fridge for over 30 years only ever replaced the seals recently, no other problems ever
Jun 11, 2008 | Refrigerators
Refrigerators Logo
76 people viewed this question
Top Kelvinator Refrigerators Experts
Charles T Nevin
Charles T Nevin
Melissa Martin
Melissa Martin
Are you a Kelvinator Refrigerator Expert? Answer questions, earn points and help others
